#1 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
Anyway I posted about this before but couldn't get the right answer and I searched with no luck, is the method to adjust the clutch so there's about a 1 inch difference between the brake and clutch pedal?
I have a 6 puck clutch and it engages really high in a really short amount of pedal at the top and it's kinda annoying. Also like I mentioned before, sometimes it's hard to get the car in gear in first or reverse from a complete stop, like it doesn't let me in. No grinding or anything. But it doesn't let me in. Obviously something isn't right. 06 wrx 07 sti trans fx400 clutch new oem sti flywheel.
#2 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
There should be an adjustment on the pedal, in the pedal area, at least there is one on my pedal box. Never seen an 06 wrx set-up though....
~Josh~ |
#3 |
Member#: 243992
Yes there is, I adjusted it when I got my clutch to how I believe it said in the manual.
#4 |
Member#: 243992
No one can help me?
#5 |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
Try adjusting the pedal again.. maybe you did it wrong.. it can only go 2 ways
#6 |
Vehicle:OK Houston we have an Uncle |
and if ya still have the anti dump valve in there...get rid of it
#7 | |
Member#: 243992
I will look at adjusting it again. I heard they are higher (assuming because they are thinner) and I also assume the travel is just due to how fast it engages. I just want to be positive. Especially because of the first gear issue I'm having. |
