#1 |
Member#: 309754
Tri-State
Vehicle:2012 Impreza Sport L Ice Silver Metallic |
![]() ![]() ![]() ![]() Ok, here we have the 2012 Impreza 2.0i Sport Limited. I will be doing a OEM LED mirror retrofit. First you need to order the following parts: 4 - Solderless Terminals 4 - OEM Screws Part No. 91039AJ500 $00.71 each 1 - Left Cover Part No. 91059AJ210 $33.71 1 - Right Cover Part No. 91059AJ200 $33.71 1 - Left Lens Part No. 84401AJ010 $67.48 1 - Right Lens Part No. 84401AJ000 $67.48 PLUS + $14.00 shipping comes out to $219.22 www.heubergersubaruparts.com ![]() ![]() As you can see that one for the mirror covers have the cut out in them. In Japan they paint them and have different part numbers for the painted part, In the USA they only come in that unpainted beige color. ![]() The lens look like it has a slight tint to them, and have a defusser in the plastic to make the LED look brighter. This is the wire that you are going to connect the POSITIVE + side of the Signal Lens to inside the door harness (YES) it's already there. The white wire with a red stripe is the turn signal. ![]() ![]() This is the finished product below and I will take another picture with the cover painted and on the mirror.
#2 |
Member#: 72730
NESIC
Vehicle:2001 Lexus ES300, 2005 Outback XT |
Nice job! Having worked with the earlier Impreza/WRX/STI mirrors for a while now, I was waiting for someone to take this one on. Since the earlier Impreza almost always had the wiring already there for signals and this new gen the Canadian model already has the signals, it makes sense the wiring is there.
#3 |
Member#: 315759
Vehicle:2012 Impreza 5 Door Obsidian Black Pearl |
Nicely done!
#4 |
Member#: 309754
Tri-State
Well it's the wiring for the FOLDING JDM Mirrors! it's in the same harness! WoW!! This is GREAT NEWS!!
![]() ![]() ![]() RIGHT NOW ON EBAY! $800 SHIPPED! OUCH!!!! http://www.ebay.com/itm/360539242698...witem=&vxp=mtr Last edited by ZURCALED12; 02-15-2013 at 12:11 PM. Reason: adding price & ebay link |
#5 | |
Member#: 309754
Tri-State
#6 |
Member#: 72730
NESIC
Yep this is pretty standard all the previous imprezas have some of the JDM wiring. I have been keeping my eye out for some of the newer mirrors if I could land a set I could do better than $800.
PM me if you might be interested in checking a couple more things to see how ready the wiring is for JDM folding... |
#7 |
Member#: 309754
Tri-State
#8 | |
Member#: 309754
Tri-State
#9 |
Member#: 342440
Vehicle:2013 Impreza 5dr Ltd Satin Pearl White |
#10 | |
Member#: 72730
NESIC
#11 |
Member#: 309754
Tri-State
Cool, I am for sure interested, when you come across something let me know and I will PM you right away. I am most likely going to get a few parts painted besides the mirror covers.
#12 |
Member#: 305152
South East
Vehicle:2012 WRX 5-Door WRB 2000 Corvette C5 |
Can you make a write up for my 2012 wrx to do this?
PM ME |
#13 |
Member#: 349481
Vehicle:2013 XV Crosstrek Black |
does anyone know if these are the same mirrors for the XV Crosstrek? Unfortunately the USA XV's dont have the signal mirrors as an option. Also do these have the heating element in them? I know there isnt a separate switch for the heated mirrors and that they just work off the rear defrost button. I've been itching to do this ever since i got my XV. Havent checked the wiring harness yet.
#14 |
Member#: 315759
I'm going to go out on a limb here and say yes.
#15 |
Member#: 315759
#16 |
Member#: 315759
That Beige looks painted. Is the plastic itself that color? Im thinking we can get a different part number and get the right color somehow? You've done a great job sourcing and pioneering this and I am ready to pull the plug on it, but I want to do it right. I don't want tan paint chips on my black mirrors. Your input is much valued.
#17 | |
Member#: 309754
Tri-State
#18 |
Member#: 309754
Tri-State
Harness side has wires. There are no pins on the mirror side , but on the harness side there are pins, I just spliced the wires twisted them into the empty mirror side pin holes, and when I connected the two connectors (mirror side/connector side) together they made contact. I don not know where you would get the pins from since no one sells them or for that matter makes them. |
#19 |
Member#: 342440
Has anyone else seen these mirrors for the 2014 Forester?
http://www.patrickaccessories.com/J201SSG000 http://techinfo.subaru.com/proxy/706...j201ssg000.pdf Auto dimming and approach lighting. |
#20 | |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
#21 | |
Member#: 72730
NESIC
Some have asked about the wiring, looks like OP had to rig it up the best he could and this is how most do it.
The electrical parts are available, identifying and sourcing them is the hard part, Subaru will sell you mirror parts but not the internal wiring. I have sourced the parts, I am going to make up a run of signal wiring, to see if people would be interested. If you use my wiring, you can make the signal like stock, with the waterproof plug and the wiring snaps into the connector in the door. It looks like this: ![]() ![]() Quote:
Now of course this is all pre-wired on the Forester...previously the largest connector was a 10-pin but this new Forester must have a 14-pin they have added at least 4 more wires. To add all that stuff to another model you'd have to wire into the door from the mirror and interior lighting to get both those functions to work, would be way cool though. |
#22 | |
Member#: 15451
MWSOC
Vehicle:2013 XV Crosstrek Desert Khaki - CVT |
Thanks! Jim |
#23 | |
Member#: 309754
Tri-State
#24 | |
Member#: 309754
Tri-State
![]() YES THEY ARE! Exterior Auto-Dimming Mirror with Approach Light MSRP: $199.95 Add to Cart Your Price: $149.96 Description Enhance your Auto-Dimming Mirror experience by adding the Exterior Auto-Dimming Mirrors with Approach Light.* Open or unlock the doors with the keyless entry system and LED lights located behind the Subaru logo in each exterior mirror help to light the way. Light is cast down all four doors and onto the ground next to and towards the rear of the vehicle. When in traffic, the Exterior Auto-Dimming Mirrors help add to a safer driving experience by reducing headlight glare on the exterior mirrors. This occurs when excessive light is detected from the rear of the vehicle. The dimming level of the exterior mirrors is regulated by the level of light detected by the Interior Auto Dimming mirror. *Requires accessory interior Auto-Dimming Mirror. This item fits: Forester 2014 Impreza 2.0i 2012-2013 *approach light only XV 2013 *approach light only Last edited by ZURCALED12; 04-13-2013 at 07:01 PM. |
#25 | |
Member#: 349481
