Old 01-13-2013, 09:37 AM   #1
Luc r
Member#: 332784
11 flexed wrx
Default direct port meth question
ill be running direct port meth injection on my 06. im curious if just one pump can handle direct port, or if ill need 2 pumps
thanks
-Luc
Luc r is offline   Reply With Quote
Old 01-13-2013, 03:30 PM   #2
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
1. How much meth are are flowing?
2. What kind of system do you have?
Aquamist is offline   Reply With Quote
Old 01-13-2013, 05:15 PM   #3
Luc r
Member#: 332784
11 flexed wrx
leaning towards the aem kit, then adding 3 ports and nozzles. not sure on how much ill be flowing yet
Old 01-13-2013, 05:54 PM   #4
Aquamist
NASIOC Manufacturer
Member#: 110029
The AEM or 250psi aqutec pump shoudl be able to flow 2000cc+/min on reduce pressure.
Old 01-13-2013, 05:57 PM   #5
Luc r
Member#: 332784
11 flexed wrx
on average how much are you flowing per min. on direct port?
Old 01-13-2013, 07:34 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Thats a question you have to figure out based on your fuel injectors and the % of meth/water injection u want to be able to do. Then divide that by 4 and then you have your direct meth injection jet sizes. Atleast thats how we have done it in the past.
Token-Negro is offline   Reply With Quote
Old 02-10-2013, 10:01 PM   #7
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
So then what would it calculate out to with 850cc fuel injectors and a 50/50 meth-water mix?
I just got a set of APS duel injector TGVs and Im looking to run direct port through the secondary injectors on the TGVs. This in theory will all be controlled through a AEM 2 EMS. Basically in short a full second fuel system for the meth. Injectors rails regulator pump tank ect...
I have an Aqua Mist V5 system still in the box, but if I can run direct meth with the AEM EMS via injectors through the dual TGVs along with supporting bits Id sell it and put together that said system.
Is my thinking correct??
dangerousatom is offline   Reply With Quote
Old 02-11-2013, 03:55 AM   #8
Aquamist
NASIOC Manufacturer
Member#: 110029
For direct port application, it would be advisable to use your NIB aquamist system due to better flow control at low to mid range. Pump speed system tends to over inject at those areas.
There are other advantages also.
Old 02-14-2013, 01:54 AM   #9
shaman
Member#: 164259
Stick with the HFS-5. the valve will help you out with multiple nozzles, pressure and dribbling.
I have a direct port kit with 0.3mm nozzles if you are looking.
shaman is offline   Reply With Quote
Old 02-14-2013, 04:12 PM   #10
dangerousatom
Member#: 70710
Im not using meth nozzles, Ill be using out right fuel injectors for the meth.
Old 02-15-2013, 03:00 AM   #11
Aquamist
NASIOC Manufacturer
Member#: 110029
There is a very good chance of corrosion if you use 50/50.
Old 03-30-2013, 10:22 AM   #12
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I had considered doing this, aquamist is right though, the injectors will corrode. There is however a company that makes stainless steel fuel injectors for motorcyles. Pm me, they were hard to find, i want to say from england somewhere.
Old 03-30-2013, 07:15 PM   #13
reid-o
Member#: 103631
2004 STI
Aren't flex fuel injectors stainless?
Old 03-30-2013, 07:20 PM   #14
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I dont know for sure, but since ethanol is not as corrosive than methanol i would say no i dont think so.
Old 03-31-2013, 08:10 AM   #15
reid-o
Member#: 103631
2004 STI
Check out mike Moran fuel injectors. Pricing is insane though.
