#51 | |
Member#: 204765
SCIC
Vehicle:2008 STi OBP |
I use tasker to turn on screen and wifi when the power is applied via USB. The power adapter is switched. Nothing fancy in tasker right now just wifi and screen on / off. During testing I tried out many of the car apps and hated them all, car home ultra is not bad but overall did not like them. I decided that I put the tablet into the car because I really like the stock android experience so why ruin a good thing... I've been researching IOIO + tasker options for a few ideas. Screen dimming with dash dimmer, timed charging, cooling etc. Anti-glare helps allot, and had the added surprise benefit of making the tablet polarized sunglasses compatible.
#52 |
Member#: 95193
MWSOC
Vehicle:2013 STI Crystal Black Silica |
I was on the internet and I found this...
http://hackaday.com/2013/01/29/adapt...board-opening/ I thought it looked oddly familiar ![]() |
#53 |
Member#: 330817
I'm doing this project this weekend.
I know I'm going to jack something up, but can't wait! |
#54 | |
Member#: 305167
MWSOC
Vehicle:2011 WRX SWP |
Looks like somebody noticed his work and I gotta say it's a really good one.I'm thinking of doing it, except I got galaxy tab 10.1. But that's summer project for now and if I can fit in the dash ![]() |
#55 |
Member#: 170097
South East
Vehicle:2007 WRX STi PTE6266 OBP |
Pretty sure he answered this. I understood that it probably won't be enough for some, but it works. Probably a little better/louder than the stock radio.
#56 |
Member#: 345419
I found this thread via hackaday...
I thought I would post a link that may help the OP... http://forum.xda-developers.com/show....php?t=2019847 The nexus 7 has 4 pogo pins on the side and since jellyBean 4.2.1, these can be used for Charging and Audio output. This would free your BT connection for a phone and you wouldn't have to by any other hardware, such as the USB-OTG DAC. Cheers -AL |
#57 |
Member#: 170932
Vehicle:02 wrb wrx 18g'd |
How did you get spotify to work in landscape mode?
#58 |
Member#: 270751
Nice work, I wanna ask how secure is the cig charger plugged in? I would be worried vibrations would shake it loose in that configuration.
#59 |
Member#: 284582
South East
Vehicle:2011 WRX Dark Grey Metallic |
#60 |
Member#: 336913
E. Canada
Vehicle:2010 Impreza Ltd |
#61 | |
Member#: 345650
MWSOC
Vehicle:2002 WRX Bugeye Silver |
I plan to replicate your setup on my '02 WRX. Thinking about heat, my idea is to use a usb fan and connect that to some of battery pack that supports pass-through charging like the HyperJuice Mini and connecting it to the usb fans. The fans would still run when the car is off, and would probably run a long time with a decent sized battery pack. add in a USB on/off switch and you have an easy cooling system that will run all day. I was thinking of drilling holes in the Nexus cover and mounting the fans with Sugru (or some adhesive). You could even go as far are popping off the back cover of the Nexus 7 itself and drilling a few holes. Ifixit.com did a teardown and the back cover comes off very quickly. I plan to install a radio where my clock is using a Upper Dash DIN mount and just running an AUX cable to the Nexus. The power with use a 12v adapter that my mechanic will run straight to the battery to charge the device. I am also going to hid a NFC tag behind my dash that will trigger my phone to turn on WIFI hotspot and connect to my Nexus for internet. I'm going to start with buying the Dash mount and redoing my radio before anything else. I kind of want to find a ****ty looking deck that that has Back AUX out to deter theft. All I would use the radio for is to power speakers volume/radio. Any Suggestions on something not flashy? I might wait and see about a 1080p Nexus 7 that could come out in may (Link) Can you tell me which Metra radio mount you used specifically? |
#62 |
Member#: 40943
Vehicle:2003 subaru wrx aspen white |
wow. impressed with the build! good job.
#63 |
Member#: 271691
SCIC
Vehicle:2004 WRX Wagon Silver |
Gorgeous!
#64 | |
Member#: 256712
Regarding heat and possibly theft, my idea was to make it removable, as in take the N7 w/ me when I left the car. Taking into account your previous experience, would you find it possible? |
#65 |
Member#: 347121
NICE WORK!
Have a few questions though, Did you need a special harness to go from your wiring to the bluetooth receiver? (Crutchfield is telling me I need a wiring harness then a special bluetooth harness that connects to the bluetooth receiver) Have you had a problem with the MKi9 disconnecting on you? I see you're in SoCal and so am I so how much did the acrylic cost? and what dimensions did you use for the acrylic? |
#66 | |
Member#: 347121
#67 | |
Member#: 303408
NWIC
Vehicle:04 STi WRB |
#68 | |
Member#: 347121
This guy tested it and it looks like a go, I've been trying to find the same info on XDA but I didn't find anything except I did see your question on that thread though! Hahahaha |
#69 |
Member#: 347121
#70 | |
Member#: 303408
NWIC
nice, thanks for the link. |
#71 | |
Member#: 170097
South East
Thanks. |
#72 | |
Member#: 347121
#73 |
Member#: 170097
South East
#74 |
Member#: 347121
#75 |
Member#: 317947
Best setup I've seen so far!
Can you describe how you've integrated your speakers and tablet? |
