Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 02-02-2013, 01:10 AM   #101
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Got to love when the Media guys do all the work when you are at home!! Check out the latest Q300 video.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 02-02-2013, 11:08 AM   #102
KD1CA
Member#: 341974
09 WRX
BLAACCKK
Awesome Video! Sounds great.
KD1CA is offline   Reply With Quote
Old 02-02-2013, 11:54 AM   #103
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
sounds great!
FCmaniac is offline   Reply With Quote
Old 02-13-2013, 03:30 PM   #104
RallySport Direct
Member#: 33174
We are Open Late!
For those of you not following us on Facebook, first shame on you :P, second we posted up this little teaser shot
https://www.facebook.com/Rallysportdirect
Kirill
RallySportDirect.com
Old 02-14-2013, 12:41 PM   #105
RallySport Direct
Member#: 33174
We are Open Late!
Dem Rear Brakes
Kirill
Old 02-14-2013, 12:42 PM   #106
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Fapfapfapfapfap
Old 02-14-2013, 12:59 PM   #107
Bones702
Member#: 205115
06 Sti Dom4.0XTR
Those brakes are sick. I would love that setup on my STI.
Bones702 is offline   Reply With Quote
Old 02-14-2013, 01:00 PM   #108
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Not a bad way to spend $10,000
Old 02-14-2013, 01:10 PM   #109
Jdub.csu
Member#: 283784
2013 EVO X GSR
Time to track this bad boy
Old 02-15-2013, 02:05 PM   #110
RallySport Direct
Member#: 33174
We are Open Late!
One more shot of the rear:
Thanks,
Jasmin
Old 02-17-2013, 03:31 AM   #111
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Thanks,
Rick
For cryin' out loud, please vacuum the road before making another under car vid like that.
Gallo2011 is offline   Reply With Quote
Old 02-18-2013, 12:14 PM   #112
RallySport Direct
Member#: 33174
We are Open Late!
Next project car is the RSD Street Sweeper!
Check out our new video we made of the Tein Street Flex coilovers on our BRZ
Thanks,
Rick
Old 02-18-2013, 12:18 PM   #113
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Wow theres a lot of flex in that sway bar mount.
Old 03-04-2013, 09:38 PM   #114
RallySport Direct
Member#: 33174
We are Open Late!
Wanted to do a quick review on the Cusco engine mounts and their rear diff mount as well. One thing I noticed while driving the car was the vagueness coming from the stock engine mounts and the rear end as well. I saw this as a opportunity to not only improve on those aspects of the car, but it also gives me the opportunity to give you guys my impression of the parts as well.
Let's start with the install first. The engine mounts are very straight forward, simply unbolt the 2 large nuts on the bottom of the front cross member, and then the 4 bolts holding the left and right mounts to the engine block. Lift the engine up a few inches to gain enough clearance to remove the old mounts. The new cusco mounts are a bit easier to get in than the stock ones are to remove, but really neither are that bad. The new cusco mounts will bolt up just like stock, and so you will just reverse the uninstall process, and they should bolt right in without too much fuss.
The rear diff mount was a bit more tricky, and not that I would ever call it a difficult install, but a bit more time consuming as you do have to access the inner portion of the rear cross member, which will require you to remove the lateral arms from the rear cross member. Once you have access, you will want to get your skinny fingered friend to hold the nut on the inside of the cross member as you thread the long bolt through the new mount and into the nut. Other than that very minor frustration of small access holes, the install was a breeze and bolted up just like it was supposed to without any problems.
Now the review! I must say, I was never expecting these to retain the factory comfort levels, as I have run products like this on my own cars. I did notice a bit more noise and vibration than I was used to, but once I had a chance to go drive the car, I knew exactly why I did these mods, and the extra noise and vibration was almost a welcomed feeling. The direct connection these parts bring to the car is a huge improvement over the stock bushings, no longer do you feel the slop from the rear end, or the somewhat delayed response from the engine. Everything is instant, everything feels solid, and it feels AMAZING! Finally the Albino Rhino is starting to become what I had envisioned in my head, and besides the extra noise and vibrations, I could not ask for anything more.
I would not recommend these parts for anyone who wants to keep their car as a comfortable daily driver, as you will most likely despise these mods. But for someone looking for something more aggressive and direct, and does not mind the harshness, than this would be perfect!
Check out the videos below for some before and after.
Cusco Engine Mount Set Subaru BRZ / Scion FR-S
Cusco Rear Differential Support Brace Subaru BRZ / Scion FR-S
Thanks,
Rick
Old 03-04-2013, 09:38 PM   #115
RallySport Direct
Member#: 33174
We are Open Late!
I know, it's crazy how much flex there is!!
Thanks,
Rick
Old 03-10-2013, 11:34 AM   #116
05lgturbo
Member#: 349689
Look sick
05lgturbo is offline   Reply With Quote
Old 03-10-2013, 01:49 PM   #117
RallySport Direct
Member#: 33174
We are Open Late!
Spotted in the wild!
Kirill
Old 03-16-2013, 06:42 PM   #118
RallySport Direct
Member#: 33174
We are Open Late!
We took the STi and the Rhino out for some laps around Miller Motorsports Park yesturday evening .
Good times! Both cars need set up, but gave us a chance to get a good idea where to start
(we will have some non cell phone pics up shortly)
Kirill
Old 04-13-2013, 08:44 AM   #119
superbike81
Member#: 235442
Wow, this car is growing on me more and more. I didn't like it at first, but seeing one truly well done like this makes me like it. Especially with those brakes! Just awesome!
superbike81 is offline   Reply With Quote
Old 04-22-2013, 01:00 PM   #120
RallySport Direct
Member#: 33174
We are Open Late!
Been really busy with the car recently and have a few updates for everyone!
First, we installed the Kartboy short throw shifter with the rear bushing. Now we all know the stock shifter is pretty good, but I wanted even shorter throws and a more direct feel to the shifter as a whole and Kartboy came to the rescue with their Short Shift Kit!
I LOVE this shifter! Install was not too bad at all, and the shifts are definitely more crisp and direct, plus it does reduce the throw between shifts which makes for slightly quicker shifts as well. The rear bushing helped secure the shifter assembly as a whole and really adds to the feel when shifting quickly.
Next, we decided the car needed something up front to complete the look we were going for when we added all of the beautiful APR carbon fiber bits. So, naturally we looked to APR and we installed their Carbon Fiber Mirrors and Carbon Fiber front Air Dam. I was not quite sure how these would look, but based off the quality and look of the previous APR parts installed, we knew we had to install them, and I must say, they make the car look jaw droppingly beautiful.
And last but not least we installed the Prova Front Fender Emblems. Since day one, we have wanted to get rid of the stock fender emblems, and go with something a bit different, so as soon as these showed up here, I grabbed a set and installed them that same night. Fitment is perfect, the quality is top notch and they come pre-painted and ready to install. I really like these as they are a subtle addition to the car, they don't really stand out, but they do add something to the car that I just can't quite put my finger on. Either way, I am loving the way the car is looking with all of the additions we have done to it.
We have some really good things in the works for this car, can't divulge any info, but I think you will really like it
Thanks,
Rick
Old 04-22-2013, 01:02 PM   #121
RallySport Direct
Member#: 33174
We are Open Late!
Old 04-22-2013, 11:55 PM   #122
Harey
Member#: 270569
Great work guys, love the brakes! The diff brace sounds like a great mod
Harey is offline   Reply With Quote
Old 04-23-2013, 10:40 AM   #123
RallySport Direct
Member#: 33174
We are Open Late!
Thanks! And yes, the diff brace made a huge difference for sure, no more sloppy rear diff!
Thanks,
Rick
Old 04-24-2013, 01:07 AM   #124
ben_art
Member#: 172635
2003 WRX Wagon
small, possible off topic question, are the yellow headlight lens' covers legal? all states? perhaps i need to inquire with my dmv
ben_art is offline   Reply With Quote
Old 04-24-2013, 04:12 PM   #125
RallySport Direct
Member#: 33174
We are Open Late!
You would need to check with your local DMV/DOT. As that is something that is different state to state.
Kirill
RallySport Direct's BRZ: The Albino Rhino RallySport Direct BRZ Forum 179 07-18-2014 11:37 AM
RallySport Direct's 2011 STI Sedan! RallySport Direct NASIOC Project Cars 540 04-07-2014 02:31 PM
RallySport Direct's 2011 STI Sedan! RallySport Direct Rocky Mountains Impreza Club Forum -- RMIC 192 12-27-2010 03:07 PM
RallySport Direct's 2011 STI Sedan RallySport Direct Member's Car Gallery 119 08-25-2010 04:06 PM
OMG - I think I made the theme track to the Spearmint Rhino... sherifx Southern California Impreza Club Forum -- SCIC 9 05-19-2004 05:41 AM
