Old 02-15-2013, 12:12 AM   #1
wrxjon1989
Member#: 331101
2010 Impreza WRX
Default 2010 WRX "lowering"
I want to lower my Rex but can't decide on what to do. Should I go with a good spring on my stock struts? Or should I get cheaper coilovers like the basic tien or megan racing? What's good and keep my car comfortable as a daily driver.
Thanks everyone.
wrxjon1989 is offline   Reply With Quote
Old 02-15-2013, 01:31 AM   #2
mod maniac
Member#: 300551
2002 DD wgn 6 spd
2.1 kel 272's meth 2.5xtr
Lowering springs on your stock struts would be the best ride. Coilovers would handle better. Lowering springs with sways would be a good combo for both ride and handling.
mod maniac is online now   Reply With Quote
Old 02-15-2013, 01:59 AM   #3
sc00by4life
Member#: 97135
This is so insanely generalized that it is nowhere near an accurate statement.
Old 02-15-2013, 02:08 AM   #4
aod12
Member#: 282701
2008 Impreza 2.5i
Dark Grey Metallic
If you want a reliable and comfortable but firmer ride get a good strut/spring set up. Bilstein shocks and RCE yellow/black springs are in high demand because of their quality. Koni inserts are also a great upgrade that offer adjustable damping and are more readily available, but you have to modify your stock front struts. Because of their adjustable damping, they are slightly better for a broader range of springs.
Another option is to buy preowned set ups, look in the classified under suspension to buy. But do some research and read through the suspension subforum under Technical
aod12 is online now   Reply With Quote
Old 02-15-2013, 02:50 AM   #5
Gallo2011
Member#: 268310
2011 STi SSM saloon
Church!
If you do decide to go with coilovers, I guarantee you will regret going cheap. Save your pennies and go with a quality coilover. Here's an example of quality from Turn-In Concepts.
http://turninconcepts.com/index.php?..._481_1078_1555
Gallo2011 is offline   Reply With Quote
Old 02-15-2013, 07:04 AM   #6
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Call turn in concepts and tell them EXACTLY what you want. Follow what they say to the T.
OR buy s-techs.
Old 02-15-2013, 07:24 AM   #7
blue sedan
Member#: 311622
2010 WRX STG 2
KONI struts/RCE BLACKS are a comfortable daily ride and ready for track use.Ive been using this setup with no complaints.There's a great thread by XLUBEN w.pics!
blue sedan is offline   Reply With Quote
Old 02-15-2013, 08:23 AM   #8
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I still don't get why people don't just call TiC... we could tell you to go with Bilstein struts, RCE yellow springs, and a Whiteline roll center kit, but who knows if that's what you're looking for. Go call them and I promise you won't regret it.
Old 02-15-2013, 08:47 AM   #9
Thunderpaw
Member#: 242205
2009 wrx
blue
Don't buy coil overs just to lower your car
Thunderpaw is online now   Reply With Quote
Old 02-15-2013, 10:31 AM   #10
mod maniac
Member#: 300551
2002 DD wgn 6 spd
You are right that is a generalized statement. Nowhere near accuate there I would disagree.
Old 02-15-2013, 11:22 PM   #11
Hmclark2143
Member#: 347188
04 Wrx
I have adjustable coil overs and lowered it 2 inches. It does good for a daily driver
Hmclark2143 is offline   Reply With Quote
Old 02-16-2013, 01:36 AM   #12
sc00by4life
Member#: 97135
In general, peoples opinions on coilover quality are wrong. Without experience and knowledge to back up their assessment, the advice means nothing to the OP.
If a statement is generalized, then that means it is not correct in every scenario. Meaning its pretty useless in terms of accuracy. Especially when the market is saturated cheap coilovers that handle like absolute garbage.
When attempting to provide assistance for newbies, it helps to actually include useful information.
Your post is completely worthless without knowing WHAT type of coilovers, spring rates, what type of driving you do, alignment specs, corner balanced or not....
Old 02-16-2013, 02:13 AM   #13
mod maniac
Member#: 300551
2002 DD wgn 6 spd
^^^ ok and all you have is what? where is your useful info? just a critic?
Old 02-16-2013, 04:30 AM   #14
sc00by4life
Member#: 97135
Post 6 covered everything OP needs to know.
Old 02-16-2013, 07:57 AM   #15
Tweeder
Member#: 129922
MBP
^^But there is enough information on this site that can answer his question. Which reminds me isn't there a suspension sub forum or some great stickies on this site
OP do some research and understand how to properly lower your car and how the mechanics of it all work. By doing that you will answer your own question with out even having to ask.
I even found a good link for you.
http://forums.nasioc.com/forums/showthread.php?t=911257
Tweeder is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 01:57 AM.
