Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Used, Open Box or Refurbished Items
Old 02-16-2013, 08:07 AM   #1
PerformanceAutoSolutions
Vendor Sales Rating: (18)
Member#: 853
2011 STI Sedan
Default 06+ WRX Clutch Components BRAND NEW OPEN BOX!
ACT Pressure Plate SB014-P/PL Heavy Duty
Pressure Plate Type: Heavy Duty.
Engagement: A low to moderate pedal feel.
Recommendation: Recommended for street and race use.
Description:
ACT pressure plates use exclusive diaphragm design to increase clamp load, reduce deflection and maximize clutch life. All diaphragms endure an exclusive four-stage, heat-treating process for unparalleled performance. ACT pressure plates have precision cover stampings to provide rigidity and consistency. ACTís Heavy Duty pressure plates increase clamp load by 20 to 50 percent. ACTís Heavy Duty pressure plates are recommended for use with a street or race disc.
Part Number:
SB014
$425.00 SHIPPED
ACT Flywheel
Flywheel Weight:13.7
Feel: Improved engine response and acceleration with lightweight design
Recommendation:Recommended for street and race use
Description:
ACTís XACT Streetlite flywheels are considerably lighter than stock and are the most durable flywheel offering from ACT. Materials are properly distributed for maximum strength, lower inertia, good heat tolerance and rigidity. ACTís Streetlite flywheels are preferred for street or drag racing. XACT flywheels are serviceable and can be resurfaced with no need to purchase additional parts.
Part Number: 600480
$242.00 SHIPPED
ACT Clutch Disc
Disc Type:Race Disc
Engagement:Aggressive engagement with fast shift action; Spring-center construction for low to moderate gear rattle
Recommendation:Recommended for high horespower street or race use
Description:ACTís 6-pad, spring-centered race discs are made with high quality ceramic friction materials. The engagement is harsher, but shifting is faster. The heavy duty torsional dampening springs are stronger in most cases than standard springs and are provided in the best sizes and spring rates to suit the application. The 6-pad, spring-centered disc is recommended for larger clutch sizes to absorb more heat and for smoother engagement.
$125.00 SHIPPED
****** Brand New Never Used Items******
**Please note that these products are from our display/open box area at the shop..**
Fitments: 2006+ WRX 2.5 ltr
-Don't forget to check out our website at
www.performanceautosolutions.com
__________________
PerformanceAutoSolutions is offline   Reply With Quote
Old 02-19-2013, 03:34 PM   #2
Member#: 853
2011 STI Sedan
Bump!!
__________________
Old 02-21-2013, 03:31 PM   #3
Member#: 853
2011 STI Sedan
To the top!!
__________________
Old 02-22-2013, 03:09 PM   #4
Member#: 853
2011 STI Sedan
Friday Bump
__________________
Old 02-28-2013, 03:19 PM   #5
Member#: 853
2011 STI Sedan
Bump!!
__________________
Old 03-01-2013, 03:43 PM   #6
Member#: 853
2011 STI Sedan
Its Friday!!!
__________________
Old 03-05-2013, 03:40 PM   #7
Member#: 853
2011 STI Sedan
To the Top!
__________________
Old 03-07-2013, 03:07 PM   #8
Member#: 853
2011 STI Sedan
bumpppp
__________________
Old 03-12-2013, 03:33 PM   #9
Member#: 853
2011 STI Sedan
Tuesday Bump..
__________________
Old 03-14-2013, 03:14 PM   #10
Member#: 853
2011 STI Sedan
To The Top!!
__________________
Old 03-19-2013, 03:44 PM   #11
Member#: 853
2011 STI Sedan
Tuesday Bump To The Top!!
__________________
Old 03-21-2013, 02:30 PM   #12
Member#: 853
2011 STI Sedan
Top The Top!!!!
__________________
Old 03-22-2013, 02:45 PM   #13
Member#: 853
2011 STI Sedan
Friday Topper!!
__________________
Old 03-23-2013, 03:22 PM   #14
superblkwrx
Member Sales Rating: (3)
Member#: 129395
2006 OBPWRX VF39 E85
333WHP 385WTQ 21PSI SD
will running this flywheel throw a misfire code from de-acceleration?
superblkwrx is offline   Reply With Quote
Old 03-26-2013, 02:21 PM   #15
Member#: 853
2011 STI Sedan
bumpp...
__________________
Old 03-28-2013, 03:28 PM   #16
Member#: 853
2011 STI Sedan
Thursday Topper
__________________
Old 04-09-2013, 03:49 PM   #17
Member#: 853
2011 STI Sedan
Bumppp!!!
__________________
Old 06-30-2013, 01:20 PM   #18
army21b
Member Sales Rating: (8)
Member#: 228116
2008 FXT Sports
AW
Still have the flywheel?
army21b is offline   Reply With Quote
Old 09-09-2013, 12:40 AM   #19
morbid818
Member Sales Rating: (6)
Member#: 144182
2006 WRX
BLACK
Still have the heavy duty pressure plate?
morbid818 is offline   Reply With Quote
