Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 01-10-2012, 06:13 PM   #1
ukranianization
Member#: 238506
2003 wrx
Psm
Default 05 legacy GT STI swap
My brother got a legacy gt with a bad engine,turbo and everything and was thinking about an STI swap. Is there a thread on this? Do you need a lot of wiring work and etc. Done?
ukranianization is offline   Reply With Quote
Old 01-11-2012, 03:19 PM   #2
typrice
Member#: 255253
2005 Legacy GT
This is interesting, I would love to know the answer.
typrice is offline   Reply With Quote
Old 01-11-2012, 03:57 PM   #3
elromero3
Member#: 281131
Check out PHAT subi's project. Its coming along looking sweet
elromero3 is offline   Reply With Quote
Old 01-11-2012, 08:25 PM   #4
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Is the Legacy GT auto or manual? I'm pretty sure PHATSuby went from an auto to a manual though, so that would eliminate a lot of the work and wiring harness splicing. Also, Ben is using a BE/BH Legacy, not the 4th gen Legacy (2005). I really don't think it would be that much depending on the donor car that you're harvesting from. But it's not as simple as dropping in a new motor.
Frogsthatmoo is offline   Reply With Quote
Old 01-11-2012, 09:40 PM   #5
Azlegacy
Member#: 279837
After reading above it doesnt make sense. 2005 and up are turbo'd. There is no engine splicing. Swap to an STi block , fuel injectors , and turbo or rebuild current turbo. Get a tuner and good to go . As far as I know.
Azlegacy is offline   Reply With Quote
Old 01-12-2012, 04:42 AM   #6
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
it's direct swap....
kirbykirb is offline   Reply With Quote
Old 01-12-2012, 10:07 AM   #7
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Outback STI
For reference. Same body (just an Outback). Gregnauman can probably answer any questions you want.
Old 01-12-2012, 12:44 PM   #8
netsfan549
Member#: 296456
09 Legacy
blue
I have a 2.5 na engine. Can I put a gt engine in it?
netsfan549 is offline   Reply With Quote
Old 01-12-2012, 08:35 PM   #9
Azlegacy
Member#: 279837
^ If u want to spend thousands of dollars u can.
Old 01-18-2012, 04:36 PM   #10
G3nX09
Member#: 307045
Why would you wast your time doing that when the it basically a STI engine replaced the stock engine and buy a STI turbo and injectors with the STI intake manifold and tune it. Same stuff just some minor difference.
G3nX09 is offline   Reply With Quote
Old 01-20-2012, 09:37 PM   #11
Azlegacy
Member#: 279837
The sti 2.5 bottom end is what u want. It won't break like the legacy 2.5 turbo block.
Old 01-28-2013, 06:39 PM   #12
deoexmacchina
Member#: 174900
I would like to know also...
Cant find PHAT subi....
I dont want to pay STI insurance.
deoexmacchina is offline   Reply With Quote
Old 01-28-2013, 09:17 PM   #13
verendia
Member#: 54550
1995 LX
graphite grey
My sister has done the swap 05 lgt 5eat with 04 sti motor. You have to extend a few wires but other wise it runs fine. Running on stock lgt ecu
verendia is offline   Reply With Quote
Old 01-29-2013, 03:20 PM   #14
PDAWG
Member#: 66813
2000 Legacy GT
PHATsubi's crazy project -
HTML Code:
http://forums.nasioc.com/forums/showthread.php?t=2198454
PDAWG is offline   Reply With Quote
Old 01-31-2013, 05:22 PM   #15
rougeben83
Member#: 115154
2005 Outback XT
White on grey
first off phatsuby has a 3rd gen car 00-04. You're talking about an 05 LGT, which is already turbocharged to begin with. Why do you want to do an STI motor and what are you goals?
rougeben83 is offline   Reply With Quote
Old 01-31-2013, 05:26 PM   #16
holyjoetart
Member#: 232986
07 Legacy GT
The 05 and 06 legacy gt short block is the same as an Sti SB. The heads are the big difference between the legacy and the Sti. The are a bunch of threads on legacygt.com about doing a Sti manifold and intercooler swap. Kind of a waste now that they make aftermarket turbos and TMICs for the legacy.
holyjoetart is offline   Reply With Quote
Old 02-05-2013, 07:24 PM   #17
Reaper13
Member#: 346053
2005 Legacy 2.5i lim
What about 05 legacy 2.5 i. I'm interested in doing an sti swap what year would be best to swap with?
Reaper13 is offline   Reply With Quote
Old 02-09-2013, 11:29 AM   #18
PhotoREX
Member#: 180193
04 Forester XT
Same here^^^
PhotoREX is offline   Reply With Quote
Old 02-11-2013, 01:19 AM   #19
ArtClassShank
Member#: 338180
Sell your car and buy a Legacy GT.
ArtClassShank is offline   Reply With Quote
Old 02-12-2013, 05:58 PM   #20
benena
Member#: 335379
that is so dope.
benena is offline   Reply With Quote
Old 02-16-2013, 10:36 AM   #21
MichaelBrown
Member#: 347228
2005 Outback XT
Silver/Grey Bitone
A friend of mine did something similar to this. He bought a 2002 Impreza RS really cheap, bought a wrecked 05+ STI for cheap. Combined them, and he had a 2002 STi for half the price of a 05+ STI.
MichaelBrown is offline   Reply With Quote
Old 02-16-2013, 12:53 PM   #22
kirbykirb
Member#: 183596
2005 WRX/9-2x
Great idea, but make sure he does suspension upgrades, steeringn rack, etc
Old 03-13-2013, 02:27 AM   #23
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Heads,cams, valves, valve covers, plugs, wires, coils, oilpan,oil pump, waterpump, timingbelt, timing belt covers,exaust mainifolds, mid-pipe, up pipe, alternator, p/s pump,water neck, thermosatst and if I'm not mistaken the injectors are yellowtop side feed sti injectors... all these are the same as the Sti down to the tensioners.
(Same part numbers)
The diffrences that I have gathered are, diffrent up pipe, turbo, wastegate, intercooler,intake manifold, the airfilter intake, maybe the tgv's(but I don't think so) throttle body and some cooling and vacum line routeing under the intake, but the wiring harness on your lgt/obxt should be the same.
The fuel rail might be a little diffirent, I do recall reading something about that, but I'm not positive. I tore down my obxt engine today, its all pretty fresh in my head.
The intake on the lgt/obxt it plastic, logicly this means it will retain less heat, and since its moldedplastic my bet is it thinner and capable of flowing better than a sti intake. The Sti intercooler won't fit under the hood of a lgt/obxt with out modifing you scoop. All and all unless you just want to pop your hood and see Sti on your intercooler and a red intake, its really not worth all the work. With a d/p, turbo, intercooler and a tune you would be 300ish hp just as easyy as the "Sti engine"
Sneeky Pete is offline   Reply With Quote
Old 03-17-2013, 01:05 PM   #24
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
Actually the 255 and 257 are not that similar. The only thing that is the same is the block itself. ervything is pretty much different. Different heads and internals. Sti top mount does fit under a LGT hood. You need to swap everything over to make it work . Its more work than just swapping out the TMIC but it does fit with no modification to the actual hood
PMDSOA is offline   Reply With Quote
Old 03-20-2013, 09:00 PM   #25
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
While I could be wrong about a few things in the heads...like cams degree and maybe I'm wrong about the harness, but I promise with out a doubt that shortblock in this leg gt and outback xt are identical. I'm holding a new rotating assembly out of a sti short block and my rotating assembly out of my xt and every thing is identical...piston sizes, journal sizes, numbers on pistons rods and crank all match.
05 & up Legacy GT wheel swap to 97 Legacy GT??? O.D.P. Tire & Wheel 0 10-17-2010 08:43 AM
FS: 05 Legacy GT STi Front Strut Tower Brace Baccata Suspension/Brakes/Handling 0 05-31-2009 03:54 PM
05+ Legacy GT Transmission Swap Hurley 2.5 WRS Subaru Conversions 7 07-31-2008 12:37 PM
05 Legacy GT trunk lid swap? johnawd Rocky Mountains Impreza Club Forum -- RMIC 0 09-23-2006 05:32 PM
Simple 05 legacy GT question...Top mount swap.. M32WRXin3seconds Legacy Forum 9 09-23-2005 01:45 AM
