Notices
Old 02-15-2013, 03:21 PM   #1
RJSoobs251
Member#: 345206
2012 Impreza 2.0 Lim
Default 2012 Impreza Automatic Window
So...today my automatic driver window decided to stop working on my 2012 Subaru Impreza Limited. I still goes up and down but the automatic roll down and up has stopped working. Has anyone had this issue? Any quick fixes? Should I just bring it in? Thx
RJSoobs251 is offline   Reply With Quote
Old 02-15-2013, 03:52 PM   #2
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Check the owner's manual for how to enable the auto window feature; perhaps yours got reset somehow. I need to perform this procedure every time I disconnect/reconnect the battery to do something, but I can't remember the process for resetting it.
Old 02-15-2013, 04:38 PM   #3
RJSoobs251
Member#: 345206
Got it thank you. Sorry I am still new to the car.
Old 02-16-2013, 08:39 AM   #4
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
If the battery was disconnected, it needs reset. Check the manual to be sure but I think you roll the glass half way down, roll it up and hold the switch for a couple of seconds, then roll it down all the way.
As previously noted, it is mentioned in the owners manual.
John
Old 02-16-2013, 02:55 PM   #5
LGA2011
Member#: 321173
Page 2-20
Initialize the power window using the
following procedure to reactivate these
functions.
1. Close the driverís door.
2. Turn the ignition switch to the ďONĒ
position.
3. Open the driverís side window halfway
by pushing down the power window
switch.
4. Pull up the power window switch and
close the window completely. Continue
pulling up the switch for approximately 1
second after the window is closed completely.
5. Open the driverís side window completely
by fully pushing down the power
windows switch.
LGA2011 is offline   Reply With Quote
