Old 02-13-2013, 09:51 AM   #1
shad0vvfax
Member#: 337163
2002 Subaru WRX
Default 5 speed, what years work...
What year WRXs can I take a trans from that would be a direct swap for my 02 WRX 5speed POS. My gears broke amongst other things.
shad0vvfax is offline   Reply With Quote
Old 02-13-2013, 10:15 AM   #2
suby.ej20wrx
Member#: 218242
2006 STI
I believe any 02-07 wrx 5 speed will be a direct replacement. With that said the newer the trans the stronger the gears are. For example a 05 wrx trans will have stronger gears than a 02 wrx trans.
suby.ej20wrx is offline   Reply With Quote
Old 02-13-2013, 10:36 AM   #3
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
02 and 03 I believe will swap in with your existing axles. 04 and 05 use different axles, you can still swap it but you'll need the matching axles. There are other differences on the newer models, 06 forward, that can be overcome to install on your 02. That said, you posted in the wrong section, there is a transmission dedicated section, search there.
Old 02-13-2013, 10:36 AM   #4
projectQWKSLVR
Member#: 285270
03 WRX
^WRONG!
Both of you need to read the TRANSMISSION FAQ's!
Hint: All 5MT's are NOT created equally! Might want to learn about the different center diff ratio.
Happy reading!
Edit: you beat me rodman :-/
projectQWKSLVR is offline   Reply With Quote
Old 02-13-2013, 11:48 AM   #5
wrxracer519
Member#: 149890
09 Forester
Green
the 02-05 are swappable. The 06-07 needs more work. Also, the axle stubs change mid 03.
Read the FAQ as there a bunch of little things and if you are in there, why not address other issues
wrxracer519 is offline   Reply With Quote
Old 02-14-2013, 12:33 AM   #6
FULL
STOP
dont listen to any of the idiots here
you want STRAIGHT SWAP ya want any 02-05 wrx trans....that is IT
the axles...taht is another story.....the mid 03 and up cars used differnt axles than the early bugeyes so if ya get one of those ya need the matching axles
Old 02-14-2013, 07:08 PM   #7
shad0vvfax
Member#: 337163
2002 Subaru WRX
Getting a used 05 trans with 78k miles tomorrow and new axles so all should be well soon.
Old 02-17-2013, 08:38 AM   #8
shad0vvfax
Member#: 337163
2002 Subaru WRX
Is there any major difference as far as internals on the 05 as opposed to the 02 besides wider gears?
Old 02-18-2013, 11:39 PM   #9
dont think so...no
