Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
View Poll Results: Your break-in style and oil consumption (OC)
Easy - Little to no OC 5 4.63%
Easy - Unusual OC 3 2.78%
Recommended - Little to no OC 68 62.96%
Recommended - Unusual 16 14.81%
Hard - Little to no OC 14 12.96%
Hard - Unusual OC 2 1.85%
Voters: 108. You may not vote on this poll
Old 02-04-2013, 08:36 AM   #251
79letour
Member#: 302570
2013 XV
DGM!
I highly doubt anyone who was hard on yhe break-in is gonna go on a forum and post x amount of posts to vote that they were not following the manual during break-in and are having oil consumption.
Old 02-04-2013, 08:49 AM   #252
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Originally Posted by nels0300 View Post
I don't know why the Subaru would be more sensitive to break in style than any of my other cars.
Did any of your other cars use 0W-20 oil?
Old 02-04-2013, 08:53 AM   #253
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Well, there's hard break-in (which I don't recommend), easy break-in (which I also don't recommend), and then there's the recommended break-in (which I DO recommend).
As I said, I would commonly wind my engine up to 4k RPM, at 80% throttle, during the first 1k miles. I don't consider this a hard break-in, but it's not a gentle break-in process either. My friend with the oil-burning Forester probably shifted his car at a gentle 2.5k RPM, and accelerated very gingerly up to 2.5k. This to me is an overly-gentle break-in, and might be the root cause of his problems.
Old 02-04-2013, 05:06 PM   #254
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
We pretty much just drove ours like we normally would from the get go (except no cruise control). No consumption so far.
saabarupp is offline   Reply With Quote
Old 02-04-2013, 05:21 PM   #255
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Sounds fine, since driving like you normally would probably wasn't babying it, or abusing it.
Old 02-04-2013, 07:17 PM   #256
nels0300
Member#: 331332
2014 Camry SE V6
No, and I don't think it's relevant. If this engine requires a special break in procedure because of the oil weight, then Subaru would do it at the factory. This isn't a hand built race engine.
I wasn't overly gentle, nor did I abuse the car during break in.
The theory that the break in is the cause of oil consumption is exactly that, a theory.
With the millions of cars built and sold each year broken in thousands of different ways, you'd think there'd be oil consumption threads for all makes and models. But there aren't. There are for vehicles with FB engines though...
The only people who know the cause are Subaru engineers, and I'm not even sure they know.
nels0300 is offline   Reply With Quote
Old 02-05-2013, 08:44 AM   #257
79letour
Member#: 302570
2013 XV
DGM!
I think they fired the engineers to make room for more MARKETING people.
Old 02-11-2013, 12:06 PM   #258
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by subypete View Post
Did they find anything in your old engine that caused the oil consumption? How is the new engine working out for you so far?
Subaru said it was a problem with the piston rings.
So far the new engine is great! 2500 km and no oil burned as of yet. I'm keeping an eye on the dip stick but everything seems to be in proper working order.
gregorz4 is online now   Reply With Quote
Old 02-11-2013, 01:55 PM   #259
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
Thanks for the update gregorz4. I am happy to hear they replaced the engine.
Were problem with piston due to break in, bad batch of rings? Any details they have?
Are you breaking the new engine any different compared to the last engine?
subypete is offline   Reply With Quote
Old 02-11-2013, 03:28 PM   #260
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
That's great news! Thanks for the update. This pretty much confirms all the rumors and assumptions about the new low tension rings being the cause of the problems. I wonder if it was just a bad batch of rings, or if Subaru revised them at some point.
Old 02-12-2013, 08:57 AM   #261
79letour
Member#: 302570
2013 XV
DGM!
QC is pretty spotty, cause they have had this problem since the 2011 foresters came out.
Old 02-15-2013, 07:14 AM   #262
orndog
Member#: 34670
2013 No gears!
Saltine American
I am curious if the CVT doesn't compound the problem, seeing as Subaru's own break-in directions call for varying RPMs and the CVT insists that 2k is where it wants to live. I am constantly paddle down-shifting and giving it extra gas.
orndog is offline   Reply With Quote
Old 02-15-2013, 04:33 PM   #263
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
It had been awhile since I last Checked my oil level, So I checked just a moment ago.
I'm at 10,500 miles. 3K since last Oil change. With Fumoto Drain Valve in place.
Zero Oil Loss!!!
in another 2K I plan to take a sample for a UOA. The results of which will let me know if going to 15k (7.5k OCI) will be advisable.
ZionZR2 is offline   Reply With Quote
Old 02-15-2013, 04:38 PM   #264
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Zero Oil Loss!!!
what oil?
Old 02-16-2013, 09:36 PM   #265
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
Originally Posted by flyboy1100 View Post
what oil?
The Subaru Oil 0w20 performed by the dealership.
Old 02-18-2013, 01:45 AM   #266
stevehnm
Member#: 329526
2013 Impreza Spt cvt
Out west hardly anything is flat and level. There is always some small grade that makes the cvt adjust.
It would be nice if 6th gear could hold any kind of a grade. So far it will only do flat with no headwind.
Old 04-09-2013, 03:28 PM   #267
79letour
Member#: 302570
2013 XV
DGM!
Bump-
For folks who havent gotten a chance to vote.
Old 04-09-2013, 04:19 PM   #268
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i finally voted in this one... voted for "hard, little/none consumption" but at the same time I did a lot of highway and constantly changing the RPM. when accelerating i routinely brought it up to 4000rpm, and i ran my "break in" period through 1600 miles. (due to the amount of highway) I also did 2 redline passes when the car had less than 200miles, but otherwise i was under 4,000 for the entire breakin period
currently sitting at 18,300 miles on my car, current oil change has 4400 miles on it, and i am just down to the top "full" mark. every oil change i have done on my car, 5.3qts puts me about 3/16" over the full mark. so I am down about 6oz from what i have seen in the past to see exactly how much it will take to bring it back up from there.
Old 04-09-2013, 04:22 PM   #269
Zeeper
Member#: 299286
2017 Legacy Limited
Hey 79, I just reread my posts on this thread, and they say exactly what I thought I said, this poll is too small to be significant in any way, statistically.
Now you read what I wrote before, what did you think I said again?
Old 04-10-2013, 06:28 PM   #270
79letour
Member#: 302570
2013 XV
DGM!
I think you need a girlfriend or boyfriend or a hobby.
Old 04-13-2013, 04:28 PM   #271
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
More consumption data:
6.00 quarts in
5.22 quarts out
4771 miles
1 quart per 6117 miles.
These were easier miles in general than the last fill. Most of them were covered in fifth gear.
Old 06-01-2013, 08:48 PM   #272
spacedoc
Member#: 346930
I can't vote since I'm a noob and don't have 25 votes yet, but I wanted to add my data point to the noise. '13 Impreza w/CVT. Recommended break in (varied speeds, kept below 4k, although when I was on the freeway I would occasionally floor it in higher "gear" until revs got to 4k.) At 7200 miles I was about .4 qt low as measured by the dipstick (level was just above the halfway point between the two holes on the dipstick). Half a quart over 7200 miles seems not unusual to me.
spacedoc is offline   Reply With Quote
Old 06-01-2013, 08:59 PM   #273
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
You have 7200 miles on your car and haven't done your first oil change yet?
Old 06-18-2013, 10:28 AM   #274
cookcle
Member#: 306704
I was participating on a different 2012 oil consumption thread a few months ago, but I cant find it. Anyway, I reported on there I was consuming 1qt of oil every 1200-1500 miles. I was participating in an oil consumption test and I have finally completed it.
The dealership called me last week and said they have ordered me a new small block. Good and bad news I guess. Hopefully it will resolve this oil consumption issue, which I believe to be very serious. However...I am getting a bit worried about the repurcussions of having the engine swapped, I don't know anything about the dealers mechanics qualifications.
Any advice? Questions to ask the dealer about the mechanics doing the work? I plan to ask about extending the warranty.
cookcle is offline   Reply With Quote
Old 06-18-2013, 11:13 AM   #275
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Call me wildly optimistic, but I'm guessing that a dealership would assign their top mechanic(s) to a job as complex as a short block swap.
('11-'14) 2012 break-in period... which oil? carrathanatos Impreza Forum 10 05-16-2012 07:36 PM
Break-in oil consumption... does not seem normal to me... hoeser Built Motor Discussion 40 10-22-2011 05:13 PM
No Oil Consumption Ever, Then Massive Oil Consumption - Where to Start? This Is Not Mike Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 48 12-30-2010 09:18 PM
DO oil catch cans help with oil consumption? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-10-2005 02:57 AM
oil consumption and synthetic oil happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 06-18-2004 01:08 PM
