Old 08-03-2012, 12:50 PM   #1
-AspenSTi-
Member#: 164323
2005 STi
Default Still have to secure reverse lockout on short shifters? (kartboy ss)
I know this is a "look on your car and find out" kind of question, but getting under the car isnt real easy for me and my situation. But i searched around and most of the threads/answers are pretty dated, and i'm not sure if they apply anymore or not. When i installed my short shifter yesterday i didnt seem to see where the reverse lockout cable would be making contact with the driveline. Maybe its been "fixed" on kartboys end? The line looks to be the same as it was before i swapped out the shifter. Is the only way i can tell is to drive for a little bit and see if there is some wear on the cable itself? Need some pro tips here, thanks!
Last edited by -AspenSTi-; 08-03-2012 at 12:51 PM. Reason: cant spell no good, lol
-AspenSTi- is online now   Reply With Quote
Old 08-03-2012, 01:35 PM   #2
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
Yes you will need to do that with our shifter along with just about every other aftermarket shifter out there. Its an easy fix if you can at least get under the car. You will want to use the second zip tie and secure the reverse lockout cable to the shifter stay about mid way.
T
tom@kartboy is offline   Reply With Quote
Old 08-03-2012, 02:27 PM   #3
-AspenSTi-
Member#: 164323
2005 STi
Good to know, i will see what i can do to get it secured. I think i was looking in the wrong area (closer to the front where you have to pin the lockout thingy). Hopefully the 24 miles that will be on the cable before i get to look at it wont do too much damage...
Old 02-17-2013, 12:50 PM   #4
heavyD
Member#: 194216
2013 STI Sport-tech
T
Tom,
Bringing this back from the dead but can you do this without completely removing the heat shield? I would prefer to do this with the front on ramps rather than jacking up all four corners and getting under. I'm a noob to working on Subarus and right now I'm not clear on access to get that zip tie in to take up the cable slack.
heavyD is offline   Reply With Quote
Old 02-17-2013, 03:39 PM   #5
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
you should be able to. I can do it when the heat shields are still on the car. It all depends on how big your meat hooks are. Wear gloves. That stupid shield is sharp.
Old 02-17-2013, 06:07 PM   #6
heavyD
Member#: 194216
2013 STI Sport-tech
Cool. Thanks for the reply.
Old 02-18-2013, 08:22 AM   #7
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
Yes, you do need to zip tie it.
Yes, it is pretty easy to get to.
xluben is online now   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 09:41 PM.
