Old 01-17-2013, 10:52 PM   #101
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
Lol oh.then it's definitely worth it 😳
Old 01-18-2013, 08:31 AM   #102
Rememo
Member#: 340728
2013 Impreza 5-spd
Originally Posted by mrthompson View Post
but the xv hitch reciever actually uses that cut out.
That's just an illusion. For some reason that person has the cover removed from the cutout.
See here: http://www.subarupartsforyou.com/cp_...p?partid=22532
Rememo is offline   Reply With Quote
Old 01-18-2013, 08:45 AM   #103
Rememo
Member#: 340728
2013 Impreza 5-spd
Originally Posted by aeoporta View Post
Seriously that's a rip off the curt is 120 and any mechanic can just screw it on takes less than 30 mins Yikes
Interesting...
The one I posted earlier appears to be similar to the less expensive versions that are available from Hidden Hitch and Curt, although it's tough to be 100% sure using the available photo:
But this one is definitely something different, and it's the one I was interested in. What the heck is that round hole with the slot and small holes around it on left?
Old 01-18-2013, 01:01 PM   #104
Kharn
Member#: 306129
Probably the attachment point for a 7-pin trailer plug, so the trailer could use electric brakes and reverse lights.
Kharn is offline   Reply With Quote
Old 01-18-2013, 01:44 PM   #105
Rememo
Member#: 340728
2013 Impreza 5-spd
Ah yes... Good call.
Old 01-20-2013, 03:14 AM   #106
dromond56
Member#: 344172
2013 Impreza 2.0i
Originally Posted by chesterboy2003 View Post
End State pic with hitch attached.
Thanks for posting this write-up! I had been thinking about doing exactly the same thing. A friend of mine has had the Thule T2 hitch rack for years which he loves, but he urged me to consider a 2" hitch with one because he feels that th 1 1/4" mounted rack flexes and moves far too much with 2 bikes on it.
One question for those running an Impreza with a hitch-mounted rack like the Thule T2: how is the ground clearance? To get into my garage I have to back up a rather steep driveway and I am wondering how much of a pain it is going to be with the rack mounted or even just the hitch!
dromond56 is offline   Reply With Quote
Old 01-23-2013, 01:43 AM   #107
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Are there any hitches out there that do not require any modification to the frame of the car? I mean that including filing, drilling or any other kind of frame alteration. Thanks!
Dirt Bringer is offline   Reply With Quote
Old 01-23-2013, 08:38 AM   #108
Rememo
Member#: 340728
2013 Impreza 5-spd
When I put a hitch on my Focus, I refused to alter the body of the car to make the bolts fit, so I just removed a small amount of material from the bolt heads until I could squeeze them into the slots. I will do the same for the Impreza. Grinding the slot to enlarge it just invites more rust, unless you seal the edges of the slot after you enlarge it.
Old 01-23-2013, 09:16 AM   #109
aeoporta
Member#: 334126
Dark Gray Mettallic
The curt hitch I posted earlier in thread is bolted on so no alteration
Old 01-23-2013, 10:29 AM   #110
Dirt Bringer
Member#: 340297
Ice Silver
I thought that one required you to file the access hole in the frame to slide the bolt backplate in (or whatever its called)?
Old 01-23-2013, 01:14 PM   #111
Rpresa
Member#: 341172
2012 GP
I run that exact setup ( I have a 2012 2.0i, with a curt receiver, and the Thule T2. With the rack down and 2 bikes on it, I have to be careful going up and down driveways or into parking lots (I go slow and angled), but I haven't had a single issue yet with scraping.
Great rack by the way too, I've been using Thule stuff for 13 years and have been super happy with it all.
Rpresa is offline   Reply With Quote
Old 01-23-2013, 02:18 PM   #112
aeoporta
Member#: 334126
Dark Gray Mettallic
You do not need to file you just need to fish the bolts through and then tighten up everything
Old 02-07-2013, 02:53 PM   #113
Waterlogged
Member#: 294791
2012 Impreza Sport
Has anyone spec'ed out or tried the 2" Curt hitch for the XV? Appears to be identical other than the 2" receiver. It's a Curt 13135.
http://www.autoanything.com/towing/77A3874A3829800.aspx
Waterlogged is online now   Reply With Quote
Old 02-13-2013, 12:07 PM   #114
JimC
Member#: 346920
Default 2013 Impreza Hatchback needs 2" hitch
I've just bought a 2013 Impreza Hatchback, in fact, I haven't even picked it up yet.
I'm not looking to tow, but I do have accessories for my current vehicle that fit a 2" hitch.
Any ideas what I can do to put a 2" hitch on my new Impreza? All I've found so far are 1.25"
Jim
JimC is offline   Reply With Quote
Old 02-18-2013, 12:11 PM   #115
waja
Member#: 342440
2013 Impreza 5dr Ltd
Satin Pearl White
Jim
The Curt 13135 in the post above yours could be the one you want. Hard to tell if it has the needed clearances. Are the XV and Impreza muffler and hangers the same?
The OEM tow hitch for the XV is installed by removing the original bumper and sliding additional supports into the frame tube. If you don't want to enlarge the holes on the bottom, you could take the long route and send the bolts through here when installing the Curt hitch.
waja is offline   Reply With Quote
Old 02-22-2013, 07:31 PM   #116
Blur125
Member#: 88514
2010 Outlander XLS
Brown Metallic
Anyone towed a 12'-16' aluminum boat with their '12 Impreza? Just curious to hear your experience with that, as I am boat shopping but lack a truck. Just my trusty hitchless Subi...
Blur125 is offline   Reply With Quote
Old 02-23-2013, 06:16 PM   #117
subiTWO
Member#: 273054
2012 Impreza CVT HB
I towed a 16' side-console w/25hp motor with a honda crx. Towed it just fine...
subiTWO is offline   Reply With Quote
Old 03-05-2013, 10:29 AM   #118
jd0101
Member#: 294383
Default XV Hitch on a Impreza Sport
So I've had my XV hitch on my Impreza Sport for a bit, just an update for anyone interested and a related request for help. The hitch is great so far, surprisingly it has yet to bottom out even though it looks quite low.
Unfortunately the dealership attempted to install the XV wiring harness but said they could not do it, something about 5 pin vs. 4 pin. I have to wonder why it can't work since it is plug and play for the XV. Anyone have any suggestions...?
jd
jd0101 is offline   Reply With Quote
Old 03-15-2013, 08:45 PM   #119
gnanni
Member#: 350309
2012 Impreza
So was there a resolution to this?
gnanni is offline   Reply With Quote
Old 03-15-2013, 08:46 PM   #120
gnanni
Member#: 350309
2012 Impreza
Was there a resolution to this?
Old 03-18-2013, 11:28 AM   #121
jd0101
Member#: 294383
The dealer gave me the car back and said I was "all set". It was daytime and I drove off assuming all was well. When it was dark later on I turned on my headlights and got a lot of the idiot lights on the dash turning on and off at random including, hill hold assist light stuck on, cruise control on and off randomly (light only), traction control light, etc
Went back the next day and the dealer disconnected everything and said it was backfeeding and blowing fuses.
The XV hitch fits and looks great, but I do not have a wiring solution yet...
Old 03-19-2013, 11:24 AM   #122
waja
Member#: 342440
Satin Pearl White
You need to install an isolating wiring harness. Check out http://www.etrailer.com/Custom-Fit-V...eid=2013308406
Old 03-21-2013, 03:03 AM   #123
basara808
Member#: 262588
2012 Impreza 5Dr CVT
Default pics
jd
Do you have any pictures for this? I might want to go this route too. However, I see that you still need to trim the bumper for this.
basara808 is offline   Reply With Quote
Old 03-23-2013, 10:05 PM   #124
waja
Member#: 342440
Satin Pearl White
Old 03-23-2013, 10:21 PM   #125
aeoporta
Member#: 334126
Dark Gray Mettallic
Overpriced and weights more than a curt
2012 Subaru Impreza Sport trailer hitch? mckinnon99879 Interior & Exterior Modification 7 06-15-2012 09:17 AM
2012 Volkswagen Passat 3.6 SEL vs. 2011 Honda Accord EX-L V6, 2012 Hyundai Sonata 2.0 AVANTI R5 Non-Subaru News & Rumors 2 09-12-2011 09:02 AM
'08 Impreza 2.5i 4d Trailer Hitch Zell Interior & Exterior Modification 2 12-19-2010 07:59 PM
Providence: FS Impreza 93-06+ Class 1 Trailer Hitch / 2 Bike rack psyber_0ptix NESIC Private Classifieds 8 09-10-2006 06:03 PM
