Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Closed Thread
Old 02-11-2013, 08:14 AM   #1026
ScoobyDoo87
Member#: 346113
2012 WRX Limited
damn i want one! looks sick
ScoobyDoo87 is offline
Old 02-11-2013, 08:38 AM   #1027
Wrexflex
Member#: 326301
2012 WRX LR - Sold
2015 Forester Premium CBS
Juts did mine over the weekend and it's awesome. However, I did reprogram the car for the correct code on the new remote and everything chimed and beeped as it was supposed to if it was done right, but my remote doesn't work. I'm thinking maybe when I got it the battery was dead in it or something? So now I have to take it apart to see.... unless anyone has any suggestions?
Wrexflex is offline
Old 02-11-2013, 09:35 AM   #1028
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The chime indicates that you programmed a code to the car. Not necessarily that it was the correct code for the remote you have. There is also the possibility that the remote is non compatible or non working. Where did you get the remote?
xluben is offline
Old 02-14-2013, 01:29 PM   #1029
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
The battery for the remote that came with my car (2012 STi) was dead within 7 months. It was my spare, so I never used it.
OakleyWRX is offline
Old 02-14-2013, 02:48 PM   #1030
Wrexflex
Member#: 326301
2012 WRX LR - Sold
My buddy did this mod awhile back and bought his off some vendor on ebay, so he got me one from the same guy. I'm going to just open it back up and check the battery/code for the remote and make sure that I did indeed use the right code. So it should be compatible because his worked, assuming the seller's supply is the same.
Wrexflex is offline
Old 02-14-2013, 03:18 PM   #1031
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Most sellers get junked keys/spare parts and put them together to sell. It's a complete crap shoot on eBay. I have gotten so many mislisted or non working ones that I now only get brand new ones from the dealer.
xluben is offline
Old 02-14-2013, 04:25 PM   #1032
BrendanTheGreat408
Member#: 271207
+1 for Xluben, my key works perfectly and he was a lot of help. highly recommended!
BrendanTheGreat408 is offline
Old 02-16-2013, 02:56 PM   #1033
Wrexflex
Member#: 326301
2012 WRX LR - Sold
Pics of my remote that doesn't seem to be working.... I've checked the battery - it's good at 3V, programmed it to the number on the remote, so I'm not sure of the problem. The battery says on it CR1620 3V, which is what it says it needs.
Wrexflex is offline
Old 02-16-2013, 04:13 PM   #1034
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
As I said in the e-mail, it's probably the wrong remote. It's impossible to tell what you're going to get when you go through eBay. I have gone to purchasing all of my remotes directly from the dealer, because there are just way too many incorrect ones when you go used.
xluben is offline
Old 02-16-2013, 09:59 PM   #1035
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Looks like it should be the right remote but you never know when buying used. I'd try a new battery if you can, sometimes measuring voltage with no load via a DVM isn't going to tell you if it is done.
Also it sounds like you have the programming right, but always good make sure. The door locks will activate lock/unlock at the end of the process, if they don't you didn't get it, you'll still get beeping either way.
Power6 is offline
Old 02-17-2013, 10:15 AM   #1036
Wrexflex
Member#: 326301
2012 WRX LR - Sold
I'm going to try to re-program it today and see what happens. I have noticed that it hasn't lock/unlocked after I have done the programming both times so I need to figure out what the problem is there.
Wrexflex is offline
Old 02-17-2013, 11:03 AM   #1037
Wrexflex
Member#: 326301
2012 WRX LR - Sold
Problem found.
I would suggest updating the OP in step 3 for programming.
3. Perform the following steps within 45 seconds.
(1) Open and close the driver’s door once.
(2) Insert the key into the ignition switch, then turn it from the “LOCK” position to the “ON” position 10 times within 10 seconds (must be done very quickly).
NOTE: When you complete step (2), an electronic tone will sound once.
Once you turn it from Lock to ON 10 times, I had to take if off of ON to get the little chime to start beeping, then just put it back to ON. All the other times I programmed it I guess it wasn't in the ON position so it couldn't do the autolock feature at the end and I guess thats what threw everything off. Maybe this is trivial for some people, but I am not a programmer so I didn't know this. Luckily I found that on like the 4th page that it had to be in the ON position, it would just make it easier if that was in the OP.
Otherwise, now I'm happy and it works great. My battery was good, the remote works, just user error.
Wrexflex is offline
Old 02-17-2013, 11:58 PM   #1038
Whap Whap
Member#: 281549
found these on ebay, good for a 2013 wrx swap?
http://www.ebay.com/itm/360574318292...=p5197.c0.m619
Whap Whap is offline
Old 02-18-2013, 12:04 AM   #1039
yambeezy23
Member#: 347347
2013 Wrx Hatchback
This is awesome, can't wait to try this. Before my Wrx I had a 2013 legacy but sadly got in a wreck with a brand new driver (16 year old). All his fault not mine by the way!
Planning to use the key to my 2013 legacy as the swap, hope all goes well..
yambeezy23 is offline
Old 02-18-2013, 06:58 AM   #1040
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Theoretically yes, but if you read the thread, you'll note that xluben is now buying all of his legacy keys through the dealerships. It's the only way you'll get the exact key you need.
Old 02-18-2013, 10:03 AM   #1041
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Be very careful with ebay used keys ESPECIALLY if they have new blades. The ebay sellers assume that the FCC ID means compatible but it doesn't, when the key doesn't work you have little proof that they sold you the wrong remote...
That key could be a 2012 impreza remote with a high security blade.
Power6 is offline
Old 02-18-2013, 10:11 AM   #1042
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep, especially with a photo of just one key (and it is probably just a photo they pulled off the web) and multiple keys for sale. It's really just a random shot if you'll get the right thing. After numerous issues I have found that it's just not worth it, and get all my Legacy remotes new from the dealer.
xluben is offline
Old 02-18-2013, 07:19 PM   #1043
yambeezy23
Member#: 347347
2013 Wrx Hatchback
So what I have been reading.. Is it okay to use a 2013 legacy key?
Just wanna confirm
Old 02-18-2013, 07:34 PM   #1044
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Just buy the key using the part number and FCCID. Don't pay attn to the year.
Old 02-18-2013, 08:52 PM   #1045
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Just wanna confirm
Yeah that should be good. Since you have the key, go ahead and give it a try programming right now and see if it works!
He already had the key ;-)
Power6 is offline
Old 02-20-2013, 12:20 AM   #1046
TheChosen1
Member#: 255725
Chapter/Region: PRSIC
Pearl White
I'm happy to PM my contact info. I just dint want to post my email and get spammed.
Hi, just found this article and you seem to be "the man" on this flipping key thing. How does it work? I would like to do this for my 2011 wrx... Do i send you my key? How does it work?
TheChosen1 is offline
Old 02-20-2013, 01:21 AM   #1047
yambeezy23
Member#: 347347
2013 Wrx Hatchback
Look at the first page, it shows you which parts you need and the step by step tutorial.
Old 02-20-2013, 01:37 AM   #1048
silverbullet830
Member#: 155658
2010 WRX Sedan
ok so i've read at least 7 or 8 pages of this thread hoping to find an answer and haven't yet. How do I do this mod for my 2010 wrx? I know the key will work I'm just wondering about the fob being programmed to my car. The link in the first post doesn't go to a thread anymore.
silverbullet830 is offline
Old 02-20-2013, 06:33 AM   #1049
DirknJirkn13
Member#: 249696
2010 Outback Sport
Yes it does.
DirknJirkn13 is offline
Old 02-20-2013, 08:40 AM   #1050
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I responded back to your e-mail with a link to the parts.
The link works for me. You need to swap in the remote module inside the car, as well as all new remotes.
xluben is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
