Old 02-18-2013, 05:46 PM   #1
flyguyeddy
Member#: 236695
1995 impreza outback
dark green/greyish
Default '10 wrx transmission with no speedo drive?!
ok i am buying this trans from a junkyard for a steal and i want to know what do to about this little problem.
[IMG]http://i16.photobucket.com/albums/b5/Flyguyeddy/subaru%20****/P1010005_zps6b4283e1.jpg[/IMG]
what do i do about this?! change that gear spool out? seems like my only option if i want an oe speedo drive.
flyguyeddy is offline   Reply With Quote
Old 02-18-2013, 07:43 PM   #2
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
Photo not working.
08+ did away from the speedo gear on the front diff to drive a specific VSS sensor. Vehicle speed duties was taken up by the ABS wheel speed sensors. Since I can only assume you are planning this for your 1995 Impreza, it gets you to the "now what" issue. Have you already purchased this 5MT?
1)Research DCCDpro's VSS device.
2)Grafting a physical VSS onto that 5MT is not practical. Look for another 5MT.
JarHarms is offline   Reply With Quote
Old 02-18-2013, 08:24 PM   #3
flyguyeddy
Member#: 236695
dark green/greyish
Sounds like a GPS speedometer is in my future.
