Old 09-12-2010, 02:04 PM   #1
Donutz
Member#: 148803
11 WRX 4dr
96 Impreza 3.6RS (EZ36R)
Default The 42Autosports 3.0RS (EZ30D inside)
Just wanted to post up for my fellow nasioc-ers stage one of my ongoing Impreza build. The build started off as an STi swap for my 2007 2.5i but when I drove the Cannonball GTR (http://www.gtroc.us/forums/index.php...&mode=threaded) that was campaigned during the 2009 and 2010 One Lap of America, I knew I'd be shooting for a power levels that would not be reliable on a four cylinder powerplant. That is how my 3.0L Impreza came to be.
The powerplant in question is the EZ30D out of the 2001-2004 Outback L.L. Bean. The current motor is a "get the car up and running deal" it's a bit high mileage at 17XXXX miles but it still runs like a champ, putting down 175 at the wheels on a Dyno Dynamics with a full exhaust, intake and Haltech stand alone (they were rated at 212 crank from factory, and that 175 equates to about 200 at the wheels on a DynoJet or about 250 at the crank).
The reason for a slightly higher mileage motor is that the timing chain EZ30s are built like tanks and they don't suffer much from aging (not to mention it has been puttering around for the last 9 years (donor car was an 01 Outback LL Bean). Though this is only a temporary solution, we're going to acquire a core motor (once a six speed makes it way into the car of course) and build it with forged pistons and rods (the 2.0L WRX pistons will fit in the EZ30) and do a twin turbo setup, though that won't be coming to fruition for another year(ish).
Now for the pics and dyno video:
the car in question
The motor (a little dirty, it got cleaned up some before it went into the car)
The motor in the car at the Charlotte Auto Fair
The dyno video
Dyno plot
I'll continue updating this thread with new videos/status updates, the car's already been out to an autocross and did pretty well, compared to a VF52'd WRX it ran slightly quicker times (prep levels were similar, the 3.0 may have had better brakes/wider rubber) and it felt as if it had the peak torque of the 52'd car all over the rev band.
Donutz is offline   Reply With Quote
Old 09-12-2010, 10:53 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by Donutz View Post
The powerplant in question is the EZ30D out of the 2001-2004 Outback L.L. Bean. The current motor is a "get the car up and running deal" it's a bit high mileage at 17XXXX miles but it still runs like a champ, putting down 175 at the wheels on a Dyno Dynamics with a full exhaust, intake and Haltech stand alone...
That's pretty impressive! When you say "full exhaust", what exactly are you guys running? I see on the dyno graph that it says OBX header, so I get that, but what about the rest. Is the exhaust 2.5" all the way back or bigger than that?
What sort of tweaks to the tuning have you done that gets that much more power out of the engine? Or do you think it's just a matter of letting it breathe better with the intake and exhaust?
Are you using the variable intake plenum at all? I'd be curious to see what (if any) difference it makes in the torque curve using it vs. not using it.
... build it with forged pistons and rods (the 2.0L WRX pistons will fit in the EZ30) ...
I think you might want to second check that. There's a reason Perrin, PDX, etc had to have pistons made.
Pat Olsen
Old 09-13-2010, 04:35 PM   #3
Dodik
Member#: 122609
2002 Outback H6 BE
82 GS750E
very interesting results, can you tell more about the exhaust very interested as i have 02 H6 mostly stock just for your reference stock motor in stock drivetrain (4eat) put out 156whp and 160 torque. which transmission are you using right now?
Dodik is offline   Reply With Quote
Old 09-15-2010, 02:25 AM   #4
Donutz
Member#: 148803
11 WRX 4dr
1) Ya not exactly sure if the pistons are interchangeable, just one little rumor deal we heard though we're gonna play with things before it's settled so we're gonna look into it (play = try mixing 3.6 and 3.0 stuff lol).
2) The transmission is the 2.5i stock 5 speed, albeit with an Exedy Stage 1 organic meant for a WRX
3) The wrx is the OBX headers mated to a 3" SPT catback (the bosal unit) that had the flange rotated to mate to the OBX headers. The car is also running a standalone which is where some of the power gains are (along with it being catless etc etc).
As far as what's being intake wise used its just the stock H6 motor and intake plenum (with vibrant piping and an aem dryflow on it, short ram-esque).
Old 09-15-2010, 10:43 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The bore on the EZ30 is not the same as the EJ20 (89.2mm vs. 92mm). Unless you can cram 3mm larger pistons in there, it ain't gonna work. The EZ30 has no commonalities with the EJ engines, AFAIK (unlike the EG33, which shared a number of parts with the EJ22). The EZ36 is also very different from the EZ30, particularly the first gen non-AVCS version of the EZ30.
Gotcha.
Right, I could see that in the pictures. My question is whether or not you're using the variable intake plenum IRIS valve, which splits the plenum of the intake manifold in half when it's shut. The SVX intake manifold has the same thing. It's supposed to broaden the torque curve. I believe it's supposed to be shut at low RPM, splitting the intake manifold in two so you have two smaller plenums and improving low RPM torque and response, then open at ~4000rpm to enlarge the plenum for better top end. Your torque jumps pretty good at ~4000rpm - I wonder if you could beef up the <4000rpm curve if the IRIS valve was used.
Pat
Old 09-17-2010, 06:49 AM   #6
42Autosports
Member#: 257297
2002 H6
Pat,
Good questions about the setup. About the pistons, you are correct about the 2L pistons - there are some other options out there that we are looking at for the build. We are currently looking for a good 'core' motor for the build. At this time, it's not a huge rush, as Donutz has to get a 6spd in the car first.
As for the IRIS valve, currently it is not in operation, although that's the next thing to be tested. We also need to do some intake testing, as the stock torque box and filter on a stick were just the quick and easy solution to get the car up and running.
Glad to see you still have your Legacy GT, I miss my Luxobarge!
Steven
42Autosports is offline   Reply With Quote
Old 09-17-2010, 03:03 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Cool. If you get any dyno comparison graphs, post 'em up! I'm curious to see what a difference it makes.
Pat
Old 02-03-2012, 07:17 PM   #8
aesthetect
Member#: 89051
2001 GC6
bump
gettin interested in ez30ds... curious what all you got out of it while still NA
aesthetect is offline   Reply With Quote
Old 02-27-2012, 02:04 PM   #9
Donutz
Member#: 148803
11 WRX 4dr
funny you should ask we're just finishing up the next iteration of the build with a built (or near built) EZ30 with factory 5 over pistons, Supertech valve springs, a valve job and some decking. We'll post with results when we get them, the car's going to be stout....(and a rocketship at 2600 lbs)
you can also check us out on facebook: www.facebook.com/42autosports
Old 02-27-2012, 07:03 PM   #10
aesthetect
Member#: 89051
2001 GC6
awesome thats just what i was hoping to hear -- bumping compression at all? any thoughts on cam options for the EZ30D? what about headers?
Old 02-18-2013, 04:19 AM   #11
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Hey, how hard was it to hook up the 5MT to the EZ30D? Was there any work involved custom-fitting, or did it bolt right up?
Basically, I'm thinking of doing a trans swap into my OB, and I wanted to know any pitfalls that may arise ahead of time.
Thanks.
TurboLag23 is offline   Reply With Quote
Old 02-18-2013, 11:08 AM   #12
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
nice job!
bigolrig is offline   Reply With Quote
Old 02-18-2013, 09:28 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
The 5MTs and 6MTs will bolt right up to the EZ engines.
Old 02-18-2013, 10:36 PM   #14
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Perfect, thanks!
Now time to save up some money! hahaha
Old 08-24-2013, 03:05 PM   #15
RallyGuy2k
Member#: 1146
Hmmm....anyone got ideas on this one? I can't get to the dealership until Monday to have them check it out.
The EZ30 runs great but when above around 4k it sputters at WOT and has a decrease in power...I can back off and it runs better/faster than WOT. Nothing coming from exhaust, no overheating, no codes...(other than the usual auto/manual tranny codes)
I had one of the techs drive it for 2 min and thought it might be the intake manifold's iris valve not opening...which would make sense. He didn't have time to dig in, but I checked it out at home...found it and checked the hoses and solenoid...checked connection, etc. I need to take a spin to see if it had any effect. However anyone know how to test that particular system?....or rather bypass it open to see if that's the problem?
Also it's running quite rich...when I blip the throttle to downshift it's popping quite a bit...exhaust is straight from obx headers to 3" wrx spec SPT exhaust.
RallyGuy2k is offline   Reply With Quote
Old 08-24-2013, 04:12 PM   #16
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
How's the MAF look ? Fuel filter been replaced lately ? And last but not least how about spark plug condition ?
04wrxhart is offline   Reply With Quote
Old 08-25-2013, 10:33 AM   #17
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'm going to guess it's the line from the manifold to the FPR. remember on N/A engines it provides suction. disconnecting it results in MORE fuel. that may explain the richness and poor firing.
Old 08-25-2013, 11:55 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I wouldn't think the IRIS valve being out of position would make it that unhappy. You might be able to reach under the front of the intake manifold to see if you can manually shift the IRIS back and forth - that might tell you if it feels like it's sticking or something.
No MAF in RallyGuy2K's setup (or Donutz's setup, for that matter). Checking the spark plugs to confirm the car is running rich is a good idea.
I'd be checking for vacuum leaks - a split line somewhere, or a line that isn't tight on whatever nipple it attaches to. Subaru loves to have vacuum lines that just slip onto a small diameter nipple that doesn't have any sort of lip on it, so it's easy for the hose to become loose.
Old 08-26-2013, 07:08 PM   #19
RallyGuy2k
Member#: 1146
Thanks for the input guys...I've played around with it but haven't gotten a chance to take it out...might take it for a spin in a few.
...one of the techs mentioned the iris...hell I still haven't found it yet. Patrick you meintioned reaching under the front of the mani....behind the alternator?...I'll check there.
No doubt about vacuum hoses...I've been checking them and will keep going.
This morning I programmed the xgauge codes for both A/F banks so I'll be able to see if I'm rich or lean.
Old 08-26-2013, 11:45 PM   #20
RallyGuy2k
Member#: 1146
So far both air/fuel banks look good. 14.7 for both on idle...when on throttle up above 4k or so they both go up to 11.2 to 11.7...hence the richness.
When downshifting using the motor to slow down it can run lean...ranging from 15 to 20 with no throttle.
I didn't get a chance to really let it wind out plus it was raining...but I believe the problem is better or partially solved...will know more tomorrow. Will drive it quite a bit tomorrow.
Old 08-27-2013, 12:38 AM   #21
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Like so:
The big gold thing is a vacuum actuator, which is triggered by the maroon-ish solenoid on the right. The actuator has that arm pointing towards the front of the car (straight down in the picture), which causes the IRIS (inside the intake manifold) to shift. There are 2 posts that protrude down from the bottom of the manifold, which limit the motion of the valve. You can see them in the picture below, too.
Here's the IRIS valve itself:
11.2 to 11.7 is a little rich, but not all that bad. A N/A car is probably best in the 12.5-13.0 range at WOT; when I've dyno'd my EJ25D in the past I didn't see any change in that range, so I left it at 12.5 just to be a little safer. Stock was richer than 10:1, so 11.2-11.7 isn't bad at all.
Old 08-27-2013, 07:45 AM   #22
vicious_fishes
Member#: 158864
2003 SOHC destroker
when you engine brake the ecu actually turns the injectors off IIRC, so don't worry about it going lean. the throttle is closed remember?
idle is what it should be, and above 4000rpm doesn't seem to be all that far off.
Old 08-27-2013, 10:58 AM   #23
RallyGuy2k
Member#: 1146
I just gave my engine a reach around.
LOL...I felt around...not much to do without popping the mani off. I've already checked the solenoid. Not much to see...wondering if I raise the RPMs above 4k if I'd be able to see/hear it activate. Might try before heading out.
Might run 12v to the solenoid to hear it click as well...these are not polarity sensitive am I right?
Thanks for the help guys.
Update:
Ran 12v to the solenoid and it works fine but noticed that one of the two hoses running to it was loose...might have been leaking. I cut the loose end off and reattached it...much tighter. Will check results on the road.
Old 11-26-2013, 09:56 PM   #24
95widbod
Member#: 307606
Default update
need an update on reolts as i am having the same issue and would rather not tare my stuff apart if i dont need to
95widbod is offline   Reply With Quote
Old 11-27-2013, 06:29 AM   #25
vicious_fishes
Member#: 158864
2003 SOHC destroker
so what the hell is this "iris" thing anyway?
Event: DriftWater 3.1 (Grip Inside) ProjektPhoto Mid Atlantic Impreza Club -- MAIC 15 09-07-2009 08:19 PM
3.0RS. Possible? UniqueTII Built Motor Discussion 5 03-15-2008 01:58 PM
Last day for 2002/3 Accessport (Reserve inside) Expatbrit Private 'For Sale' Classifieds 0 08-14-2005 10:25 AM
I keeps it old school, bitch! (browsing OT on Netscape 3.0...screenshots inside) Kaiser Off-Topic 15 07-06-2005 04:15 PM
The last 3 Get Fuzzy comics (funnAy inside) Spheris Off-Topic 3 05-08-2004 04:04 PM
