Old 01-19-2013, 05:57 AM   #3676
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
I am not sure if your pump is still work based on your post. You post mentioned change fittings etc. This won't be a problem as we have all the metric compression fitting available to suit the 2d.
If the pump is a problem, you can perhaps try this:
Aquamist is offline   Reply With Quote
Old 01-19-2013, 06:08 AM   #3677
shaman
Member#: 164259
Richard, can an HFS-6 Junction box be bought separately if broken or lost?
shaman is offline   Reply With Quote
Old 01-19-2013, 07:46 AM   #3678
Aquamist
NASIOC Manufacturer
Member#: 110029
I am not sure if the HFS-6 has a junction box. Please explain more.
Old 01-19-2013, 08:06 AM   #3679
shaman
Member#: 164259
Sorry, the box that all of the other connectors plug into. There are two, the flow control with FAV and flow sensor, and then the other "brain" that all of the CAT cables plug into.
The box in this pic
http://www.aquamist.co.uk/forum/gall...6/trimmers.gif
Also, how much would an extra gauge cost?
Old 01-19-2013, 04:50 PM   #3680
Aquamist
NASIOC Manufacturer
Member#: 110029
That is the controller. The controller circuit board is no longer available but we offer a repair service as we only have spares (electronic components).
You can check the gauge price on our new shop.
Old 01-19-2013, 05:38 PM   #3681
Aquamist
NASIOC Manufacturer
Member#: 110029
Originally Posted by climbhigh09 View Post
MOAR FUN! (not really). I've got a 2011 WRX and none of the diagrams I've seen online really key up with what I'm seeing on the back of my ECU.
I have the 09' and '11 ECU wiring diagrams from Subaru Tech and the 2009 HFS-6 diagram; here is what I've got for the translations:
( legend: my wire #- 2009 pin function 2011 pin HFS-6 harnes color)
A6 MAP D20 *blue
B19 IGN-SW C30 red
B27 MAP SW C34 pink (not using this right now)
D11 FUEL INJ1 A10 green
D27 F/S SW A33 white-brown
black/yellow unused
I have hybrid boost control... I'd like to, when the system is off or fail safe triggered, drop to waist gate pressure. Does this achieve that? Or do I need to use the optional output from the FCM?
Also, as long as I do not wire in the pink- I won't throw CELs or drop into limp mode, right?
I didn't see the last two paragraphs sorry.
On the HFS-6, you have three failsafe output options:
1. MBC ......... use the MAC valve option (from the FCM)
2. EBC ......... use the white and brown wire (yellow harness)
3. Factory limp-home mode ......... use the map switch output (pink wire of the yellow harness)
The #3 option will not work if the system has a power cut.
Old 01-20-2013, 03:51 AM   #3682
shaman
Member#: 164259
Would the replacement HFS3-v2 be able to run the HFS6 flow control box? Found half of an HFS-6 kit for sale, and I am trying to figure out how to finish it with the controller and guage.
Old 01-20-2013, 06:42 AM   #3683
Aquamist
NASIOC Manufacturer
Member#: 110029
It is most unusual item for sale, half a HFS-6!
The FCM module has the flow sensor decoder and valve driver built in compared to the HFS-3/4 with the two function built into the controller. The gauge
has also been improved over the HFS-6. The guage cable's RJ connector has also been changed to 10-position (v11) from 8-position (v10).
I think is would be better if you can get a used HFS3-v2 system rather try to marry up two systems together. It has zero resale value. I will be pull my hair out if you decided to pass the hybrid system onto the next guy.
I have given a "yes" advice before and regretted it.
Old 01-20-2013, 07:27 AM   #3684
shaman
Member#: 164259
I was thinking about picking it up and keeping the pump as a backup, posting up the FCM and wiring as spares. You don't want me to use the race pump stuff so I am looking at other stuff.
I have contacted the seller to see if the controller was found, but haven't heard back. Overseas and all communication takes time. You know what I mean.
Old 01-20-2013, 08:07 AM   #3685
Aquamist
NASIOC Manufacturer
Member#: 110029
I am amazed that you are so familiar of the aquamist systems made over the years.
Once you have located the controller, send it back to me if it is not a v3. We still have electronic components to upgrade it. Make 100% sure the cable of the FCM is not cut as we cannot repair/extend a cut cable from 100% water proof.
Time lag is a problem for me too.
Old 01-24-2013, 10:00 PM   #3686
shaman
Member#: 164259
It got sold before the guy got ahold of me. Oh well, the accumulator would have been nice to have, and the Spec C tank would have probably sold for what they wanted for the whole lot.
Old 01-25-2013, 02:59 PM   #3687
Aquamist
NASIOC Manufacturer
Member#: 110029
we still have stock of the accumulator but have no plan for it.
Old 02-04-2013, 11:13 PM   #3688
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
I'm trying to install a hfs-5 dds3v10 into my 04 wrx I need wiring diagrams for the failsafes and which ones are best to hook up also which pins do I tap in the ecu if possible I need a diagram for that and I need to know what jets for 22-25 psi and around 350hp
alexandern05 is offline   Reply With Quote
Old 02-05-2013, 03:34 AM   #3689
Aquamist
NASIOC Manufacturer
Member#: 110029
This one should work
Old 02-05-2013, 08:44 AM   #3690
alexandern05
Member#: 266954
04 wrx v7 sti swap
great people over there at aquamist very helpful answered my email very fast also thanks a whole lot
Old 02-15-2013, 07:07 PM   #3691
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Default Blowing Pump Inline Fuse
Any idea why this keeps blowing. Would happen if I switch the gauge/system on while under boost, now it just happens all the time? Everything looks fine but...
dsmtowrx is offline   Reply With Quote
Old 02-16-2013, 12:58 AM   #3692
Aquamist
NASIOC Manufacturer
Member#: 110029
Is your pump installed in the engine bay?
The most commonest reason is water ingression into the pump. Once the pump motor bearing is corroded, it will put extra load on the motor and draw excess current.
Old 02-18-2013, 05:50 PM   #3693
dsmtowrx
Member#: 48879
Grey Stocker
It's right in front of the washer tank in a GR. So could see moisture but should be pretty protected in the fender well there. How susceptible are they to moisture? Pump is just over a year old...
Would I check pump condition by testing it's resistance? What should that be?
Old 02-18-2013, 06:06 PM   #3694
climbhigh09
Member#: 254163
2011 WRX 20GXTR
That's a pretty common place for them...
climbhigh09 is offline   Reply With Quote
Old 02-19-2013, 09:00 AM   #3695
Aquamist
NASIOC Manufacturer
Member#: 110029
The pump itself is very well insulated. But the cable gland is not. Water trickles down the cable and gets into the pump.
You need to separate the pump head off the motor and check the bearing.
Old 03-12-2013, 10:24 PM   #3696
sti20g
Member#: 300874
2006 Subaru sti
gunmetal grey
which jet should i install want to run 22 psi on 750cc injectors on a blouch 20g w/ supporting mods (2006 sti) hsf-3 kit also which resistor should i install
sti20g is offline   Reply With Quote
Old 03-12-2013, 10:29 PM   #3697
sti20g
Member#: 300874
2006 Subaru sti
gunmetal grey
** single port meth injection and the pump is mounted to my sub box same height if not lower than my tank
Old 03-13-2013, 02:02 PM   #3698
Aquamist
NASIOC Manufacturer
Member#: 110029
You have 3000cc/min of fuel. For M50/W50, you need to flow 600cc/min. It look like a 0.8mm + 0.9mm jet. Use a 0.7mm restrictor.
It is good.
Old 03-15-2013, 02:44 AM   #3699
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I am putting back to use my good old 2D system to spray 100% water on 98RON with small sized garrett 30 turbo on TMIC
injectors are 1000cc, and currently I have 0.7mm jet installed in the TMIC
Will it be ok, or do I absolutely have to put a bigger one in there?
Hyper is offline   Reply With Quote
Old 03-15-2013, 01:26 PM   #3700
Aquamist
NASIOC Manufacturer
Member#: 110029
Hey, greetings. It has been a long time.
What was your fuel injector size before?
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 04:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
