Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 09-07-2012, 10:17 AM   #1
STIMULA8
Member#: 298221
2004 WRX swapped STi
Default Need Help Fast Clutch Stuck To Floor
Okay so this Wednesday, August, 5th, 2012 I went to Lancaster Speedway near my house for a local car show/drag show. Its 5$ bucks to race and I wanted to take my new 2004 sti down the strip. I have never launched with any Subaru before. I didn't feel it was right. The Subaru I have now is built and I even called the previous owner and asked him if what the launch control was set at was safe to launch at. It was set to 5500 rpm.
**I raced 4 times before ever launching it and just bogged out at the line which caused a very bad time. **
So on the 5th time racing, I decided to use launch control, I let out the clutch slow after the launch, and spun the tires really good. I went pretty deep in the redline (almost 7600rpm) then as I went to shift into 2nd and I lifted my foot off the clutch slowly, the pedal stayed at the floor and I was in neutral still just revving the motor down the strip. I put the car in neutral, and pulled the clutch pedal with my hand, it popped out, but it felt very soft. As I was rolling I put it in second again to see if it would go into gear and it would grind real bad as I'm pulling off the clutch.
I pulled over, turned the car off and starting swearing like a sailor. Every word in the book. i started it back up, and just rolled out of first and u can hear the clutch isn't sounding right and a real bad grind only when i shift.
I decided to drive it in the raceway parking lot, and noticed if i rev match when up-shifting, and not using the clutch at all, it would not grind at all. I would not go past 3000 rpm, and the gear lines up itself, and sucks into gear. Same goes for down-shifting, if i don't use the clutch at all and rev match down-shifting, it drives better than when I was using the clutch! O.o
It only make the noise when I am at a stop, and put it in 1st to get the car rolling, it seems like it skips/slips then once I'm moving the noise is gone and I then drive the car clutch-less, with the rev match technique.
So what I am asking is if anyone has any ideas what this could be. LET ME KNOW! I need my car back and I'm hoping I don't need to spend a 1,000$ (hoping its just my slave cylinder or clutch fork or clutch disk)
Here's whats done to the car mods wise: CAR MAKES 466WHP/401WTQ @ 22PSI
EJ257 Shortblock 99.75mm Bore
Disassembled, cleaned, decked and torque plate honed.
Crankshaft polished and balanced to.5g
Blueprinted and Reassembled with Calico Coated
ACL Race Bearings
Brand New 8.2:1 99.75mm Mahle Pistons and File Fitted Rings
Manley Rods(H beam)
Version 7 JDM big port heads PnP,radius valve and decked
BC cams 280
New springs and retainers
APS dr725 FMIC
APS 70mm CAI
850CC Denso Injectors
APS 3in Hard turbo Inlet
AMR T60 Turbo10.5cm Exhaust Housing
* 3 inch compressor Inlet
* Fully ported exhaust housing
* Fully ported compressor housing
* OIL AND WATER COOLED!
AP ver 2
Mishimoto Rad with samco hoses
GMS 170 Thermostat
Grimmspeed uppipe with 38mm tial wastegate
Hallman pro manual boost controller
HKS High power exhaust 3in
Moore Performance Downpipe 3in, no wastegate side.
PnP throttle body with heat coating
PnP intake manifold with heat coating
TGV delete with pheloic spacers 6mm
grimmspeed oil air separator
Grimmspeed exhaust manifold with hi flow x pipe(PnP)
Perrin Fuel rail
Perrin F&R Sway bars and endlinks
Whitline anti lift kit
Tokico Shocks
RCE springs(Yellow)
Saggy butt spacers for the rear
Whiteline rear diff lock kit
Whiteline rear subframe bolts
GT spec F&R strut tower bars
JDM 6speed swap with the r180 rear diff 5x100( 48,xxx miles)
Torque solution short shifter and bushings
Torque solution rear shifter bushing
ACT 6puck HD and pressure plate
ACT streetlight flywheel(15lbs)
Cusco eng and tranny mount
Brembo Brakes
DBA F&R Rotors
Hawk HPS pads
Gruppe S SS lines
Grimmspeed Master Cylinder
04wrx to 05 STI center console swap.
STI gauge cluster
Sparco Toreno 2 seats(good condition)
Defi Oil temp, Oil pres, boost
Pioneer AVIC D3
Alpine Type s Components Front
Kicker speakers Rear
Rally Armor UR mudflaps
Wheels
(4) Rota Wheels(Royal Silver) 18x8.5 5x100
(4) Sparco rally wheels powder coated back with winter tires on them 17in
5x100 only used one winter 80% tread left on them
STIMULA8 is online now   Reply With Quote
Old 09-07-2012, 11:07 AM   #2
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Hmm so can you actually actuate the clutch by hand or does it behave as if the clutch is permanently engaged? Based on your description it sounds like the fork may be busted. I would say return spring, but then you'd be able to actuate it by hand. Sounds like something it shot, may as well just crack the thing open now.
Old 09-07-2012, 02:17 PM   #3
STIMULA8
Member#: 298221
the clutch engages, but not fully. it only got stuck to the floor once. i can drive the car without the clutch just fine....lol just from a roll it grinds to get the car moving in 1st
Old 09-10-2012, 11:30 AM   #4
STIMULA8
Member#: 298221
i can make my pedal suck to the floor every time if i push the slave cylinder (while the cars on), with my hand i push the fork to push the piston inside the slave cylinder all the way, and then i quickly go to my clutch pedal and just tap it and the clutch pedal gets sucked in to the floor.
would this be a bad slave cylinder?
Old 09-10-2012, 02:16 PM   #5
STIMULA8
Member#: 298221
bumpp
Old 09-13-2012, 11:25 AM   #6
STIMULA8
Member#: 298221
bumpp it
Old 09-13-2012, 12:45 PM   #7
STIMULA8
Member#: 298221
this is a video on myself wiggling the clutch fork and pushing the slave cylinder piston in. idk if what its doing is normal. any thoughts?
Old 09-24-2012, 01:57 AM   #8
kj15991
Member#: 293548
2005 wrx sti
aspen white
bleed the clutch, remember you will have to remove the slave and hold it above the master in order to bleed all of the air out.
kj15991 is offline   Reply With Quote
Old 09-24-2012, 11:17 AM   #9
STIMULA8
Member#: 298221
i bled the system twice, and no difference in grabbing point/ pedal stiffness.
Old 02-19-2013, 08:50 AM   #10
Boost@15
Member#: 230420
2005 impreza wrx sti
Olllld Thread... But Looks like the fork came out the throw out bearing... Happened to me long time ago...
Boost@15 is offline   Reply With Quote
Old 02-19-2013, 09:16 AM   #11
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
Sounds too me like the throw out bearing popped out of the pressure plate...
rexworx is offline   Reply With Quote
Old 01-22-2014, 02:52 PM   #12
STIMULA8
Member#: 298221
To confirm and update, it was the clutch disk and pressure plate that got so hot it melted some chunks of disk and they hardened on the pressure plate so there wasnt an even surface to the disk/pressure plate.
Old 01-31-2014, 12:44 PM   #13
STIMULA8
Member#: 298221
Pics
reposted
Old 01-31-2014, 01:09 PM   #14
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Yer pix don werk..
Old 01-31-2014, 01:19 PM   #15
STIMULA8
Member#: 298221
Originally Posted by RoadKillDMD View Post
Yer pix don werk..
updates pics, used igota URLs to insert image
Old 01-31-2014, 01:28 PM   #16
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Still nuttin.
http://igotasti.com/vBforum/attachme...0&d=1391190160
http://igotasti.com/vBforum/attachme...1&d=1391190186
http://igotasti.com/vBforum/attachme...2&d=1391190197
Even your links don't work. You need a different website to host such as photobucket or imgur.
Old 01-31-2014, 01:31 PM   #17
STIMULA8
Member#: 298221
updated to photobucket links, did that work?
Old 01-31-2014, 01:42 PM   #18
STIMULA8
Member#: 298221
Still nuttin.
how about now? i used the bucket
Old 01-31-2014, 02:00 PM   #19
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Only one was working properly...
Old 01-31-2014, 02:08 PM   #20
STIMULA8
Member#: 298221
I fixed it....i think
Old 01-31-2014, 06:38 PM   #21
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Old 02-04-2014, 10:37 AM   #22
STIMULA8
Member#: 298221
Old 02-04-2014, 10:45 AM   #23
Trolling motors
Member#: 380710
Dang that poor car
Trolling motors is offline   Reply With Quote
Old 02-04-2014, 01:52 PM   #24
STIMULA8
Member#: 298221
Originally Posted by Trolling motors View Post
Dang that poor car
Im surprised the clutch went and just melted, and not my rear diff/axles or something else. She is running great now, I have a new motor setup with only 2400~ miles as well, on a low boost tune for break in.
Old 02-06-2014, 02:00 PM   #25
mr4thGEN
Member#: 380922
That poor clutch
mr4thGEN is offline   Reply With Quote
