Old 02-18-2013, 10:57 PM   #1
Dillinja666
Member#: 332644
07 STI
It's white
Default Driveline binding?
So I have on 07 STI and when I have the DCCD in auto I get crazy clicking and poping noises from the front and rear diffs. Like not normal, people have sat in my car and said theirs does not do that. The noise goes away though when I have the DCCD on man and all the way open. ( I have never had it set to anything else other then open )
So...any ideas?
Dillinja666 is offline   Reply With Quote
Old 02-19-2013, 07:47 AM   #2
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
Open means no dccd engagement. Closed (or closing by degrees) means dccd is locked and power split (on mine) is 50-50. I get those same noises at slow speeds when locked.
BTW only engage my dccd when racing on dirt and maybe on snow street driving.
mhoerath is offline   Reply With Quote
Old 02-19-2013, 09:12 AM   #3
Dillinja666
Member#: 332644
07 STI
It's white
So basically you have to turn it to manual mode every time you restart the car? The auto function even on open locks the dccd?
Old 02-19-2013, 09:19 AM   #4
xplosion79
Member#: 339279
Do you have different sized wheels or tires?
xplosion79 is offline   Reply With Quote
Old 02-19-2013, 09:25 AM   #5
Dillinja666
Member#: 332644
07 STI
It's white
No. When I got the car the tires were beat. I replaced all 4 with a nice set of Goodyears. It was worse with the beat tires on. I'm worried I'm going to break something, it sounds bad and you can feel it in the car bind up and skip and crackle as it moves in tight turns in auto open.
Old 02-19-2013, 03:18 PM   #6
mhoerath
Member#: 131379
justablue hatch
My controller is aftermarket and has no auto mode. If i unplug connector from controller by default dccd opens. If you can defeat your controller the dccd will open. If you accomplish both then the problem is related to your controller.
Old 02-19-2013, 03:20 PM   #7
Dillinja666
Member#: 332644
07 STI
It's white
Hm OK. I'll gave it a shot tonight.
Also I feel it does it more/worse when warm. Like after a decent drive, mayby 15 mins of freeway driving or so.
