Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 02-25-2012, 07:47 PM   #301
Superaison
Member#: 257982
02 Impreza
thanks for info
Superaison is offline   Reply With Quote
Old 04-12-2012, 09:01 PM   #302
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
Just finished mine. I was scared at first but the instructions were real easy to follow. I'm usually anti-cut/splice but it worked out and the car feels so much smoother and pulls so much harder. Well worth the money!
damonmlime is offline   Reply With Quote
Old 04-12-2012, 09:10 PM   #303
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I just redid mine and I got rid of any splicing.
I had the entire harness out of the car so where I originally had a splice, I took the wire that was originally between the igniter and the main engine connector and ran that straight to the ecu connector and installed a new terminal. Now i only have a single wire that goes between the ecu and the engine harness. I lost about three to four feet of wire for each of the four igniters, I lost the strange hung of wire that ended up residing in the engine bay and I lost one more connection point that could cause a failure.
bmxpunk is offline   Reply With Quote
Old 04-12-2012, 09:10 PM   #304
makipsee
Member#: 150181
1998 2.5RS
wrb
i converted my 98 2.5RS to COP with the stock ecu been running great
makipsee is offline   Reply With Quote
Old 04-28-2012, 01:45 AM   #305
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
just did this swap except used the pig tails from the new coilpack...car starts however it then idles down and bogs out...every time...any ideas? it holds idle for a few seconds 5-8 or so then dies
93GC8Dub is offline   Reply With Quote
Old 05-31-2012, 11:37 AM   #306
mrBradleyDean
Member#: 317831
1995 STI RA
My Subaru is in transit from Japan and i already know I'll have to eventually do the conversion. So I'm trying to get parts and be ready for it. I got a good line on some cheap coils but most of the posts I read about are using 02+ coil packs however the ones I have lined up are 04+ is there any difference or will it work all the same? Thanks.
mrBradleyDean is offline   Reply With Quote
Old 05-31-2012, 03:54 PM   #307
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
04 wrx or sti coils will work fine
TommyAtomic is offline   Reply With Quote
Old 05-31-2012, 11:28 PM   #308
mrBradleyDean
Member#: 317831
1995 STI RA
Ok awesome! This deal is too good to pass up on a set of 04-09 STI diamond Ignition Coil Packs
Thanks for your help
Old 06-24-2012, 01:25 AM   #309
REECERS
Member#: 259958
mkay figured out my issue, I bought (snowjob)'s legacy. Apparently I have a jay dee mmmm motor which has two bolts for the coilpack instead of a single bolt. I believe it to be EJ20G because snowjob said it was out of 96 wrx. Any help on this? Am I screwed and just have to find jdm coilpacks?
i found my problem on wikipedia. Looks like i might have a 93 motor. Any fixes for me? And if not anyone know where I can get a Coilpack that will work with the two bolt setup?
REECERS is offline   Reply With Quote
Old 06-24-2012, 02:05 AM   #310
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
You have a 1989-1993 engine. You can make the coil packs work but it involves some cutting and drilling which is not ideal. I've already seen one pack shorting out to the engine because too much insulator material had to be removed.
You can also purchase four AEM coils and use short spark plug leads:
http://www.aemelectronics.com/high-o...dumb-coil-1239
http://www.ebay.com/itm/AEM-High-Out...3695af&vxp=mtr
I'm planning to use those on (one of) my next conversion(s).
Marnix is offline   Reply With Quote
Old 06-24-2012, 01:53 PM   #311
REECERS
Member#: 259958
looks legit, but how do you know those bolt holes will line up? and is that 53 bucks each? so like 200 dollars?
Old 06-25-2012, 06:27 AM   #312
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
They don't bolt to the head. You can bolt them to a bracket (DIY) or chassis rail and use short plug leads.
Old 08-26-2012, 07:59 PM   #313
curly2k3
Member#: 87614
9698 GC8 & GF4
Black and White
For those of you with odd heads, like the older Leggy 2 bolt ones, you can keep your eyes peeled for Nology wires that were made for the B4 legacy, I found a set on Ebay Japan (from Hong Kong however) and the seller took a reasonable offer.
makes dealing with the plugs and coil set up a lot easier, the Nology wires have ran ground wires as well, plus heat shielding. Just food for thought, I'll be wiring in my new set up next weekend.
curly2k3 is offline   Reply With Quote
Old 12-05-2012, 09:46 AM   #314
scobbymike
Member#: 339748
Unhappy
hi guys i have a problem with my impreza i put a diffrent engine in car heads and rocker covers are diffrent but i used my orignal coil packs i dont think they fit properly as in iam not sure if the coil is attauly touching at the plug at the moment old plastic ones i need to get car sorted i will be doing this conversion when i have some money to buy coils when i get to turbo range car holds back spluuters etc i thought it was maf so changed that but no diffrence how can i modifey my old coils to use them on theses heads they are signle bolt hole
thanks all
scobbymike is offline   Reply With Quote
Old 12-09-2012, 01:42 PM   #315
scobbymike
Member#: 339748
hi guys what coils are the best to use thanks
Old 12-13-2012, 07:31 PM   #316
scobbymike
Member#: 339748
Exclamation
can any 1 help please need to know what coils to use
Old 12-13-2012, 08:35 PM   #317
makipsee
Member#: 150181
1998 2.5RS
wrb
im guessing anything 02 and up from a wrx or STi
Old 12-14-2012, 03:06 PM   #318
scobbymike
Member#: 339748
hi mate thanks becouse i can get hold of a black colour coil or a grey colour coil not sure what to use
Old 01-18-2013, 01:33 PM   #319
CRX7
Member#: 31639
99 Impreza
Amazing i was getting misfires and hesitation as low as 3k rpms as soon as boost hit. Now it's smooth all the way to redline. Car runs smoother, my afrs are leaner, no longer running rich.
Btw, stock cops looked fine. Only one had aslight crack in the plastic. So even if they look fine yet could be bad. Thanks rob great writeup. I got a set of plugs for to cops, made it much easier to wire.
CRX7 is offline   Reply With Quote
Old 01-30-2013, 03:10 PM   #320
canadiansnoobie
Member#: 334960
1996 WRX - silver
2010 impeza 2.5i - silver
Default Success!!!!!!
I just did this conversion last night and let me tell you: holy hell what a difference. The pull that my soob has now is awesome!!
Thank you Rob!!!!!
The Instructions you gave for this conversion were very easy to follow and I had no issues.
I have a friend with a 94 STI and he wants to do this conversion. If any of you know where to get some more 2002+ coils let me know
Thanx
canadiansnoobie is offline   Reply With Quote
Old 02-19-2013, 04:37 PM   #321
Gera97
Member#: 311928
1997 Impreza GT
Deep Green 307
Hello, Im from Costa Rica, I have a 1996 Impreza GT, which comes with EJ20G ,I havent read all this thread pages because of lack of time, anyway Im a little confused because Išve found more than one part number for 02-up coils, so anybody can tell me which coil part numbers work for my car?
The second thing is whats the price for the 02 wrx
coils in the US?
In my Local dealership they are offering me 01 wrx sti coils for around $86 each coil!
Gera97 is offline   Reply With Quote
Old 04-23-2013, 03:55 PM   #322
Bruere
Member#: 353523
1998 STi RA V-Ltd
Super Mica Blue
Is this something you should do for an EG20K as well or just the EG20G?
Bruere is offline   Reply With Quote
Old 05-02-2013, 12:48 PM   #323
MrWeedster
Member#: 293096
Hi there.
Im planning doing this coil conversion on my 93 Legacy EJ20G.
One thing i dont understand about this: Its stated that you have to bypass the ignition module. By the same time one should only make one coil after another and test them after installing.
Im wondering how someone can test e.g. the first installed coil while the other ones are still requiring the ignition module?
My plan is to not cut wires at the two connectors that run into the ignition module but to build cables that connect them together.
The other thing is: As far as i understand one has to cut around on the ignition coil to get it into the legacys two bolt heads?
Does someone has a pic at how the coil looks after it has been treated that way? I dont want to destroy my new coils ^^
[EDIT]
What curly2k3 said is a good idea too. Im thinking on doing such bracket for myself and get some spark plug wiring + leads.
Im just curious which i should buy. Is a grounding cable mandatory or can i use leads without? Which connectors do the cables need to have? Male - Male or Female - Male?
MrWeedster is offline   Reply With Quote
Old 08-16-2013, 09:36 PM   #324
bigd003
Member#: 233285
2008 Forester
Outfront Motorsports sell a connector complete with pins, that will fit the coil, so that anyone who broke an OEM connector can fix it.... They would then work great for anyone doing this conversion, not wanting to solder wires to the pins.
http://www.ebay.com/itm/Subaru-Ignit...b25fe2&vxp=mtr
I bought 6 for an engine project that I am working on.
I have a question- Are the WRX coils longer than the STI ones? If so, would that give them a better contact with the plug, or is this not an issue?
bigd003 is offline   Reply With Quote
Old 09-18-2013, 10:01 AM   #325
gc8owner
Member#: 368525
1995 gc8 wrx
Default I'm confused..
hello guys im very confused ive done all the wiring and checked it over multiple times and it will not start. what do i do ? im clueless ive tried everything i can think of and it will not start.
Last edited by gc8owner; 09-18-2013 at 07:04 PM. Reason: problem turned into another problem.
gc8owner is offline   Reply With Quote
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
