Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-08-2010, 03:04 PM   #51
lennybootzz
Member#: 190811
04 gt35r built
wrb sti
Im having the same problem aem with kelford cams ! I rev to 6600 and boom same thing!!!
My car idles and start MINT drive awasome, just the rev to 6600 seem to be my only problem!!
So Me and my tunner filled down just a little tiny bit on bolth cams sensors, as well as the crank sensor last after reading this tread i showed to him.
Car stated up fine last night, i go to start my car this morning it starts then dies, doesnt idle , lots of poping (like its running rich).
so i pulled out all the sensors agian re connected them car ran like mint agian!!!
lennybootzz is offline   Reply With Quote
Old 08-19-2011, 06:18 PM   #52
Razlin
Member#: 146635
06 WRX STI
Satin White Pearl +
^ Hows it running now?
Razlin is offline   Reply With Quote
Old 02-19-2013, 07:21 PM   #53
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Any new info? I have a series 2 box that will randomly sync vvc1b (drivers side avcs) and work properly. Cam sensors are filed down. (Properly this time vs how one of them was from the shop I bought the car from. )
Swapped cam sensors around and both sensors are good.
When vvc1b isn't working, I get hesitation and fluctuation during light to medium throttle between 2000-3100 rpm. Randomly it will kick in and work properly. All ranges are very smooth when its working properly. As soon as the rpm drops below 1800 ish rpm, it cuts out and won't kick back in until it randomly decides to do so.
I am pretty tired of all this. I have spent more time troubleshooting this issue than actually enjoying the car. Probably why the guy I bought it from wanted without of his garage.
05_wRex is offline   Reply With Quote
Old 02-19-2013, 08:14 PM   #54
bigmike25rs
Member#: 83924
2005 HTA 86 STi
10.66 @ 136 mph
Wow. I forgot about this.. my car has been gone for 2 seasons now..
your issue sounds a bit different than mine was. It sounds like your AVCS is just cutting in and out. I can tell you that car is stumbling because the AVCS has to stay active to keep timing at 0 advance. It requires oil pressure to do so. You would not be able to just shut it off as the timing would drop to full retard and stay there (causing the issue I believe you're experiencing) maybe you have an issue with one of the solenoids. Try swapping the solenoids side to side and see if your bank changes. Its not hard at all to swap them. Just a 10mm bolt holding them in place. We see them act up all the time at the dealership and 99% of the time its just from dirty engine oil or some type of prior turbo/rod failure that left debris in the oil. I would go that route first.
bigmike25rs is offline   Reply With Quote
Old 02-19-2013, 08:46 PM   #55
05_wRex
Member#: 170097
Passengers side is a pain. Still haven't gotten it yet. The car has 28k miles on it. As far as I know it hasn't blown up before. The drivers side (side with issues) solenoid looks brand spankin new. No signs of dirt or anything to indicate it's clogged. It moves freely. Would it be internal?
Old 02-19-2013, 09:40 PM   #56
05_wRex
Member#: 170097
OK. Got them switched and it didn't change anything. Thanks for the suggestion. Aem called me back and said that the drivers side avcs (vvc1b) is providing values higher than the sensor is supposed to read. Vvc1 start and range are 1.902 and 2.328. Combined that is 4.230. Vvc1b start and range are 1.551 and 2.328. Combined is 3.879. This is the max value the aem unit will accept for the cam sensor. It will error out if it sees a number higher than that. Apparently the vvc1b sensor is providing a higher number than 3.879 most of the time. This causes the aem to error out and it defaults to vvc advance offset (my cal says 60.45*). This only happens to vvc1b. Sometimes it will be OK and everything will be running correct in aem tuner. Meaning both avcs sides are working as they should. If I let the idle drop below 1800 ish it errors out and vvc1b is back to acting up until it decides to come back online. Vvc1 never misses a beat and is always working properly.
Here's the thing. There was no change in behavior after switching cam sensors side to side. And when vvc1b does start working, its perfect, like nothing was ever wrong.
Aem has suggested that it could be a problem with the teeth/tooth/edge on the aftermarket cam itself giving a false reading or making it error out. Why would just one side do it?
Thanks for any help. I can email the log file I sent to aem if anyone wants to take a look.
Old 07-20-2013, 11:03 AM   #57
0to115in11
Member#: 140832
I have the EXACT same issue with my car (BC 280 cams with Series 2 AEM) and have the same values in my start/range! Did you ever figure out a solution!?
0to115in11 is offline   Reply With Quote
Old 07-20-2013, 11:24 AM   #58
0to115in11
Member#: 140832
The only variable between the driver and passenger side is that the passenger side has an oil reducer for the turbo that causes higher oil pressure at idle on the passenger side
Old 07-20-2013, 03:06 PM   #59
05_wRex
Member#: 170097
Pm box full..
Old 07-22-2013, 04:17 PM   #60
0to115in11
Member#: 140832
Cleaned out inbox.....
Old 07-26-2013, 01:58 AM   #61
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Last I heard 05_wRex fixed his problem by going to Vipec
Old 01-14-2014, 07:38 PM   #62
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
bump because my car just starting having the same issue. Passenger side is losing signal.
06rexwagon is offline   Reply With Quote
Old 01-14-2014, 08:25 PM   #63
2000subie
Member#: 207638
2004 WRX
Yellow
I had this issue last year. Ended up taking a file to the sensor housing to bring it closer to the cam gears. It fixed the issue for me.
2000subie is offline   Reply With Quote
Built motor not starting bad crank/cam signal with AEM EMS and kelford 272s? lester Engine Management & Tuning 10 08-19-2013 12:26 PM
Element Tuning HYDRA EMS 2.5 02-05 WRX w/ LAUNCH CONTROL dan avoN7 Engine/Power/Exhaust 27 06-03-2009 02:17 AM
AEM EMS w/uego 02-05 WRX only SuperClutch Engine/Power/Exhaust 1 06-25-2007 01:01 PM
Tuning AEM EMS on 02 REX ShadowWRX77 Engine Management & Tuning 5 05-09-2007 07:13 PM
aem ems 02-05 wrx (not STI) Silver Ra Exterior/Styling 0 01-11-2007 06:43 PM
