Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 12-04-2012, 07:19 PM   #1
DirtyEP2
Member#: 161939
2011 WRX STI
SSM
Cool Competition Clutch Stage 3 Review GVB
So recently I had my clutch replaced, my stock clutch was still ok, but for the upgrades I have and will be making in the future I wanted get the clutch out the way. In the past I have had Exedy stage one in my old Integra, and a Competition clutch stage 4 in my old civic. I like the Exedy but with their limited line up its hard to find a clutch just right for my application. I loved the Comp stage 4 in the civic. Pedal feel was great and the clutch hooked like an on/off switch. Now that I have a STi that is fairly new I wanted to keep pedal feel reasonable, and have some good bite from the clutch. Plus since I like to auto x and track the car I need something that wouldn’t start slipping, and not feel like moving a ton of bricks when disengaging. So I went with Comp clutch again, I opted for a stage 3, due to the fact that itis a full face with segmented Cerametallic compound, and a Heavy Duty pressure plate. The clutch is rated to hold 450 lb-ft of torque which is plenty for what I plan on doing with this car.
I took the car in to Touge Factory in Wheeling, IL to have the clutch installed. TF did a great job on getting the clutch done quickly. My STi was in and out in one day. They took some pics of the install which I have added to this post. Please take a look below.
How it feels:
I now have 400 miles on the clutch; there is no break in period for the stage 3 clutch due to the material they use to make it. But I am old fashion and put 300 miles on it before putting it thru the paces. First impression was its a lot stiffer pedal pressure than stock, and it is tough to find the sweet spot for a normal take off, after 150 miles the pressure eased up, and it became a lot easier to launch. It feels like power comes on stronger than the stock clutch, and after a session on a curvy back road I couldn’t get it to slip. I made 4 passes on this road which requires a lot of on off throttle, and shifting. The clutch just continued to engage the same every time. I even purposely rode the clutch on a hard start, to try and heat it up and see how it reacts. I was pleased to feel that it felt the same as if it wasn't overheated. One thing I did notice is the trans used to give me a little bit of a grind on a hard acceleration from 4th to 5th, Now with the new clutch and the AMSoil in the trans it has gone away. It has to be either the clutch or the oil, if not both.
Overview:
All in all I am very happy with the Comp stage 3. It gives the holding power that is needed, and the drivability I want since the STi is my daily driver right now. I would recommend this clutch again and again. It’s perfect for the street and track driver this clutch is up to any task that you can throw at it.
.CC part # 15030-2600
Amsoil Severe GearŪ 75W-90 in the trans.
The car: 2011 Subaru WRX STi GVB.
Installer: Touge Factory Wheeling, IL. tougefactory.com
Stock vs. CC Stage 3
DirtyEP2 is offline   Reply With Quote
Old 12-04-2012, 07:36 PM   #2
bug eye wrx
Member Sales Rating: (13)
Member#: 161584
Cool review and nice looking STI!
bug eye wrx is offline   Reply With Quote
Old 12-04-2012, 07:37 PM   #3
DirtyEP2
Member#: 161939
2011 WRX STI
SSM
Thanks!
Old 12-04-2012, 10:04 PM   #4
zandman
Member Sales Rating: (1)
Member#: 239055
nice STI.
i've seen this driving around several times.
zandman is offline   Reply With Quote
Old 01-31-2013, 07:01 PM   #5
CookKnowsBest
Member Sales Rating: (2)
Member#: 320039
2012 Impreza WRX
Ice Silver
After my tax return I'm ordering this clutch to go with a GTX3076R setup. I hope it's up to the task.
CookKnowsBest is offline   Reply With Quote
Old 02-19-2013, 11:16 PM   #6
besthaticouldo
Member Sales Rating: (15)
Member#: 279660
this clutch, i have it in my car as well. do you notice a lot of bucking or the clutch engagement being really rough?
thanks
besthaticouldo is offline   Reply With Quote
Old 02-23-2014, 09:24 PM   #7
extransam
Member Sales Rating: (4)
Member#: 287109
04 WRX 18G Hybrid
I have my old one for sale, only 1200 miles, no problems, just too aggressive. Fits 02-05 wrx. I am on my phone so I can't link it but just go to my profile.
extransam is offline   Reply With Quote
Old 02-01-2015, 02:18 AM   #8
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
I know this an old thread but i followed some information in it and it screwed me up. Kevlar clutches are harder to break in because they wear less and it's harder to knock of the peaks in the friction material. You may need more than 300 miles.
From CC
"This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for up to 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 300 mile break-in recommended with this set-up."
Purpose_Built is offline   Reply With Quote
Old 04-28-2015, 11:52 PM   #9
bluemax189
Member Sales Rating: (19)
Member#: 137405
20g 6spd
Installed this clutch roughly 3000 miles ago along with a 6spd swap. Getting used to engagement from the stock clutch took some getting used to but this thing grabs and goes. No issues at all so far at all and has been a pretty great daily driver that can handle some power and future proof me for some more down the road.
bluemax189 is offline   Reply With Quote
