Old 02-28-2011, 03:03 PM   #76
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Can't wait!!!
Leonardo is offline   Reply With Quote
Old 06-22-2011, 05:37 PM   #77
old blue
Member#: 39710
Default well ?
So where does all of this stand ?
Did anything ever get resolved or product offered for 5 EAT ?
Mike
old blue is offline   Reply With Quote
Old 06-22-2011, 06:37 PM   #78
FlatironsTuning.com
NASIOC Storefront Vendor
Member#: 171650
Mike
Well, ClimberD has had the diff for a while now, so hopefully it is installed and he can give us some feedback. Once we get that, we will start looking into producing this diff.
FlatironsTuning.com is offline   Reply With Quote
Old 06-23-2011, 01:22 PM   #79
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I spoke to him 2 weeks ago before I went on vacation. He threatened to get off his arse and install it in the car. But I understand he's had some unplanned difficulties (I think he popped an engine IIRC) and decided to do a fully built gearbox at the same time as installing the diff. He'll update this when it's in the car and running...
Old 06-23-2011, 10:40 PM   #80
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Can't wait!
Old 07-01-2011, 12:31 AM   #81
climberd
Member#: 183019
05 LGT Stg3 Wgn
It's in and it's awesome. 5eat front torque-sensing LSD is rocking and rolling! Fitment is great. Ring gear fits snug on the carrier, perfect clearance. Bearings pressed on no problem. I cannot speak to the carrier bearing screw caps (not sure of real name) positioning vs stock front diff, because the new bearings were slightly revised, and came with new bearing seats, or whatever they are called that go in each end cap along with an oil seal. So they are slightly thicker. In other words, don't think about being lazy and pretending stock preload settings are appropriate for this diff! Set it up as you're supposed to, of course. I marked the bearing caps to see before and after, and it's proportional, indicating the machine work is spot on!
Setting carrier preload was done exactly to factory service manual instructions, with success. No problems there.
The diff is completely transparent, and as quiet as stock. No problems there.
It pulls the front end around corners! The more power you give it, the more it pulls. It is very exciting. A whole new car in respect to a drivetrain. The front end is more on rails now. No problems anywhere.
My other mods to the 5eat (namely HexMods center differential bulletproof bearings, and HexMods F1 Valve Body) really make the 5eat and this mod shine. I use to be jealous of the 6MT, with its really great drivetrain. But no more! I am now very happy with the 5eat, which now has viscous rear (stock), electronically controlled variable locking center, and Torque-Sensing FLSD!!! Plus with lots more line pressure now, it holds gear ratios effortlessly!
I highly recommend this differential!!!
What else do you guys want to know?
Don't forget to grease the stub axles!
climberd is offline   Reply With Quote
Old 07-01-2011, 01:56 PM   #82
Matt Monson
Member#: 832
99 2.5RS, '85 911
You're welcome.
Old 07-01-2011, 03:14 PM   #83
FlatironsTuning.com
Member#: 171650
Very glad to hear that the diff is working well!
It sounds like you are seeing similar benefits to what I did when I put the Modena diff in my 5MT. That front TBD makes the car like you always though an AWD car should. And as fun as it is on the street, it makes a world of difference on the track.
Matt and I will have to talk about getting this into production now.
Old 07-02-2011, 11:45 AM   #84
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Or at least a second unit for me!!
Old 07-02-2011, 11:56 AM   #85
vicious_fishes
Member#: 158864
2003 SOHC destroker
Old 07-03-2011, 02:06 AM   #86
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
That isn't for the 5 Speed Auto, but thanks!
Old 07-03-2011, 10:26 PM   #87
Matt Monson
Member#: 832
99 2.5RS, '85 911
Originally Posted by vicious_fishes View Post
I like how they call it an LSD in their marketing. It's a TBD. There's a very real difference between the two and you would think the "experts" at PPG would know the difference...
Old 07-04-2011, 04:23 AM   #88
vicious_fishes
Member#: 158864
2003 SOHC destroker
5eat. XD.
*goes pink*
tbd = torque biasing differential?
do you know much about it? i'm contemplating dropping it into my track toy.
Old 07-05-2011, 01:00 AM   #89
Matt Monson
Member#: 832
99 2.5RS, '85 911
A TBD (torque biasing differential) is the type of design used by OBX, Quaife, PPG, and is the same style as the factory Suretrace units. The advantage of them, especially on an AWD car on tarmac in particular is that they have no lock up under braking. They don't introduce any additional corner entry push, but once you are on throttle they aid in power transfer as the inside front wheel starts to slip. It's a great option for a street car weekend track toy or budget racer.
But for a purpose built racecar, most people, tarmac or dirt rally, will go with a clutch type LSD. With multiple internal ramp angles, you can set it up to have little or no lock u on braking and a wide variety of locking characteristics under acceleration. If it's a tight technical course, we run steeper ramp angles and set the LSD to lock later with more difference in wheel speed allowed from side to side. If it's a long fast course with big high speed sweepers (think Road America) then we give the LSD more acceleration lock.
This is purely with respect to the front diff. The way we set up and tune the center and rear LSD is significantly different...
Old 08-31-2011, 10:48 AM   #90
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Hey Matt, updates on when we can get one of these??
Old 08-31-2011, 11:57 AM   #91
Matt Monson
Member#: 832
99 2.5RS, '85 911
My understanding is that ClimberD is trying to put together a group buy on one of the Legacy GT forums. I think Flatirons may be doing the same thing here as well. Basically, we've got to get half a dozen people to raise their hand and put in a deposit to make it worth the effort. Either that, or if people want singles, they are going to cost a whole lot more because of the custom machine work needed to do them.
Old 08-31-2011, 12:09 PM   #92
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
well....id bet they Do know the difference...its the idiots buying them that dont so they have to market to the lowest common idiot
Old 08-31-2011, 12:54 PM   #93
Matt Monson
Member#: 832
99 2.5RS, '85 911
So you condone treating people like they are stupid instead of making the effort to properly educate them about what they are buying?
Old 08-31-2011, 01:15 PM   #94
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Yep, he does it all the time as he got tired of educating.
Old 08-31-2011, 01:50 PM   #95
Uncle Scotty
OK buy Nates beans
d000000000000d.....wake up....people ARE stupid and dont want to be educated....they want to be spoon fed and THAT is just NOT on the ****ing menu
Old 08-31-2011, 02:02 PM   #96
Matt Monson
Member#: 832
99 2.5RS, '85 911
Hey look, it's the devolution of Scotty's attitude over the last ten years here.
Old 09-02-2011, 05:07 PM   #97
FlatironsTuning.com
Member#: 171650
For anyone interested, we now have a group-buy thread started.
http://forums.nasioc.com/forums/show...5#post35019805
We hope that there will be a good amount of interest so that we can get this going soon.
Old 02-20-2013, 06:42 AM   #98
ausrs
Member#: 114593
Hey guys bringing this thread up to see if anyone can answer a question on 5EAT diffs.
I was just about to buy a 5EAT box for a project but have found out that they are a 3.08 ratio and I wanted 4.44.
So my question is do the ring and pinion gears from the 4EAT bolt straight into the 5EAT ?
I thought I would ask this here because of the work done putting 4EAT centres in the 5EAT.
Thanks in advance.
Ken
ausrs is offline   Reply With Quote
Gauging Interest on 05-09 LegGT specific Crawford air-oil separator. Leonardo Legacy Forum 0 12-24-2009 03:33 PM
WTB: Any Downpipe that would fit on an 02 WRX w/ stock midpipe JeffyLube SCIC Private Classifieds 3 06-02-2009 12:26 AM
Whatever happened to that tribe of orcs we found in the amazon? skimmilk68 Off-Topic 16 12-24-2008 12:35 AM
WTB wheels that would fit a 05+STI Bumble Bee 03 MWSOC Private Classifieds 0 07-15-2007 10:44 PM
WTB: WRX Din Pocket or any others that would fit paperchasin Private 'Wanted' Classifieds 8 11-06-2004 05:37 PM
