Old 05-15-2003, 10:53 PM   #1
NewbyScooby
Member#: 33710
Question Will a 2.2 liter head fit and work on a 1.8 liter block
Hi,
I am trying to find a larger head that will bolt up and function on my 1.8 liter. I was was wondering if the 2.2 liter head will work or the 2.5. If not is there anyone that does a good head work?
Any info would help
Tom
NewbyScooby is offline   Reply With Quote
Old 05-19-2003, 06:08 AM   #2
RSimport
Member#: 24718
05 impreza RS
white
thats one of my options also when I go to do motor work let me know if you come up with anything.And if you do it let me know how it works out
RSimport is offline   Reply With Quote
Old 05-19-2003, 11:23 PM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default All EJ heads work
All EJ series heads are compatable. What you need to look at is what your compression ratio ends up after a head swap. Most of the 2.2 heads are a horrible upgrade because they are single port exhuast I think the 1.8 heads are all dual port not a 100% on that. So going to a 2.2 head could actually be a downgrade.
Joshua
yebokmj is offline   Reply With Quote
95 1.8 liter heads on a 98 2.5 dohc engine?? possibe felixwankel88 Normally Aspirated Powertrain 8 09-28-2006 11:28 PM
('93-'01) What Will 2.5 DOHC Heads Fit? Roy Impreza Forum 1 05-17-2006 08:54 PM
('93-'01) will a 99 2.5rs gauge cluster fit and work in a 99 obs? zeke21 Impreza Forum 0 12-15-2005 12:27 AM
Timing and detonation on a 1.8 to 2.5 swap.... EcksJay Subaru Conversions 18 09-25-2005 09:21 PM
Can I put a 2.0 head on a 1.8 block? NewbyScooby Normally Aspirated Powertrain 11 11-18-2003 07:10 AM
