Old 02-19-2013, 10:00 AM   #151
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by luan87us View Post
^ that. Though little LCD screen and HD radio are nice features to have I don't think they worth more than $100. For $300+ you realize you can get MUCH better HU out there with much better functionality. You can even find the OEM NAV unit for around $300-$350 around here sometime.
Not if you want to keep the oem look, which I did. I'm happy with my purchase.
Old 02-19-2013, 04:29 PM   #152
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Originally Posted by burnurass View Post
There definitely a limitation, but it's acceptable.
A bonus is that the bluetooth works much better, it picks up the call right away.
With the stock headunit, it would pick up the call, radio would come back on, then go back to the call. So it would take 3 seconds for you to start talking.
weird i never had the delay problem with my non-4.3 unit. hopefully the 4.3 unit im getting doesnt do it.
Blackmamba24kb is offline   Reply With Quote
Old 02-19-2013, 06:14 PM   #153
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
First, the other lead I was thinking of in my previous post is for the illumination of the dash to day time brightness when the lights are on.
To your comment. Yes, you are correct, and I am well aware of that. In fact, I have said so in other posts. I obtained a CM631UD because that is what I wanted. Further, several people have complained of the factory nav not being so user friendly. I don't know, but I really didn't want that unit. I also didn't want to have to adapt the SWC's, 3.5mm jack, USB jack, BT mic, all of which would be necessary with aftermarket, or abandon them in lieu of what the AM comes with. I wanted plug and play. As I said, I got what I wanted. Now I'll be able to add the BU camera.
Since the OP asked about PNP, I was simply trying to inform him.
John
Old 02-19-2013, 06:41 PM   #154
luan87us
Member#: 335013
2013 Premium WRX 5dr
You can get a HU with front USB and Aux lol. Does this unit still gives out bad sounds aka not enough power?
Old 02-19-2013, 06:54 PM   #155
verbalwarfare1
Member#: 347603
2005 impreza
champagne
You need the serius sat radio adapter from the dealer. Hooks into the existing unit, but it is about 350$. Seems like it would be cheaper to hook an aftermarket unit that comes with the antenna and unit. Mine was 100$ and had the antenna, FM transmitter, remote, et cetera. I bought an extra antenna that I stealth installed into my 02rex so I can swap between subys without paying for XMsirius twice.
verbalwarfare1 is offline   Reply With Quote
Old 02-19-2013, 07:20 PM   #156
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
I know. I did my homework.
It sounds more clear at volumes above 30, where the original would start to distort. Otherwise, pretty similar. It had the same stupid EQ and loudness settings, which got turned off.
I'm happy with it.
John
Old 02-19-2013, 08:16 PM   #157
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I found used one for 100 shipped, they are out there.
Old 02-19-2013, 08:20 PM   #158
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I think it sounds much better, but I am only using the signal to feed an alpine ktp445u amp. But the output had much cleaner signal
Old 02-20-2013, 06:03 AM   #159
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
I have been considering that same amp. Where did you locate it, and are you satisfied with it?
It seems resonable for what it is. I'm not looking for lots of bass so I don't want a sub. Just a bit more power to the exsisting speakers.
John
Old 02-20-2013, 06:59 AM   #160
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
John
I will find the pictures or the thread if I posted one and post them here.
I originally had the gain set to 1/2, but when I installed the new radio I dropped it down to about 1/3, sounds better because the white noise is gone now
Old 02-20-2013, 07:12 AM   #161
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Good info on the gain settings. Thanks.
BTW, my question regarding where you located it pertains to where in the car, as opposed to Crutchfield. Did you use the power lead for the HU as Alpine advertizes you can?
Wiring is not a concern to me. That is, for me, a piece of cake. Everything I have read suggests the wires that come with it are too short so I expect to need to extend those.
I am in the process of getting the harness from DC for a camera and the eventual amp install. I'll probably wait until I have good weather and do it all at once though.
John
Old 02-20-2013, 07:58 AM   #162
08BlackWRXCT
Member#: 225296
2015 WRX Premium
Crystal White Pearl
which sirius module part number do i need for HU CP635U1?
08BlackWRXCT is offline   Reply With Quote
Old 02-20-2013, 11:53 AM   #163
luan87us
Member#: 335013
Just scored a 2012 Nav unit for $375. Pretty excited. Now I have to find out how to update it with different map database.
Old 02-20-2013, 12:37 PM   #164
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
John
wires are plenty long, i should have actually cut off 6" on both sides, but I'm just stuffing them under the radio/behind the HVAC controls. I made a bracket, zip tied it to the metal supports, and zip tied the amp to it. it is a perfect fit
yes, i just tapped into the power/ground/remote lead for the power/turn on signal for the amp. I didn't use the antenna power because that is only active with the radio mode. top of my head, i don't remember what i used for the remote. SVXd told me what to use, i might still have the email.
http://forums.nasioc.com/forums/show...&postcount=272
Old 02-20-2013, 12:39 PM   #165
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
the one available for your WRX, i think anything from 2008+ works.
Old 02-20-2013, 02:14 PM   #166
08BlackWRXCT
Member#: 225296
2015 WRX Premium
Crystal White Pearl
Just got mine installed! Love it! I got it from car-parts.com and It was pretty beat up..must have been in a bad accident cause there glass between the buttons and between the screen and bezel. Had to take it apart and clean it up...there are a few scratches on the screen but barely noticeable...all I need now is my Sirius module!
Old 02-20-2013, 02:46 PM   #167
jeffoppido
Member#: 272559
2011 Impreza 2.5
carparts.com? Checking now.. Part number 86201sc630, model number pf-3302b-a, front model number cp635u1
not on carparts.com right now.. anyone know of one for sale? I'll purchase immediately.
jeffoppido is offline   Reply With Quote
Old 02-20-2013, 02:48 PM   #168
Blackmamba24kb
Member#: 330797
how much did you get it for? were you the one that got it for 80 bucks?
Old 02-20-2013, 03:15 PM   #169
luan87us
Member#: 335013
it's car-part. When you're thre do a search for 2011-2013 Subaru Impreza Radio. There's a shop (google B&R Autowrecking) wanting $175.96 for one and he said he's willing to do $150 + shipping.
Old 02-20-2013, 03:41 PM   #170
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
very cool information found in fcc documentation for the CP635U1/ PF3302-b, especially their user manual. apparently you can bring up a list of presets? i didn't know that, going to try it tonight when i get home
go to
http://transition.fcc.gov/oet/ea/fccid/
first box
ax2
second box
PF3302
Old 02-20-2013, 03:49 PM   #171
08BlackWRXCT
Member#: 225296
2015 WRX Premium
Crystal White Pearl
Yup that was me...it wasnt in perfect condition but id say 8/10.. def worth the $80
Old 02-20-2013, 04:00 PM   #172
Blackmamba24kb
Member#: 330797
def can't go wrong with $80 did that include shipping? how much was shipping to you? good come up.
I just installed the one without the satellite, if I can score the satellite version ill swap it. not sure if ill ever use satellite though since i've never used it before but its nice to have it if I wanted to. My fiance' infiniti has it but i think she stopped subscription but its nice to have so many different channels.
love this thread.
Old 02-20-2013, 04:09 PM   #173
08BlackWRXCT
Member#: 225296
2015 WRX Premium
Crystal White Pearl
Yup that was $80 shipped, he told me on the phone $65 for the unit and $15 for shipping. It took about 2-3 days to get it here. i saw very surprised to find one since everyone else had such a hard time finding these with the SAT radio.
Old 02-20-2013, 04:16 PM   #174
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i never thought to check car part. but mine came out of a car with 350 miles on it in flawless condition
Old 02-20-2013, 04:44 PM   #175
jeffoppido
Member#: 272559
2011 Impreza 2.5
Thank you! Shot him a message!
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket SubeDooS SCIC Private Classifieds 1 04-14-2011 03:05 PM
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims johnpaulm1208 Tri-State Area Private Classifieds 1 04-06-2011 10:32 PM
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale mug23 Suspension/Brakes/Handling 3 06-26-2008 12:35 PM
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? ScoobyNubieToo! Car Audio, Video & Security 3 02-11-2008 08:26 AM
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires singincanary Private 'For Sale' Classifieds 5 08-30-2005 08:50 PM
