Old 03-29-2012, 09:46 PM   #276
Bennett Johnson
Member#: 257587
2008 Wrx 4dr
Originally Posted by lordgrinz
Yeah, I was a little freaked out at that myself, the front bumper flexs like its not attached correctly or something. Definitely a very flimsy part.
Haha, try removing it!!! Then you'll see why it's so flimsy.
Bennett Johnson is offline   Reply With Quote
Old 04-01-2012, 02:02 PM   #277
coutbacksport
Member#: 80582
1998 Impreza Outback
Default cracked front bumper
What is the cheapest possible fix for a broken front bumper? My 98 OBS is all cracked from multiple snowbank crashes. I drive very aggressively in snow, and sometimes the snowbanks I crash through to get into my driveway are too hard. But that's why I love driving an old car that I can drive like it's a toy and not worry about. It's only the bottom center of the bumper that is cracked. Would gorilla tape be my best bet. I've tried to superglue it back together, but it never holds.
I thought about covering it with skateboard grip tape which would look great at first, but I'm afraid of running into cleaning/wear issues.
I'd like to do gorilla tape to make sure everything is together, and then cover that with something else a little nicer to finish it off. Any ideas about a good material for this purpose?
coutbacksport is offline   Reply With Quote
Old 04-03-2012, 12:16 PM   #278
Phuz
Member#: 293189
SSM
For me, silicone works great. Not sure how it would look on a black car, but find some that dries clear and i think you'll be in good shape.
Phuz is offline   Reply With Quote
Old 04-03-2012, 11:58 PM   #279
purplewrx
Member#: 315291
2012 WRX
PBP
Originally Posted by motown View Post
Bought my car (2011 wrx limited hatch) 1/31/12 (obsidian black pearl). Saw a cracked foglight and notified the dealer. I took the car the way it was an dthey ordered a new fog light lens. After having the car a couple days, I noticed a crack in the bumper on the driver's side right under the foglight (same damn spot as everyone else). I recently took it to the dealer to have them change the lens and the whole foglight housing was cracked behind it so they ordered me a new one. Knowing all of this, and seeing the scrapes on the underside of the bumper (from the past owner), do you guys think Suabru will do anything?
What dealer ? I am from long island and have a 2012 on order
purplewrx is offline   Reply With Quote
Old 04-10-2012, 11:46 AM   #280
MasiveMunkey
Member#: 44631
2004 WRX
WR Blue
I had the same crack as everyone in this thread and had it repaired at a Subaru dealer for ~$200. Now a month later I scraped asphalt going probably 3 miles an hour and the crack has reappeared I'm not sure what I should do at this point. It's so frustrating that these cars can't have even the smallest force put on the bumper. My 2004 WRX went through tons of **** and I never had a problem with that bumper.
MasiveMunkey is offline   Reply With Quote
Old 05-17-2012, 09:53 PM   #281
jnumata
Member#: 266755
2011 STi
Plasma Blue Pearl
Driving home today from work I changed lanes to make my exit and wham! The car in front of me hit a semi-truck retread and threw it straight into my front bumper. The Ventureshield looks the worst so I'm just going to get that lower section replaced and call it good for now after reading this thread.
jnumata is offline   Reply With Quote
Old 05-22-2012, 08:19 PM   #282
meski
Member#: 321014
I had the same thing happen to mine. Driving down a road that was ruts of thick, bumpy mud so the front bumper kept hitting and cracked both sides. I ended up epoxying the crack together and then when i feel like it ill bondo and paint it. Holding strong so far.
meski is offline   Reply With Quote
Old 06-01-2012, 08:52 PM   #283
jnumata
Member#: 266755
2011 STi
Plasma Blue Pearl
Got mine fixed today - plastic weld, paint and clear blend, and then my Ventureshield will go back on Monday! $300 fix.
Old 06-01-2012, 10:24 PM   #284
echardcore
Member#: 260638
2011 WRX Sedan
Spark Silver Metallic
nice. you inspired me to get the clear bra. I have an appointment for monday. you should spray the inside of the bumper with Stop Leak rubber sealant. I used a similar product. Its like Rhino Liner. Very easy to apply.
echardcore is offline   Reply With Quote
Old 06-01-2012, 10:28 PM   #285
jnumata
Member#: 266755
2011 STi
Plasma Blue Pearl
FYI. The Ventureshield is on the car in this picture except for on the repaired lower lip area - it was separate piece luckily so they could just take that little section off.
Old 02-15-2013, 02:01 PM   #286
NYInk
Member#: 329681
2012 WRX Sedan
Cracked the bumper on my '12 sedan recently too I have a clear bra but that makes it look worse now because when it cracked, the flex in the bumper made the clear bra lift up so now I'm getting all this dirt and crap in there. Might just remove the bra on that piece of bumper and live with it. I've got mods I want to spend money on, not a new freakin bumper and paint!
NYInk is offline   Reply With Quote
Old 02-20-2013, 08:59 AM   #287
moboost4u
Member#: 160429
2005 STi
JBP
Sorry if this has been answered already but I dont have the time this morning to read all 12 pages here. Did anybody end up having any luck with SOA on getting the bumper replaced???
I ask because this morning I cracked MY SECOND bumper in the exact same lower spot as most of you have. The first time I tapped (and I mean tapped) a snowbank and cracked it within months of ownership. I was so upset that I just got it replaced but this morning I hit a pothole (bumper dint touch anything) and low and behold, exact same crack. This is outrageous that these cant withstand the wear and tear of daily driving anymore.
So yeah, anybody have any luck with Subaru?
moboost4u is offline   Reply With Quote
Old 02-20-2013, 09:23 AM   #288
echardcore
Member#: 260638
2011 WRX Sedan
That sux ^ sorry to hear that.
I sprayed a **** ton of that newish rubber sealant stuff all over the inside of the bumper and along the bottom edges. Not the Flex Seal from TV but a similar product from Home Depot. I have scraped one time since applying and so far so good. The scrape was pretty bad too.
I really hope they address this.
Old 02-20-2013, 11:01 AM   #289
lifeonwalls
Member#: 317150
2009 WRX Hatch
Dark Grey Metallic
I've got a cracked bumper on an '09 WRX hatch (premium) and was considering replacing it with newer bumper cover but not sure if a newer one will fit or if the widebody bumper would like strange on it.
Stupid flimsy bumpers.
lifeonwalls is offline   Reply With Quote
Old 02-20-2013, 06:45 PM   #290
swpshgnwgn
Member#: 150494
11 WRX
SWP Torqued Stg II
Have you tried calling SOA? I think you might have a bit more luck with your case considering you've gone through two. Maybe I'm giving SOA too much credit...
swpshgnwgn is offline   Reply With Quote
Old 02-20-2013, 09:02 PM   #291
_davin
Member#: 260501
2011 WRX 5dr SWP Ltd
No it would not fit for several reasons, and I guaranty your bumper is stronger than ours.
_davin is online now   Reply With Quote
Old 02-20-2013, 09:28 PM   #292
huey412
Member#: 347737
that looks painful
huey412 is offline   Reply With Quote
Old 02-20-2013, 10:23 PM   #293
kthorsen
Member#: 346471
2013 wrx base
wr blue
Default same here
Car has 700 miles on it pulled up on the lawn bumper rubbed the grass going very slowly bumper cracked on the corner common to the side air vent thing and popped out the piece on the side. what a cheap ass bumper i had a acura tl i ran into a pole at 10 miles an hour and it just scuffed it.
kthorsen is offline   Reply With Quote
Old 02-21-2013, 08:37 AM   #294
moboost4u
Member#: 160429
2005 STi
JBP
Not yet but I probably will today. I was waiting on responses from here.
Old 02-25-2013, 10:23 PM   #295
CatchMyDrift11
Member#: 335970
2011 WRX Sportback
Obsidian Black
I had the same problem with the same location. My bumper cracked too. I just bought a front lip and aligned it in place before installing. Now that will take any abuse. Hahaha
CatchMyDrift11 is offline   Reply With Quote
Old 03-18-2013, 02:31 PM   #296
jlundy11
Member#: 324709
2012 WRX Sedan
Cracked mine yesterday coming out of a steep driveway. Barely even touched and it cracked. My G37 is way lower and rubs everywhere... no crack yet. The plastic on the WRX is weak. Any good looking aftermarket replacements out there?
jlundy11 is offline   Reply With Quote
Old 03-18-2013, 02:59 PM   #297
heavyD
Member#: 194216
2013 STI Sport-tech
Man you would swear that these bumpers are fiberglass with all the people suffering cracks. It appears the thin bumpers covers also are made from a cheap thermoplastic compound that has very little give. I've seen crappy cars like Cavaliers get into fender benders where big dents just pop back out.
heavyD is offline   Reply With Quote
Old 03-18-2013, 07:03 PM   #298
BlueWRXsubie
Member#: 347451
WR Blue
Add one more cracked bumper to the list. There is some scuffed paint on the driver side corner, but I have no idea when it happened, must have barley rubbed. found it while replacing fog lights. Super annoying I baby this car. :P eff
Guess I'll try the plastic repair and v-limited lip to keep it from splitting up the front....
BlueWRXsubie is offline   Reply With Quote
Old 04-01-2013, 04:26 AM   #299
accuracy
Member#: 152151
2011 WRX 5door
went up driveway a bit too quick today at the wrong angle....
any luck repairing this with just 5min plastic weld epoxy and duct tape over it?
accuracy is offline   Reply With Quote
Old 04-01-2013, 11:35 AM   #300
Bajamedic
Member#: 233360
2003 Baja
Obsedian perl/grey
OMG HAHAHAH I have the exact same issue with the exact same location. im gunna use fiberglass to reenforce the crack and then im' gunna plasty dip the lower part of the bumper.. give my car a sporty look. dude i feel for ya. i don't have snow in SF, i was bein dumb
Bajamedic is offline   Reply With Quote
WTB : 02-03 wrx lower front bumper piece... 240WRX02 Private 'Wanted' Classifieds 2 06-28-2010 01:12 AM
cracking on front bumper OneArmedScissor Interior & Exterior Modification 1 05-01-2004 02:22 AM
'02 WRX wagon: lower front only? gordon Brakes, Steering & Suspension 28 02-22-2004 12:07 AM
CRACKED my front bumper!!!!. SFimpreza411 Bay Area Impreza Club Forum -- BAIC 4 06-30-2002 03:06 AM
Message Board Statistics All times are GMT -4. The time now is 04:11 PM.
