Old 01-07-2013, 02:21 PM   #526
WRXncrew
Member#: 39970
2008 LGT Spec.B
Quartz Silver Metalic
Originally Posted by RexyGirl View Post
The remote and immobilizer are two totally separate things. You were able to program the remote, but the immobilizer needs to be programmed by computer....there is no way for you to do it. It's a high security key, so it needs to be programmed by computer.
It is true that all your keys will need to be programmed at the same time, otherwise they will not work to start the car.
Also, you may be required to provide proof of ownership of the vehicle before they will program the keys to the car.....
So, I sort of get that they are separate. But, what I have read is that people have a new remote & key, then they take the immobilizer chip out of their valet key and put into their new remote and key and that should work. If that works, then how does the immobilizer connect with the cut key? Proximity? The immobilizer chip needs to be very close to the actual newly cut key?
WRXncrew is offline   Reply With Quote
Old 01-07-2013, 02:46 PM   #527
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
The chip has to be VERY close to the ignition, in other words, in the key itself.
I don't know where they would find room inside the remote to put the chip. The only difference between a valet key and a regular key is that the valet key will not open the glove box or the trunk like the master key will. Why cut up a key that actually works?
I don't think putting the chip in the remote will be considered close enough.
RexyGirl is offline   Reply With Quote
Old 01-08-2013, 05:06 PM   #528
WRXncrew
Member#: 39970
2008 LGT Spec.B
I decided not to cut up the valet key.
I took out the immobilizer chip from another remote where the key was working, and put it into the new remote and it now starts the car.
Old 01-09-2013, 09:55 PM   #529
rainbom
Member#: 341480
2012 STi(Canadian), factory alarm with factory shock sensor. I'm wondering is there a way to tell if the alarm went off at some point but I didn't hear it? i.e. does the car make any different chirps when I come back to unlock it?
rainbom is offline   Reply With Quote
Old 01-10-2013, 05:40 AM   #530
snobrder_ad
Member#: 129203
2004 WRX Aspen White
StgII
Is there any way to change the frequency/code of the stock alarm and reprogram the remotes to that?
(Keys were stolen at gym, and dont want the lowlife that took them to have access to my car in the future)...
any help is appreciated
snobrder_ad is offline   Reply With Quote
Old 01-11-2013, 07:05 PM   #531
CSVT_2004
Member#: 182213
1999 Contour SVT
Correct me if I'm wrong, but I believe you'd need to have the dealer remove the old keys to prevent that.
CSVT_2004 is offline   Reply With Quote
Old 01-11-2013, 10:32 PM   #532
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
You can take it to the dealer, bring your current remotes so they can know which ones are good and which ones to clear.
If you want to DIY, program your remote(s) 4 times in a row, the keyless computer only remembers 4 remotes, in a series, so if you program known remotes 4 times in a row, you'll have "pushed" the old stolen remotes out of the system.
Power6 is offline   Reply With Quote
Old 01-12-2013, 10:47 AM   #533
CSVT_2004
Member#: 182213
1999 Contour SVT
oh yeah forgot about that. Good call!
Old 01-12-2013, 09:14 PM   #534
RexyGirl
Member#: 63616
with mods :)
The immobilizer chip is not in the remote....it's in the key.
Not sure how you got it working. The key you used must have been programmed to your vehicle. The remote has nothing to do with the vehicle starting.
Old 01-12-2013, 09:15 PM   #535
RexyGirl
Member#: 63616
with mods :)
When you go to unlock the vehicle with the remote, it will chirp more than normal....the number of chirps will tell you what was activated.
Old 01-12-2013, 09:19 PM   #536
RexyGirl
Member#: 63616
with mods :)
Your alarm system will hold up to 4 remotes. Depending on how many you have let, you can program each one multiple times to take up the 4 spots. The old number will be erased out and will not longer work to unlock the car.
For example, if you have 2 remotes left, program each one twice,.
If you only have 1, then program it in the car 4 times.
Old 01-12-2013, 09:51 PM   #537
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
He has a an 08 Legacy the remote and the key are the same piece.
Old 01-12-2013, 10:11 PM   #538
RexyGirl
Member#: 63616
with mods :)
Whooops...didn't look at that
Old 01-13-2013, 10:58 AM   #539
WRBWRXWGN
Member#: 340320
2002 WRX Wagon
OK so I've done everything in this thread to try and get into programming mode. I've checked to make sure I do infact have a security system. I have the alarm horn on the strut tower and the security module in the center console. I thought the security module might be bad so I swapped out another one and still nothing. I cant get my security light on the dash to even turn on at any point of the ignition cycle. There are no wires cut under the dash, the security module has power, the alarm horn works, all the fuses are good. At this point I don't know what else to do in diagnosing my security, but I would greatly appreciate some help. 2002 wrx wagon btw. Thanks
WRBWRXWGN is offline   Reply With Quote
Old 01-14-2013, 07:04 AM   #540
campen
Member#: 343570
Are the Keys waterproof? Not the remote but just the key. I was wondering if I could just leave the remote in the car and take the key with me when I go tubing on the river and if I'd have any problems with it?
campen is offline   Reply With Quote
Old 02-01-2013, 06:29 PM   #541
WRXncrew
Member#: 39970
2008 LGT Spec.B
FYI.. The immobilizer chip (transponder) is in the key near the remote buttons inside.
Old 02-07-2013, 11:19 PM   #542
AndreaB
Member#: 345935
Default pesky alarm
a couple of weeks ago my battery died on my car and i had to replace it. Then the next day when i got in it the alarm went off(it has never gone off before EVER) and locked me inside the car after a few attempts of pushing the lock and unlock button buttons on my car the alarm finally shut off and the doors unlocked but it wouldnt let me start it, so my father disconnected a white wire under the dashboard and now the alarm goes off when i open the door and finally goes off after a few minutes but while im driving the car beeps. beep. beep. beep. beep. after the car has been driven for about 15 minutes it will sometimes stop. or when i press on the break it sometimes stops. also my dome light and radio no longer work. i do not have the keyless entry thing but i have a car starter? how do i get the beeping to stop, its driving me insane even if i have to disconnect the alarm horn im fine with that i just dont know where its located? oh yes and its a 2000 outback.
Thanks in advance!
AndreaB is offline   Reply With Quote
Old 02-08-2013, 01:05 PM   #543
RexyGirl
Member#: 63616
with mods :)
Thanks in advance!
Sounds like you need to take it back to whom ever installed the remote start. When the wiring under the dash was disconnected, it probably affected your dome light and radio.
When you replaced the battery, you reset the factory alarm system which was probably in valet mode. Unless you can somehow get the remote start installers to put in back in valet mode, you will probably have to get a new OEM remote.
Old 02-10-2013, 01:33 AM   #544
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
I had bought an OEM teardrop remote off ebay for my 06 WRX. I opened it up and there is only one set of 8 digits... They are mixed of numbers and letters. What do I do to program that? I tried substituting the letters for numbers and that did not work. Any help would be appreciated!
mr.nicknasty8 is online now   Reply With Quote
Old 02-10-2013, 04:48 PM   #545
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I just checked mine to see what the sticker on mine is (I got mine off ebay as well).
Its a single sticker with two sets of numbers (one is just numbers, the other is letters and numbers).
I don't think the letters/numbers version will work with this programming method
Hotsho111 is offline   Reply With Quote
Old 02-10-2013, 09:26 PM   #546
mr.nicknasty8
Member#: 244192
2006 WRX
ARC FMIC
That's what I figured... Off to the dealer I go! Thanks!
Old 02-12-2013, 01:11 AM   #547
Capitals101
Member#: 319406
2006 WRX
Could you check out the thread I posted and see if you could help me out in anyway? I cant seem to figure out the problem and its driving me crazy I cant even drive my car!! http://forums.nasioc.com/forums/show....php?t=2467208
Thanks a lot.
Capitals101 is offline   Reply With Quote
Old 02-18-2013, 08:53 PM   #548
live2ridetahoe
Member#: 31386
2008 WRX Avant
Default Only half of lights blink...
This weekend, I noticed that the passenger side lights do not blink when I lock/unlock with the remote. The blinkers themselves work fine, aka when I put on my turn signals.
I am goin to try to engage/disengage valet mode when I get home to see if that somehow fixes it.
Anyone have any suggestions?
Thx,
JG
live2ridetahoe is offline   Reply With Quote
Old 02-20-2013, 07:06 PM   #549
88hatchback
Member#: 347645
93 Subaru Legacy
Is there a source for remotes without having to pay a fortune?
88hatchback is offline   Reply With Quote
Old 03-16-2013, 06:36 PM   #550
TogeTouge2.0
Member#: 342681
02 Wrx
Red
I've checked the owners manual and tried the procedure below but I cannot seem to disable the chirp on the 02 Bugeye. I must be doing something wrong.
The horn no longer beeps/chirps when I lock/unlock the car:
**Make sure all the doors, windows, trunk and hood are closed.
**Disarm the alarm.
**Press and hold BOTH buttons on the remote until the horn/chirp sounds.
NOTE: To turn the beep/chirp back off, repeat the steps above.
TogeTouge2.0 is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
