Old 03-21-2012, 03:09 PM   #1601
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
125 FM - QRE Invader
Originally Posted by xsnapshot View Post
Here's some data I haven't seen mentioned yet.
http://www.clubwrx.net/forums/engine...04-19t-12.html
He's only moving 4.4 mafV @ 18psi. I move that much air at 16 psi on the small 16G. The dyno sheet at the end is not that impressive either. He does have a log up where it spools pretty quick however. Quicker than a small 16G usually does anyway. Looks like he sees 20psi by about 3200 RPM on a 3rd gear pull.
I'm still working on a few tweaks on this car. I've been very busy with life and haven't had the chance to really dial in the tune I would like. The tune is conservative and the car is running rich, so there's still some room for more power, albeit likely not too much.
The car is very fun to drive.
wrx wagone is offline   Reply With Quote
Old 03-23-2012, 10:43 PM   #1602
azscooby
Member#: 115297
2002 ej207 vf34
I ran the 19t for about a year and absolutely loved it. I only changed it because I did an ej207 swap which came with a vf37.
Spool time was just about the same as stock, definitely quicker than the small 16g I ran. I was disappointed with the 16g spool time, that's why I.chose the 19t wheel upgrade.
BTW mine is for sale if anyone wants to give it a whirl! Less than 8k miles and done by Blouch, still have the.paperwork.
azscooby is offline   Reply With Quote
Old 03-24-2012, 03:07 AM   #1603
Spec R
Member#: 187752
99 RS/X5/Volt
some of us stuck with 19T's for stock housing turbo's for vehicle inspections and the like.
Spec R is offline   Reply With Quote
Old 03-26-2012, 04:15 PM   #1604
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Do they actually check part numbers on the turbine/compressor housings for that stuff? How do they know that it's a stock-looking TD04-13L vs. a TD05-16G, especially if you manage to hide it under a modified stock turbo heatshield ?
Scooby921 is offline   Reply With Quote
Old 03-26-2012, 04:19 PM   #1605
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Hell, I've got a billet wheel 20G in a "stock" JDM GC8 16G housing... Never had a question about it at the VA inspection... They did not even notice my 45 mm EWG either...
soobaviator is offline   Reply With Quote
Old 03-26-2012, 04:20 PM   #1606
Spec R
Member#: 187752
99 RS/X5/Volt
I almost failed my CA BAR certification because of my boost gauge. I was chatting up the inspectors, and those guys do actually inspect the turbos and other items. Not only do they know exactly what to look for, they also know all the tricks and then some that people try to sneak by them.
Old 04-04-2012, 03:18 PM   #1607
vincent2
Member#: 315710
Hi!
Do you still have the 19T for sale?
Regards,
Vincent
vincent2 is offline   Reply With Quote
Old 05-16-2012, 10:57 PM   #1608
RumblinWagon
Member#: 303383
2002 PSM Wagon Stg2+
tuned
Changed my vf39 to a td04H-19t and love it. Quicker spool and very similar powerband. Pulls hard up to 6500 for sure and spools like ~17 psi by 3200 in third. Not too much of a drop in power up top with much better low end. Great daily driver turbo, not much more lag than stock but definately some. Just my 2.
Running full 3" catted exhaust, Cobb sf intake, grimmspeed pnp manifolds and crosspipe, v7 Sti tmic, dw650, walbro 255. Clark e-tune. Protune maybe someday...
RumblinWagon is offline   Reply With Quote
Old 05-24-2012, 09:50 PM   #1609
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
But WOW have the prices gone up on the small 16G!
http://www.bptstore.com/Subaru-WRXST...ger-_p_28.html
That turbo is now $845! When I ordered directly from blouch back in 2010, that turbo was $650 brand new. That's quite the increase.
Up top the JDM 15T I had was about 20HP less than the 19T in terms of airflow by the logs. Timing was 6 degrees more advanced on my stock motor with same basic mods; TGV deletes etc. Best road dyno was 260WHP IRRC
On the 2.1 stroker the small 16G made 4.4 MAFV by 4,200 RPM and 28 psi on the way up and at 18 psi, 4.7 MAFV at 6,200. This is with an external gate and Apexi power intake (equvalent stock MAF voltages quoted). That's where I left it and it was pushing the turbo quite hard but it held up great.
I thought about trying out the 19T on the small stroker but cost wise it did not make sense to leave so much power on the table. I'm curious to see what a good EWG setup will do with one but I'm past that now an on to a billet 20G (and maybe T04S hybrid). I think the only way to really get the potential out of this small snail big compressor turbo is with an ex-gate. Without one you are leaving a ton of power on the table maybe as much as 60HP in terms of air flow. The 6 cm hot scroll is a huge restriction after about 4K RPM. 28 psi peak boost is doable on this turbo as well for someone who has the courage.
For the money and simplicity I'd take a used/rebuilt VF39/43/48 over the 19T if staying on the internal gate. It will make more power and cost less.
Old 05-24-2012, 10:16 PM   #1610
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
That's a good point w/ the increase on the 16g pricing! What happened w/ blouch, why such a huge jump? Also fp's hta68 was 899 at some point, now their site has it for 1299?!
Evilchargerfan is offline   Reply With Quote
Old 07-12-2012, 02:43 PM   #1611
boricuamepr
Member#: 246244
2003 v7 Limited
STi Clone
boricuamepr is offline   Reply With Quote
Old 07-12-2012, 05:03 PM   #1612
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Mitsu raised prices on their turbos... by a lot.
All turbos made by buying a Mitsu turbo and "Frankstein-ing" from there will be more expensive. At Blouch, you may have noticed that the G based turbos went up significantly, but the DOM 1.5, 2.5, 3, etc... didn't really increase, because these are based on Garrett parts, not Mitsu parts.
Old 08-05-2012, 07:10 AM   #1613
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
So will any of the two 19Ts listed here, be a good bolt-on candidate on a bugeye??
http://shopping.kinugawaturbo.com/ki...ubarutd04.aspx
Torquey is offline   Reply With Quote
Old 08-14-2012, 10:39 PM   #1614
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Bump
Would like to know as well.
nightcrawler60 is offline   Reply With Quote
Old 10-04-2012, 08:07 AM   #1615
WRXbutch
Member#: 274152
2005 WRX
I've been reading this thread for a while and still haven't quite made up my mind about going with the 19t upgrade or just go for the 16g. I really like the price for the 19t conversion which midwest turbo connection (http://shop.midwestturboconnection.com/main.sc) list the prices on their site with all the options (l,h,hl,thrust bearings,and step gap rings) where as the blouch site doesn't. I also like the fact that they can do the upgrade with the l shaft and upgraded thrust parts for $675, but if you go with the H shaft then you end up paying $800. With this being said I am definitely stuck between a rock and a hard place bc I could spend a few more bucks and get a 16g and have more power available and not have to worry about it going out prematurely bc of it pushing harder than the housing is meant to allow or whatever.
sorry for being long winded, not clear, or rambling my turn to watch my son who is 2 weeks old who hasn't quite got the nack of sleeping at night yet has just ended hince why I finally get to post something at 7 am... ugh
WRXbutch is offline   Reply With Quote
Old 10-04-2012, 11:12 AM   #1616
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Have you seen the number of failures of 19Ts in this thread? I think you have to take into account the risk as well as the initial cost. 16G is a virtually no risk proposition. How much can you afford for your ~$700 to evaporate if it has the problem many of the 19Ts have had in this thread... plus if you go 16G, your original turbo is worth at least $100, which narrows the gap further.
Old 10-04-2012, 02:17 PM   #1617
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
small 16G and done. nothing else to be said really.
Old 10-19-2012, 11:54 PM   #1618
castle1977
Member#: 332244
2003 wrx wagon
black
looking to do the 19t upgrade and wondering about the mpg, since the turbo would be spinning most of the time. im getting about 25mpg on 91oc in colorado, and would like it to stay about the same. anyone out there care to comment?
castle1977 is offline   Reply With Quote
Old 10-20-2012, 12:16 AM   #1619
AllAWD
Member#: 17079
Depends solely on your right foot, should not change unless your driving style changes.. Also, skip the 19t and go straight to VF39/43 etc or 16g.
AllAWD is online now   Reply With Quote
Old 02-20-2013, 06:47 PM   #1620
b3delta
Member#: 242814
Midnight Black Pearl
Read a bunch of this whole thing, and I have to say that those who say a 19T will not get you to 300whp are talking out of their asses. I have a 19T with DW 650Cobb spec, walbro 255, PnP everything, and catless exhaust, and I'm at 300. and not even close to maxing out, beast of a turbo for the 2.0, highly recommended.
b3delta is offline   Reply With Quote
Old 02-20-2013, 06:49 PM   #1621
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
were did you get yours?
R-
labcoat is offline   Reply With Quote
Old 02-20-2013, 07:07 PM   #1622
b3delta
Member#: 242814
Luckiest timing ever, the stock 13T broke, and i checked the forum CTsubie.com and a guy had one for sale never been used. Paid $400 then $250 each for tune and injectors
try midwest turbo connection. they have more options you can go basic at like $500 or push it up a couple hundred more. but always be checkin forums someone may be gettin rid of one
Old 02-20-2013, 07:22 PM   #1623
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
the reason I asked is seems like more then a few haven't lasted.
R-
Old 02-20-2013, 07:27 PM   #1624
b3delta
Member#: 242814
installed it Oct 2011, and drive it hard as hell. no issues, if it does I'll post. Probably just jinxed it too. ugh....
Old 02-20-2013, 07:29 PM   #1625
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
quick find some wood and knock on it and fling a hand full of salt over you shoulder.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
