Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 02-20-2013, 08:37 PM   #1
fatso
Member#: 227527
2005 WRX
Default Pioneer X4500BT Wiring Harness Noob QuestionS
I'm almost done with the installation of my new Pionner AVH_X4500BT.
I Still have a few (probably dumb) questions about how to wire my 05 WRX. Where these cables go?
WRX PLUG:
A- ILLUMINATION/DASH LIGHT (ORANGE)
B- POWER ANTENNA (BLUE)
PIONEER PLUG:
C- PARKING BRAKE (LIGHT GREEN)
D- ? (ORANGE/WHITE)
I'm gapping the following:
E- SYSTEM REMOTE CONTROL (BLUE/WHITE)
F- MUTE (YELLOW/BLACK)
G- REVERSE GEAR SIGN INPUT (PURPLE/WHITE)
Any help would be greatly appreciated.
*Will Ground Both black cables.
fatso is offline   Reply With Quote
Old 02-20-2013, 09:40 PM   #2
dbmonster
Member#: 335675
2013 WRX hatch
Obsidian Black Pearl
The orange wire (A) on the wrx harness goes to the orange/white wire (D) on the pioneer harness, this is optional though, only if you want the screen and buttons on the pioneer to dim down when you turn your lights on.
The blue wire (on the wrx harness) I don't recommend using. On cars with a motorized antenna, some people will connect the amp turn on lead (blue/white wire) to this wire since pioneers don't have a true power antenna wire, but our cars don't have a motorized antenna. I'm not 100% sure, but I think that wire may be used to power a stock antenna booster (if there is one), and if so it may require more current then the pioneers turn on wire can provide. if you actually listen to FM radio you may want to try connecting this wire, I usually don't bother with mine.
The green parking brake wire, this is SUPPOSED to be tapped onto to the wire that comes from your parking brake that tells your cars computer that the parking brake is engaged. this is the LEGAL way to do it, and your pioneer unit will only display video when the parking brake is engaged. If you want to watch video while driving PM me and I will explain how.
dbmonster is offline   Reply With Quote
Old 02-20-2013, 09:43 PM   #3
fatso
Member#: 227527
2005 WRX
Thanks! You've been very helpful.
Old 02-20-2013, 09:49 PM   #4
dbmonster
Member#: 335675
2013 WRX hatch
No problem, and congrats on picking a great head unit.
Old 02-24-2013, 10:40 PM   #5
pezcore
Member#: 178045
06 WRX
If the Pioneer has a blue antenna lead you definitely need to hookup the power antenna wire. Without it, you'll get no radio reception.
I know this is the case on my Alpine stereo, but if Pioneer doesn't have this wire then I guess you don't need to worry about it.
Also, been thinking of getting one of the new Pioneers, how do you like yours?
pezcore is offline   Reply With Quote
Old 02-25-2013, 10:36 AM   #6
razzmatazz_21
Member#: 348221
2008 impreza
blue
Orange wire connect to orange/white wire
blue wire to blue/white
green parking break wire to the vehicle's parking break wire (or you could attach it to a simple 2 prong switch with a ground to the radios ground...pick one up at any auto parts store for $6)
Yellow/black forget about it
And the reverse gear wire you would only need if you had a back up camera
razzmatazz_21 is offline   Reply With Quote
Old 03-01-2013, 11:16 AM   #7
pezcore
Member#: 178045
06 WRX
So I bought this radio, for a Subaru (with the antenna in the rear glass) you have to connect the Car's blue antenna wire to the Pioneer Blue remote wire if you want your radio to work, these cars need power to the antenna. If you have an amp it's the same lead, you can use it for both amp turn-on and antenna power.
So, if you haven't finished this already:
A to D
B to E
C to parking brake or bypass
F leave alone
Old 03-14-2013, 09:40 AM   #8
yudangorgor
Member#: 151107
i'm going to install this unit next week.
quite excited
yudangorgor is offline   Reply With Quote
Old 03-15-2013, 03:12 AM   #9
Dika213
Member#: 350243
Hey I just installed an Alpine headunit on my Impreza WRX just recently, I have bad reception sometimes any suggestion? I think I installed everything properly, left out the yellow/blue stipe wire out and yellow/black stripe wire (any idea what are those for?).
Dika213 is offline   Reply With Quote
