Old 10-08-2012, 09:16 PM   #751
reid-o
Member#: 103631
2004 STI
Thanks I found more pics in this thread with the shroud. It doesn't show how far back the outlet goes though, but I get the idea. I was also looking at the GST splitter. I might try fabbing my own underpanel with vents in it. I really like the idea of placing the quick latch on the panel to make it easy to pull off. I may as well since I've cut enough of the car to make resale nearly impossible haha
Old 10-28-2012, 01:27 AM   #752
reid-o
Member#: 103631
2004 STI
Just FYI: power enterprise sells adapter blocks from their kits to angle the stock condenser. I had a friend pick it up in Japan and ship it to me.
I ordered a new factory condenser and put it on. It fit but I us to bend the crap out of the lines.
It's hard to see but it doesn't cover the whole radiator which I switched out for a bigger core.
Old 11-12-2012, 11:10 AM   #753
Impressed wagon
Member#: 64413
1995 Impreza Outblak
Flat Black full WRX swap
Here are a couple picks of the start of my V-mount on my 1995 Outback Sport
Will have some more up here in a week or so
Impressed wagon is offline   Reply With Quote
Old 11-24-2012, 07:36 AM   #754
Impressed wagon
Member#: 64413
WIth Forsa intake mocked up
Old 12-25-2012, 12:34 AM   #755
TIGWERKS
Member#: 256615
Whatever happened with those forsa intake manifolds? Saw them a couple years ago but never saw anything installed on a car/results.
TIGWERKS is offline   Reply With Quote
Old 12-27-2012, 07:23 AM   #756
Impressed wagon
Member#: 64413
Old 12-27-2012, 10:38 AM   #757
mrchyes
Member#: 294069
04 Impreza RS
rob your outback is sick
mrchyes is offline   Reply With Quote
Old 02-20-2013, 10:37 PM   #758
HougieBear
Member#: 347748
2003 Impreza WRX
Midnight Black Pearl
BUMP
Working on a custom V-mount set up on my car, try and post pics once it's done!
HougieBear is offline   Reply With Quote
Old 02-20-2013, 11:13 PM   #759
scby rex
Member#: 104878
02 wrxbastardchild
aw, 1,000,000 whp 2 aw tq
Is that a rotated fp green or 18g?
Old 03-30-2013, 09:41 AM   #760
Impressed wagon
Member#: 64413
20g for now
Old 04-01-2013, 11:29 PM   #761
Serkan
Member#: 180514
2004 Sti White
Test fitting
ETS custom intercooler and Northern radiator
Serkan is offline   Reply With Quote
Old 04-02-2013, 09:35 AM   #762
boost junkie
Top Scoob 009
Member#: 68273
GD Race Car in progress
My v-mount done by IAG using a custom built Ron Davis radiator and a Garrett intercooler core.
boost junkie is offline   Reply With Quote
Old 04-02-2013, 09:57 AM   #763
sysfailur
Member#: 135993
2008 STi
AW
It's still getting there for me but here's where we are at. Ducting is starting to come together and needs to be welded up. I'll be working on her more today and I do apologize for photo quality.
Boost junkie your setup is wonderful! It's making me want to have mine all finished but we still have a large checklist of things to take care of. Can't wait to see the finished product on both our projects.
sysfailur is offline   Reply With Quote
Old 04-02-2013, 08:44 PM   #764
sysfailur
Member#: 135993
2008 STi
AW
Some better pics from the progress of today:
Old 04-12-2013, 09:39 AM   #765
gotsugg
Member#: 204014
02 Bugeye
Rotated, HTA3582, E85
Originally Posted by Serkan View Post
this one :
If the first one is used I guess it will not be a v-mount anymore. More like radiator taking the place of regular fmic location.
I've seen the picture of this Radiator posted many times throughout this thread but I never saw any pictures of it actually installed. Has anyone used this type of Radiator, or does anyone have a link to a thread I might have missed showing them being used?
Thanks for the help
gotsugg is offline   Reply With Quote
Old 04-12-2013, 10:41 AM   #766
scby rex
Member#: 104878
02 wrxbastardchild
The aussie guys use it.
Old 04-12-2013, 07:19 PM   #767
sysfailur
Member#: 135993
2008 STi
AW
I'm using a Mishimoto MR2 radiator. It has 45 degree angled up inlet/outlets both on the top of the rad, and all the tabs on the bottom are angled 45 degrees as well so it's very easy we've found to make work.
I've since fixed all the fins in the picture above, the intercooler is fully welded, and my vent is now painted. I still have to do a final sanding and clear coats/buffing. She's a bit of a mess currently! hahah
Old 04-12-2013, 10:28 PM   #768
TIGWERKS
Member#: 256615
What vent is that?
Old 04-12-2013, 11:38 PM   #769
sysfailur
Member#: 135993
2008 STi
AW
Taiwanese quality WRC vent via e-bay for $66. Not really meant for my generation STi but it'll work to a certain extent.
Oddly enough I think b/c of the fact I had to buy paint, primer, bondo, sandpaper, and wax/grease remover I've doubled the cost of it now + a few blisters from sanding.
EDIT: @TIGWERKS: How does Ryan (Area1320) not know you're doing a v-mount build? He's said nothing of this! I just noticed your posts. Car looks nice! Once I finish with my hood we're going to make a replacement bumper beam and reinforce where the old bottom rad support was. He just finished welding my intercooler today.
Old 04-13-2013, 09:25 AM   #770
AutoPrue
Member#: 115459
Sys what type of IC core are you using?
AutoPrue is offline   Reply With Quote
Old 04-13-2013, 09:37 AM   #771
dandy ktm
Member#: 324925
06 Hawkeye
when you see it pass you
Are you guys seeing lower IAT's with this setup? What would you say the biggest benefit of this onfiguration is?
dandy ktm is offline   Reply With Quote
Old 04-13-2013, 12:55 PM   #772
Serkan
Member#: 180514
2004 Sti White
If a V mount is vented properly, I am sure IAT will be lower than a typical fmic.
In a V mount setup, the air is not only being pushed thru the IC fins (with speed) but it is also pulled by low pressure where the WRC vents opens up.
It is pull & push setup and will force more air thru the I/C core.
The air rushing out of the vent on top of the hood will also help with front lift at high speeds.
Much less piping means better spool up.
Old 04-13-2013, 03:07 PM   #773
TIGWERKS
Member#: 256615
Sysfailur-I'm not sure how he doesn't know. Chat with him on Facebook every now and again and post plenty of pics as I progress. I'm hoping to have the car shipped from CA to TX as I just moved so I can finish all the small things left on it.
Old 04-14-2013, 10:10 AM   #774
sidewayz
Member#: 5810
2001 S366 2.5RS
Lol you guys!!
I know you are doing one haha. You guys!!!!
Kelly how's TX so far?
sidewayz is offline   Reply With Quote
Old 04-14-2013, 10:20 AM   #775
sysfailur
Member#: 135993
2008 STi
AW
Bell 3.5x9x14 I believe.
I guess he does haha, anyway the car looks great. Lovely stuff!
Originally Posted by sidewayz View Post
Lol you guys!!
YOU DEVIL! You've told me/shown me nothing of this! We'll have to get some wiggins clamps next winter for mine. I was drooling at all the pics he's been taking the other night.
The Ultimate Auxiliary Lighting and Mount Thread Rapid_Roo Electrical & Lighting 6133 05-14-2013 12:16 PM
Brembo Caliper mounting threads slightly stripped what to do? dogfrndnew Brakes, Steering & Suspension 31 03-31-2013 11:20 AM
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 08:37 PM
Group N transmission mount threads JBravo920 Transmission (AT/MT) & Driveline 5 10-28-2007 10:17 PM
aftermarket seat mounting thread aspera Motorsports 8 12-05-2003 10:27 PM
Message Board Statistics All times are GMT -4. The time now is 07:50 PM.
