#26 |
Member#: 72195
Tri-State
Vehicle:2012 WRX GV SWP |
Sorry to revive a dead thread...
For the two wires going to column, can't i just use an ez-tap vs shoving wires into the harness? Was thinking so it doesn't fall out.
#27 |
Member#: 72195
Tri-State
2 wires go from relay to relay slot
1 wire goes from relay into the 7.5a fuse 1 wire goes from relay to harness (purple/yellow) 1 wire goes from harness (black- next to purple/yellow) into a ground Sound right? This mod will let me run fogs normally, run when stalk is on Fog-ON, and will turn off with car... im.assuming? |
#28 |
Member#: 325210
Does this allow the fogs to be on when high beams are turned on?
#29 | |
Member#: 325249
Tri-State
Vehicle:2012 wrx dgm |
did you ever get this to work for you man? |
#30 |
Member#: 273621
Tri-State
Vehicle:2013 WRX Limited SWP Hatch |
#31 |
Member#: 72195
Tri-State
Gonna do it again tomorrow. I had it working last time as a quick test but i never actually turned my car on and tried the features of the car running and DRL, Fog, etc. I'll update tomorrow. I made all the wires last time and still have them.
#32 |
Member#: 72195
Tri-State
Did it today. Works awesome! Took about 30 min
#33 |
Member#: 277915
MWSOC
Vehicle:2011 WRX Premium SWP, Stage 1 |
#34 |
Member#: 273621
Tri-State
#35 |
Member#: 325249
Tri-State
#36 |
Member#: 72195
Tri-State
I made a quick diagram if anyone needs anything
![]() Last edited by SNE2040; 12-17-2012 at 11:25 PM. |
#37 |
Member#: 333820
South East
Vehicle:2013 WRX Limited WRB |
Awesome, mod cant wait to do this.
#38 |
Member#: 333820
South East
Did this today, cost me 20 bucks since I did not have the connectors and wires. Though home depot did not have the right wire splices so for now I have a temp solution until I get the correct ones tomorrow but here are some pics.
This is on a 2013 I took off the steel reinforcement bar to gain better access, this picture has it removed you should see it when you take yours off. It just has two 10mm Bolts This picture also has the Relay Removed and Stalk's Harness Disconnected. I also completely removed the Dash trim as well which just pulls out and disconnected the wires to the Dimmer switches. When you Route wires to the purple/yellow and Ground make sure you have enough slack and no wires bind when you adjust the steering wheel through out its full range of motion. I also found that the second ground was unnecessary as it worked without it, but I wired for it so I am going to use it. ![]() ![]() And Yes Highbeams and Fogs work! ![]() Last edited by thescreensavers; 12-20-2012 at 02:03 AM. |
#39 |
Member#: 325249
Tri-State
only thing i noticed the Fog light dash light doesnt work when you just have the fogs on standalone
#40 |
Member#: 232010
Vehicle:2013 STI hatch SWP |
Hummm.... will tackle this !!
#41 |
Member#: 314986
SCIC
Vehicle:2013 WRX Dark Grey Metallic |
Doing this today!!
#42 |
Member#: 315631
Vehicle:2012 Impreza |
wow, i might try this on my 2012 impreza. where are y'all putting the relay when you done?
#43 |
Member#: 296527
Vehicle:2013 STI Hatch SWP |
I tried doing this today but I am having some problems. I followed the instructions and diagram exactly but now the fog lights or the running lights won't work. I used 18 gauge wire and checked my ground to a few locations, but to no avail. I did put the parking brake down. Also, there seems to be a noise coming from the engine bay, not sure if this is new.
Any help would really be appreciated. Thanks |
#44 | |
Member#: 72195
Tri-State
You checked your ground and no avail? Please be a tad clearer. Where did you ground yours to? You used vampire clips on the stalk harness? Did it actually make contact? Check your fuses to see if you accidentally didn't blow them out. Did you connect each relay pin to the appropriate relay slot? |
#45 |
Member#: 296527
I eventually got it figured out. The problem was when I connected the vampire clip to the harness the metal did not cut through the insulation.
