Old 02-21-2013, 01:56 AM   #1
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
Default Tigwerks Oil Drain Flange
Has anyone had any problems with the flange sealing to the back of the block?
I have everything on and its just leaking like no other right at the block. When I took out the oem drain tube it was really snug however when I placed the tigwerks in it seemed to be a sloppy fit as if it didnt seal correctly.
Im thinking of taking it back out and putting some high temp silicone to see if it will seal that way.
Any thoughts?
StIGC11 is offline   Reply With Quote
Old 02-21-2013, 02:29 AM   #2
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Silicone will not work with high temp oil. You have to watch out for the o-ring when you install it. Use some silicone grease and ease it in. I role an oring while in a hurry and it worked perfectly once I replaced it
Old 02-21-2013, 02:33 AM   #3
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
The oil is only reaching prob 220 degrees if that. The whole suby engine uses ultra gray to seal oil in I dont see why it wouldnt work here. But I will take it out and give it a look.
Old 02-21-2013, 03:42 AM   #4
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
By chance do you or anyone know what size the o ring is just in case it did get messed up on the install?
Old 02-21-2013, 05:29 AM   #5
Ballistic1350
Member#: 156877
04 sti
Pm tigwerks, he will definitely know
Ballistic1350 is offline   Reply With Quote
