Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 12-05-2011, 02:04 PM   #376
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
what was low boost on that run jeff?
john 1badSTI is offline   Reply With Quote
Old 12-05-2011, 03:21 PM   #377
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
Originally Posted by cnstman View Post
Nice driving! What tires do you run?
Hoosier drag radials. I had to tweak my rear camber because the sidewalls were rubbing on my coilovers so the rear is out of wack currently.
28psi tapering to 26psi. I didn't have any timing in it either since it was the first run on the motor and I wanted to do a shake down pass first. Not to mention I only have 300 miles on the motor
Crystal_Imprezav is offline   Reply With Quote
Old 12-05-2011, 04:09 PM   #378
CatfaceType-R
Member#: 81102
you sir, need a forward facing manifold...I can hopefully help with that within the next few months
Old 12-05-2011, 04:36 PM   #379
SurfGuruJeff
Member#: 148974
2010 STi Hatch
Glad I could film ya, Jeff.
On the way to the track I witnessed a Semi on the freeway almost flip with a strong gust... his back end started to kick out and tires were smoking, but he hung on to it.
And somehow I got in for free, haha...
SurfGuruJeff is offline   Reply With Quote
Old 12-05-2011, 08:51 PM   #380
Layvon
Member#: 195711
STi 04/05/06/07
Imprezzive
Corny, but fitting for your login Jeff. Congrats on getting it going and good pass too. I don't know how much the wind affects it, but has to be quite a bit.
Makes me excited for my EFR build that is 1/4 of the way complete right now!!
Layvon
Old 12-05-2011, 09:11 PM   #381
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Put in some nitrous Jeff just a 70 shot on same boost, the new year is gonna come and we need to see that car deep in the 9s!! I am sure you can tune nos and turbo on e85 and show why a sleeved block is not needed!!
Or you can try 35 psis and see what`s capable on boost only... Good luck man.. car is running strong!
DJIMPREZA is offline   Reply With Quote
Old 12-05-2011, 11:27 PM   #382
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
Lol, I would never run nitrous on stock sleeves. If I had a sleeved block I would probably try a 50 shot.
The car went [email protected] in the eighth at 32psi before it broke a valve seat and it still went [email protected] at that. With that 1/8th mile, it definitely has around a 9.7 as is on only boost which I intend to reach. Just need the weather to cooperate. Believe it or not, my car actually runs/hooks much better when it is hot out
Keep in mind I am still on the stock 05 tranny. If I went to an 07 tranny or rallispec gears, I would pick up around 5-6mph off the bat and .3-.5 seconds as well not having to go into 5th .
Old 12-06-2011, 12:55 AM   #383
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
good stuff. you are doing it well.
Old 12-06-2011, 02:50 AM   #384
SurfGuruJeff
Member#: 148974
2010 STi Hatch
Exactly... I hate watching you hit that wall that is 5th gear. I see slower ET's in '07s, but higher traps... grrr.
Maybe we learn how to install '07 gears....
Old 12-06-2011, 07:48 AM   #385
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
the rallispec gear set is tempting against the 7 sti, I have used it on a 05 sti build and made 10.8s easily on our slow/heavy track
Old 12-06-2011, 08:12 AM   #386
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Nice work Jeff.
No Limit Motorsport is offline   Reply With Quote
Old 12-06-2011, 10:27 AM   #387
SW00P_G
Member#: 5591
EJ257 Gt35r
That's really not that fast if you really think about it! j/k
SW00P_G is offline   Reply With Quote
Old 12-06-2011, 10:42 AM   #388
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
not tempting... it's recommended! Hold 4th gear to 9000rpms!
Old 12-06-2011, 11:57 AM   #389
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
True, not for my standards
Old 12-06-2011, 12:24 PM   #390
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
or more
Old 02-01-2012, 07:32 PM   #391
SW00P_G
Member#: 5591
EJ257 Gt35r
Hey, just thought I would stop by and ask how it's going!!!???
Old 02-01-2012, 09:36 PM   #392
TwinscrollGT35R
Member#: 256810
What about running a taller tire? Would that help hold out going into 5th? Should help with traction anyways.
TwinscrollGT35R is offline   Reply With Quote
Old 02-25-2012, 04:27 AM   #393
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Isn't high compression going to raise back pressure unless you run a larger turbo?
spoolinsti05 is offline   Reply With Quote
Old 11-26-2012, 10:27 AM   #394
tabm0w
Member#: 265198
Any updates on the car?
tabm0w is offline   Reply With Quote
Old 02-21-2013, 03:25 AM   #395
neuroraptor
Member#: 347777
Off boost is a little peppier but not much really. Retuning the off boost was a PITA but I guess that means I picked up some off boost response.
Torque is a function of power therefore less power means less torque. It does not spool any faster than before but this could also be due to my cam switch. Although given that I did a cam change plus the higher compression, I should easily be making more power. Theorectically that is...
diesels run high compression and usually make loads more torque than horsepower...
neuroraptor is offline   Reply With Quote
Old 02-21-2013, 07:39 AM   #396
Homemade WRX
Member#: 33782
96 bastard child
apples and oranges are fruit but oranges usually are way juicier...
Yes, you are right but for completely different reasons.
Old 02-21-2013, 11:42 AM   #397
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Late 70's big block v8s run low compression and make loads more torque than horsepower. Maybe we should all lower our compression ratios to make more torque. Just run some deck plates under the heads and kill the autocross course with all those torques!
tachrev is offline   Reply With Quote
Old 02-21-2013, 12:54 PM   #398
Homemade WRX
Member#: 33782
96 bastard child
Ok, to not be so sarcastic and even ignoring combustion, power is a function of torque and RPM. Note the operating speeds of auto ignition engines (diesels) and 70's big blocks and then that of a modern performance gas engine. You'll notice that Hp and ft-lb always cross at 5252 rpm (won't get into the explanation) but that below 5252 rpm, torque will be greater than power and vise versa.
So if the engine never revs beyond that speed (in units of HP and lb-ft), it is impossible to have more power than torque.
Old 02-25-2013, 02:04 PM   #399
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
^^ This.
Squidz is online now   Reply With Quote
Old 01-16-2014, 09:39 PM   #400
Mastuss3055
Member#: 334085
I have looked into building a high cr on my 2010 wrx but decided not to.. but as to your worry about the 80-100whp diff this is do to your change in cr. Im sure if you compare both graphs you will notice that you have more gain in the low and mid range where as you lost on the top. I did not catch what turbo you are running. A high cr ratio build is not for top end power in the ej series motors.
Mastuss3055 is offline   Reply With Quote
High compression e85 big bore questions 5lipstream Built Motor Discussion 4 07-02-2011 09:39 PM
Wtb sti window spoiler and a big turbo neversummer489 NWIC Private Classifieds 10 03-04-2010 09:52 PM
FS: NC My 2001 RS w/ High compression motor, and other parts Whiteghost 2.5 Private Vehicle 'For Sale' Classifieds 23 10-17-2009 09:16 PM
Big boost, big cams, high compression? Drink Built Motor Discussion 18 03-13-2007 06:02 PM
