Old 02-20-2013, 12:01 AM   #1
upsguy04
Member#: 344026
02 wrx wagon
Default Ej207 stroker help
I just got quoted and wasn't sure if it was a fair price and if the build was put together correctly (parts) Any help will be greatly appreciated Thanks
2.1 Stroker Short block With Forged Pistons, H Beam Rods, New Heat Treated Crankshaft, and race bearings $2500
OEM Gasket Set $250
Valve Job, Adjustment, and Resurface $350
+1mm valves $360 for Supertech Stainless Intake and Nitrated Exhaust
Bowl Blending for +1 Valves $160
Supertech Dual Valve Spring Kit $350
Cams ?
Timing Belt Kit With Water Pump $350
Labor To Install Heads, oil Pan, and Timing $400
I highly recommend ARP head Studs $190 and a killer B Oil Pickup $160
upsguy04 is offline   Reply With Quote
Old 02-20-2013, 06:46 AM   #2
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Seems like good prices. Reuse stock cams if they are fine. No need for aftermarket unless like 500whp or more application
cosseywrx is offline   Reply With Quote
Old 02-20-2013, 07:51 AM   #3
upsguy04
Member#: 344026
02 wrx wagon
If I could X anything out or substitute parts what would you recommend? My bug eye is a daily driver
Old 02-20-2013, 06:00 PM   #4
cosseywrx
Member#: 276443
Idk man. I have a 2.1l stroker so i got alot of the same parts. Search my name and you will find my build thread. 05 rex is begining name of the thread
Old 02-20-2013, 07:56 PM   #5
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
As above would stick with the OE cams(JDM heads are awesome and many people running them in high bhp without the issue)
We are run OE JDM WRX AVCS cams on our 2.1L(at 490bhp* 420whp) at this level has been little bit lazier
If you are will be going with the cams,I can only recommend Kelford V2-199-C
Jura
jura11 is offline   Reply With Quote
Old 02-21-2013, 12:14 PM   #6
Computersare8ad
Member#: 287080
2000 Fozz
Blaaaaaack
What pistons are you going to be running?
Computersare8ad is offline   Reply With Quote
Old 02-21-2013, 01:04 PM   #7
cosseywrx
Member#: 276443
I run manley in mine.
My stroker is a noisy motor. I also run solid mounts so i feels it all!!!
