Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 02-19-2013, 12:26 PM   #2826
Laexreme5
Member#: 315264
i was looking at the ga3r and you can only get down to a +20 offset. are you going to be running spacers to make up for the extra 12mm? and i know people have molded them on 04-07s but i have never seen someone even put someon an 08+
Laexreme5 is offline   Reply With Quote
Old 02-19-2013, 05:45 PM   #2827
thewhiteknyt
Member#: 336644
GRB WRX
WR Blue
When its there's too much ice or too much snow. I've always got my Blizzaks
thewhiteknyt is offline   Reply With Quote
Old 02-20-2013, 02:17 PM   #2828
TheBobMan46
Member#: 322824
2005 WRX
Do you have stock suspension other then the yellows? Any rubbing?? I have an 05 wrx, looking for this size tire, and curious....
Originally Posted by 05bluesti View Post
255/40/17 NT05 on STi BBS's
Running RCE Yellows
not that meaty
TheBobMan46 is offline   Reply With Quote
Old 02-20-2013, 02:33 PM   #2829
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
On the 05 WRX you'd need to roll the rear fenders to avoid rubbing on the fender.
Being 5x100 you don't have a quick and easy 17x8 +53mm wheel, but a 17x8/8.5/9 +45mm with a 255/40/17 can work on lowering springs when the appropriate fender work is complete.
Old 02-20-2013, 02:35 PM   #2830
05bluesti
Member#: 251804
05 WRB STi
just the springs, camber is 1.8 front, 1.5 rear, no rubbing anymore after getting new fender liner
05bluesti is offline   Reply With Quote
Old 02-20-2013, 04:42 PM   #2831
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I don't have any firsthand experience, but won't you have (or be close to) strut interference issues at 17x9+45 with a 255?
Old 02-20-2013, 04:55 PM   #2832
SlverEJ20
Member#: 157158
05 WRX stage 2
.....Yeah wrong thread
SlverEJ20 is offline   Reply With Quote
Old 02-21-2013, 01:40 PM   #2833
TheBobMan46
Member#: 322824
2005 WRX
I'm actually looking at the 17x9 Rota Grids with 255/40/17, if that makes any difference. I'm gonna roll the fenders, my main concern is the rubbing and I want to be able to drive the car like it's intended, not cruise slowly for fear of the tires/wheels hitting
Old 02-21-2013, 02:06 PM   #2834
WRX8XB
Member#: 45323
Depends on the suspension, stock struts? No. You can run a 275 V710 at a +48mm offset pinched on an 8" wheel. Running a 255 on a 9 at a lower +45mm offset is indeed possible on the stock struts. (regarding in board clearance).
More info:
Fender Mod how to: with 18x9 +45mm and 255/35 on stock struts and cobb springs
Going to coilovers can pose a problem depending on spring length, spring diameter, strut diameter, # of locking collars etc.
I know RCE T2s and KW V3s are capable of running a 18x9 +45mm with a 255/35/18 without issue inboard.
I'm actually looking at the 17x9 *** Grids with 255/40/17, if that makes any difference. I'm gonna roll the fenders, my main concern is the rubbing and I want to be able to drive the car like it's intended, not cruise slowly for fear of the tires/wheels hitting
Yes, that makes a critical difference. A wider wheel and lower offset will alter the amount of fender work, camber required to fit.
Are you looking at the +42mm offset?
Old 02-21-2013, 02:20 PM   #2835
TheBobMan46
Member#: 322824
2005 WRX
yeah the +42 offset. Mine is a 2005 WRX btw. Would that be alright with just lowering springs or even stock still? I don't know whether that will hit or if I need coilovers for the fit. If I got coilovers they'd be cheap, so that makes the decision tough. Also just to get an accurate height with lowering springs makes me nervous, I don't want 'hellaflush' but I want the car to sit right with no rubbing, hitting, etc.
Old 02-21-2013, 02:55 PM   #2836
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
More info:
Thanks for that link- directly relevant to what i'll be doing with the wagon this weekend.
Old 02-21-2013, 03:07 PM   #2837
WRX8XB
Member#: 45323
Hopefully you'll be installing the 05+ Rear flare to cover up the beating the fender will be getting.
to stay on topic
-T3h_Clap
Old 02-27-2013, 09:37 PM   #2838
mhwrx02
Member#: 174582
2005 STI
mhwrx02 is offline   Reply With Quote
Old 02-27-2013, 09:56 PM   #2839
mhs5074
Member#: 184485
'06 STi AW
'08 FXT Sport 4EAT DGM
Looks good ^^ What's the wheel specs??
mhs5074 is offline   Reply With Quote
Old 02-27-2013, 10:01 PM   #2840
mhwrx02
Member#: 174582
2005 STI
18x10 front +22, 15mm spacer for brembos, 285/30 tire. 18x11 +7 rear, no spacer, 295/30 tire
Old 02-27-2013, 10:47 PM   #2841
WRX8XB
Member#: 45323
you're running a 285/30 front and 295/30 rear?
Did you convert to RWD? Or have a savings account to buy a new center diff?
Old 02-27-2013, 10:51 PM   #2842
mhwrx02
Member#: 174582
2005 STI
the rolling diameter difference is less than 1%. The center diff tolerances, recommended by subaru, are a variance of no more than 4%. Thanks for the input though!
Old 02-27-2013, 11:25 PM   #2843
WRX8XB
Member#: 45323
Where are you seeing the 4% figure?
I've seen multiple sources saying .25" difference to circumference is the highest allowable difference.
the 285/30/18 at 77.9" and 295/30/18 at 78.5" has a .6" difference in circumference. This is well past the .25" circumference difference.
Am I missing something?
Old 02-27-2013, 11:48 PM   #2844
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Compared to those, mine aren't meaty, but I just got some Federal 595 RS-R's mounted onto 17x9" RPF1's. They're quite a wide 255 compared to what I've seen in the past. Looking forward to actually trying them in a few months.
Old 02-27-2013, 11:48 PM   #2845
mhwrx02
Member#: 174582
2005 STI
http://www.1010tires.com/tiresizecal...?action=submit
this is what i went by. After consulting with a subaru tech, I was given the answer that as long as the circumference is within 4% (1973.3/1991.6=.9908%)
Old 02-28-2013, 12:09 AM   #2846
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Meat wagon is finally coming together. Not sure you can tell in this pic but 255 SS595s are actually wider than my RA mudflaps.
Old 03-01-2013, 12:37 PM   #2847
bdj238
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
just saw this on Garrett Turbo FB page...
I'd say thats serious meat!
bdj238 is offline   Reply With Quote
Old 03-01-2013, 12:43 PM   #2848
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Holy Intercooler batman!!!
more of my meats:
Old 03-01-2013, 12:44 PM   #2849
Laexreme5
Member#: 315264
That intercoolers is as big as a a smart car!
Old 03-12-2013, 11:32 PM   #2850
mhs5074
Member#: 184485
'06 STi AW
I got a question for you meaty folks: I recently got some karlton flares with 10 inch wide wheels and I want to run a 295/35/18 tire, has anyone done this with success or is it going to be too tall like I've been hearing from everyone?
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
