Old 02-21-2013, 12:05 AM   #1
Lauder229
Member#: 341460
2004 WRX
Default Epic fail, door speaker install.
So I wanted to upgrade my door speakers for a little more bump and bought 6.5" kicker door speakers for the front. I took off my door panel, and then took of the factory sub. I cut the plug and wired in the kicker.
This is the moment I realized that this speaker will not fit. The stock speaker has a big three screw frame that screws in, this speaker had 4 screws in which only one hole would line up. The hole is smaller than the ones in the door so I couldn't even do one without drilling the crap out of the speaker. I then tried drilling them into the door (I got pissed) and didn't even scratch the surface. Said hell with it and put the factory one back on and door back on. SOMEONE PLEASE HELP! I have no clue what I did wrong or if these speakers just aren't compatible with my 2004 wrx. Feed back is appreciated as I am probably taking them back.
Lauder229 is offline   Reply With Quote
Old 02-21-2013, 12:18 AM   #2
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
most audio install stores sell spacers that can go btwn the aftermarket speaker and the door panel to allow easy install and clearance for window to travel up/down.drilling an extra hole or two may be required at times. have patience you can make it work. might want to see if it will even fit behind your doorcard once installed. good luck and have patience
krambte79 is offline   Reply With Quote
Old 02-21-2013, 02:16 AM   #3
tkturboh4
Member#: 145213
2004 WRX Wagon 5spd
Which Kicker model are they? Hopefully they're thin enough to fit in there. The 04's are quite cramped in the front speaker locations. Something like these should do the trick for you: http://www.paranoidfabrications.com/...-spacers-pair/ or http://www.car-speaker-adapters.com/items.php?id=SAK026
tkturboh4 is offline   Reply With Quote
Old 02-21-2013, 12:20 PM   #4
Lauder229
Member#: 341460
2004 WRX
I gave up, I think I just taking them back today. I am getting a kicker 12" L7 sub Saturday.
Old 02-21-2013, 02:42 PM   #5
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
how is that a replacement for a 6.5" door speaker?
you just need speaker adapters to make those work.
Old 02-21-2013, 03:01 PM   #6
luan87us
Member#: 335013
2013 Premium WRX 5dr
Contact Patrick at subaruaudio.net for a set of spacers to put them in your car.
Old 02-21-2013, 03:50 PM   #7
Lauder229
Member#: 341460
2004 WRX
Do the spacers help screw them into the door? Because they just don't have the same frame the stock ones have to put them in, like the three holes.
Old 02-21-2013, 04:19 PM   #8
luan87us
Member#: 335013
Yeah the spacers help you mount the speakers to the doors and help you create enough space so you windows can roll down.
Old 02-21-2013, 04:28 PM   #9
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
you'll need to build rings to space them out. 3/4 should do it... but I needed 1"
Cefaln452 is offline   Reply With Quote
Old 02-21-2013, 04:45 PM   #10
chris07sti
Member#: 177312
2005 STI
Aspen white
chris07sti is offline   Reply With Quote
Old 02-21-2013, 08:43 PM   #11
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Once you screw spacers to the door it doesnt matter if the speaker has 16 screw holes, you screw into the spacer..
Old 02-21-2013, 09:01 PM   #12
fastfive09
Member#: 169597
2011 WRX Sedan
If you do end up building spacers, make sure you seal the wood properly. Water got to mine and the MDF split into a thousand pieces, ended up causing a short in my speakers which is how I found out.
fastfive09 is offline   Reply With Quote
Old 02-21-2013, 09:20 PM   #13
dirty wrx
Member#: 347872
dirty
Try crutchfield.com. I have 6.5" kenwoods in my front doors and 4" in the rear doors. Rears bolted right up but the front had a good size bracket adapter, or spacer, whatever you choose to call it.
dirty wrx is offline   Reply With Quote
Old 02-21-2013, 10:27 PM   #14
SubbieDubbieDo
Member#: 345810
Find a weebee audio, generally the will take you to the cleaners on install, but talk it up with one of the techs, spacers usually work best in this situation, drope the speaker into the spacer, then the wholes in the door panel will line up with the spacers...problem solved. Enjoy the new beats
SubbieDubbieDo is offline   Reply With Quote
Old 02-22-2013, 12:35 AM   #15
Vandelay
Member#: 336306
The factory speakers actually make excellent spacers. if you cut the speaker out of the plastic frame and dremel off the backing, you'll be able to mount your new speakers with the supplied trim rings to the frames and use the factory holes and mounting hardware to reinstall. I did a set of bostons recently in my GD:
Vandelay is offline   Reply With Quote
Old 02-22-2013, 11:16 AM   #16
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Vandelay - thats exactly what I did in my 07' impreza.. they worked great as spacers and wernt that hard to break out. When I sold the car I removed my nice speakers and bought some cheap on sale pioneers to throw in and noone noticed on the trade in.
MtnXfreeride is offline   Reply With Quote
Old 02-22-2013, 11:31 AM   #17
Omie
Member#: 331611
2013 Wrx 5dr
i did the same thing in mine as well
Omie is offline   Reply With Quote
Old 02-22-2013, 11:49 AM   #18
Orangejuice
Member#: 335717
http://www.car-speaker-adapters.com/index.php
I just got a pair of those to keep my new jl c2 525's securely in the factory speaker holes. They also pull the speaker out enough to let me roll my window down now. I'm pretty sure they also make adapters for 6.5" speakers too.
Orangejuice is offline   Reply With Quote
Old 02-23-2013, 10:25 AM   #19
mejifair
Member#: 11356
2012 WRX STi Hatch
Yea - I am confused...are you trying to install a sub into your door? The L7 definitely will NOT fit in your 6.5" spot in the door
And the spacers are really the way to go. Depending on the depth of the ones you bought, you may need to get a thicker spacer, but it should work just fine.
And instead of cutting your harness, just buy the Metra adapters so you can leave the stock harnesses intact.
mejifair is offline   Reply With Quote
Old 02-25-2013, 09:53 AM   #20
Lauder229
Member#: 341460
2004 WRX
No I am keeping factory speakers until I can get a pro to do it, and I got a 12"L7 for bumping till then.
Old 02-25-2013, 09:55 AM   #21
Lauder229
Member#: 341460
2004 WRX
L7 in the trunk for the difficult people. Ha if I could out that in my door it would fall off from the bass hahaha it's so effin loud.
Old 02-26-2013, 09:03 PM   #22
phenryiv1
Member#: 91212
2011 WRX 5DR
Double post
Old 02-26-2013, 09:06 PM   #23
phenryiv1
Member#: 91212
2011 WRX 5DR
Old 02-28-2013, 08:40 AM   #24
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Kartboy/factory combo...
Old 02-28-2013, 04:03 PM   #25
jhsellers
Member#: 333484
2002 Impreza Outback
Aaron, what kind of connection have you made to those drivers? It looks like something that needs a wire nut added.
John
jhsellers is offline   Reply With Quote
