Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 02-20-2013, 07:43 PM   #1626
b3delta
Member#: 242814
2003 WRX
Midnight Black Pearl
yeh it just shimmied out of its bolts and was climbing out from under the car about to stick a nail into the compressor when I grabbed it. "No, bad awesome turbo, bad!" He said "but the engine says I suck" and I'm like "it's ur job, suck squeeze blow. Like a cheap hooker!"
b3delta is offline   Reply With Quote
Old 02-20-2013, 09:05 PM   #1627
CalvinT
Member#: 329025
2002 WRX Wagon
Originally Posted by labcoat View Post
the reason I asked is seems like more then a few haven't lasted.
R-
If you go back to 35 or so, you'll find many of failed turbos were made by a company that used a custom compressor. They didn't use the Mitsubishi compressor.
The Blouch 19T turbos have a good reputation. So did the Deadbolt ones when he was still making them.
CalvinT is offline   Reply With Quote
Old 02-20-2013, 09:30 PM   #1628
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
thanks
labcoat is offline   Reply With Quote
Old 02-21-2013, 03:20 AM   #1629
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
I have a td04hl-19t I used to break in my motor 1k miles pm if interested.
Old 02-21-2013, 04:43 AM   #1630
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
a friend of mine had a well modded 05 wrx with the 19t....wasnt any faster than my stock turbo, tuned, tbe 06 wrx
meh
Uncle Scotty is online now   Reply With Quote
Old 02-21-2013, 10:36 AM   #1631
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
meh
I read all the stories about 300whp and thought I would try it.tune it right after break in no where close. I gained 40 hp, wow.
Old 02-21-2013, 11:19 AM   #1632
b3delta
Member#: 242814
2003 WRX
what size injectors u running?
my gain was about 40 whp, but i'm not at the limit yet, got room left for the injectors and turbo, just at 400chp with a ej205 don't wanna play any games until i'm ready for a motor build. Granted my car is under 2850 lbs, which could be partly for why I'm gettin such results.
Old 02-21-2013, 08:36 PM   #1633
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
For the td04hl-19t I ran 565's. For the 20g I ran 720's. For the 2.5 xtr I run modded stock flowing 815 with meth.
Old 02-21-2013, 08:58 PM   #1634
b3delta
Member#: 242814
2003 WRX
yeh u were at the limit for those injectors with the 19T
Old 02-21-2013, 11:28 PM   #1635
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
No not even close.
Old 02-22-2013, 08:38 AM   #1636
b3delta
Member#: 242814
2003 WRX
Then your tune was too conservative, that turbo will be pushing its limit with some 850cc injectors. With 565, you might as well keep the 13T. Like I said, I'm runnin 650s and am pushin em to bout 620/min, and the 19T will keep goin.
I realize it's a moot point as you have already moved to a different turbo and stuff, just want the info out for others lookin at the 19T.
Old 02-22-2013, 11:30 AM   #1637
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
If you have a good pnp job done that hogs out the snail in the right places and then pop on an external gate you could maybe get close to 300WHP. Otherwise just a dream for anything to get close to 300WHP with a 6 cm housing and internal gate. Even small 16G's and 7 cm housings don't get to 300WHP on 2 liter motors.
Anyone who claims 300WHP with a 19T I want to see some data with MAF logs etc. Show me a 19T pulling 4.6V+ with an internal gate on a 2 liter, just one. Best I've seen so far is 4.4 posted. Getting tired of the BS really, this is not a 300WHP turbo not even close in a normal setup...
soobaviator is offline   Reply With Quote
Old 02-22-2013, 01:00 PM   #1638
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Im with you. I had cams, meth, stroked and 240 whp thats it.
Old 02-22-2013, 02:00 PM   #1639
b3delta
Member#: 242814
2003 WRX
I can't post attachments, PM email and I'll send my log
I was at 260 on the 13T
Old 02-22-2013, 04:14 PM   #1640
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
No need to post it as an attachment just post the excel or CSV of the logs. Wanna see 260 on a 13T as well with MAF values. Sounds like a real optimistic dyno to me.
Old 02-22-2013, 04:25 PM   #1641
b3delta
Member#: 242814
2003 WRX
cant figure out how to post it, can't browse my hard drive
i don't have a log of my 13T, and to correct my whp its 298
Old 02-22-2013, 04:59 PM   #1642
eg33GC
Member#: 206851
56 Belair
Pro Street
my 2 liter would have to disagree, by the tune of about 20whp over 300
eg33GC is online now   Reply With Quote
Old 02-22-2013, 04:59 PM   #1643
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Dyno and airflow... It's pretty simple
Code:
 paste spreadsheet
Or just post the headers of the logged parameters and the peak values.
Old 02-22-2013, 05:07 PM   #1644
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Dyno and airflow... I would be expecting something over 4.7 MAFV V on the stock MAF for that power level. My old setup ran more than that with a fully built 2.1 stroker PnP heads, STI cams and EWG on the small 16G. Internal gate, stock motor I don't see how it gets there
Old 02-22-2013, 05:40 PM   #1645
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Gotta luv liberal dynos. My stroked, 272 cammed, meth, elh. tbe, 800 injectored, pnp heads, ported intake, pnp throttle body, tvg delete on a fp td06-20g only made 325/325. I guess I should go back to a td04.
Old 02-22-2013, 05:43 PM   #1646
b3delta
Member#: 242814
2003 WRX
yeh just writing "paste spreadsheet" does nothing for me
Old 02-22-2013, 05:48 PM   #1647
b3delta
Member#: 242814
2003 WRX
weight of the car and occupants matters. 2 cars with exact same power adders, one weighs 3100 lbs and one weighs 2900 lbs. Gonna measure differently. Not to mention what level of "smoothing" they have it set on. 1 click of smoothing can drop around 40 hp off the chart
Old 02-22-2013, 05:59 PM   #1648
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
The number of people in the car does not change the airflow into a motor... Does not change timing or boost. Who cares about the chart we want to see data.
To paste an excel spreadsheet type "code" in brackets then paste the sheet then type "/code" in brackets at the end.
Old 02-22-2013, 06:02 PM   #1649
b3delta
Member#: 242814
2003 WRX
Code:
Time	A/F Correction #1 (%)	A/F Learning #1 (%)	Engine Load (Calculated) (g/rev)	Engine Speed (rpm)	Feedback Knock Correction* (degrees)	Fueling Final Base* (estimated AFR)	IAM* (raw ecu value)	Ignition Total Timing (degrees)	Injector Duty Cycle (%)	Intake Air Temperature (F)	Knock Correction Advance (degrees)	Mass Airflow (g/s)	Mass Airflow Sensor Voltage (V)	Vehicle Speed (mph)	Coolant Temperature (F)	Throttle Opening Angle (%)	Manifold Relative Pressure (Corrected) (psi)
0	0	0.78	1.06	2208	0	12.7	8	27	10.36	113	3.5	37.55	2.52	30	187	100	0.44
265	0	0.78	1.06	2240	0	12.83	8	25.5	10.99	113	3.5	39.62	2.58	30	185	100	1.02
546	0	0.78	1.11	2273	0	12.77	8	23.5	11.29	113	3.5	41.92	2.64	30	185	100	1.6
811	0	0.78	1.13	2420	0	12.87	8	22.5	12.39	113	4	44.56	2.68	31	185	100	2.03
1092	0	0.78	1.17	2456	0	12.76	8	21	13.1	113	4	47.8	2.72	31	185	100	2.47
1373	0	0	1.23	2491	0	12.89	8	20	13.28	113	4	50.65	2.78	32	187	100	2.9
1654	0	0	1.26	2566	0	12.9	8	19.5	14.24	113	4	53.15	2.8	32	185	100	3.19
1919	0	0	1.25	2647	0	12.92	8	19	14.68	111	4	56.87	2.82	34	185	100	3.63
2200	0	0	1.29	2723	0	12.92	8	18	15.5	111	4	60.19	2.9	35	185	100	4.21
2465	0	0	1.38	2784	0	12.92	8	16.5	16.63	111	4	64.18	2.96	35	185	100	4.79
2746	0	0	1.46	2868	0	12.81	8	15.5	18.35	111	4.5	68.81	3.04	37	185	100	5.37
3011	0	0	1.57	2904	0	12.56	8	14	19.82	111	4.5	75.95	3.14	37	185	100	6.38
3276	0	0	1.67	2995	0	12.17	8	13.5	22.36	111	4.5	82.95	3.2	38	185	100	7.4
3557	0	0	1.74	3113	0	11.79	8	13.5	24.57	111	4.5	89.73	3.3	38	185	100	8.42
3838	0	0	1.84	3205	0	11.48	8	13	27.35	109	4.5	95.31	3.36	40	185	100	10.01
4103	0	0	1.97	3282	0	11.13	8	12	31.51	109	4	107.49	3.5	42	185	100	11.32
4384	0	0	2.04	3409	0	10.92	8	11.5	34.91	109	3.5	117.16	3.58	42	185	100	12.91
4649	0	0	2.34	3518	0	10.79	8	11	39.77	109	3.5	133.07	3.74	45	185	100	14.8
4930	0	0	2.45	3628	0	10.69	8	11.5	44.89	109	3.5	147.44	3.9	45	185	100	17.27
5195	0	0	2.75	3749	0	11.17	8	12	48.26	109	3.5	167.11	3.98	47	185	100	19.3
5476	0	0	2.42	3958	0	11.12	8	12.5	52.34	108	3.5	169.79	4	50	185	100	19.59
5757	0	0	2.4	4045	0	11.05	8	13	49.19	108	4	161.82	3.92	50	185	100	17.85
6022	0	0	2.37	4225	0	10.88	8	13.5	50.47	108	4	163.74	3.98	53	185	100	17.12
6303	0	0	2.52	4325	0	10.79	8	14	55.36	108	4	179.68	4.04	53	185	100	18.28
6568	0	0	2.59	4467	0	10.84	8	14	59.08	108	4	193.03	4.18	57	185	100	19.44
6849	0	0	2.46	4610	0	10.96	8	14.5	59	108	4	194.48	4.16	57	185	100	19.15
7129	0	0	2.38	4768	0	10.9	8	15	58.99	106	4	190.14	4.16	60	185	100	17.7
7395	0	0	2.45	4876	0	10.86	8	16	60.34	106	4.5	198.25	4.18	63	185	100	17.85
7675	0	0	2.51	5013	0	10.83	8	16.5	64.17	106	4.5	207.56	4.24	63	185	100	18.28
7941	0	0	2.5	5186	0	10.81	8	17	67.49	106	4.5	217.03	4.3	66	185	100	18.57
8221	0	0	2.51	5342	0	10.81	8	17.5	68.03	106	4.5	220.33	4.34	66	185	100	18.28
8487	0	0	2.49	5478	0	10.86	8	17.5	70.12	106	4.5	226.95	4.36	69	185	100	17.99
8767	0	0	2.44	5593	0	10.78	8	18	70.39	104	4.5	228.19	4.38	69	185	100	17.7
9064	0	0	2.44	5703	0	10.83	8	19	71.78	104	4.5	231.5	4.4	73	185	100	17.27
9313	0	0	2.41	5805	0	10.82	8	19	71.82	104	4.5	233.56	4.42	76	185	100	16.83
9594	0	0	2.37	5924	0	10.88	8	19.5	72.04	104	4.5	234	4.42	76	185	100	16.4
9859	0	0	2.34	6048	0	10.83	8	20	73.54	104	4.5	236.99	4.42	79	185	100	15.96
10140	0	0	2.33	6198	0	10.89	8	20.5	74.05	104	4.5	239.59	4.42	79	185	100	15.82
10421	0	0	2.28	6271	0	27.77	8	23	64.21	104	4.5	237.85	4.42	81	185	40.78	14.22
10686	0	0	1.32	6271	0	12.91	8	30.5	45.48	102	2	138.21	3.7	83	185	12.94	0.58
10967	0	0	0.91	6206	0	12.43	8	40	30.21	102	2	104.27	3.32	83	185	4.71	-7.55
Old 02-22-2013, 06:04 PM   #1650
b3delta
Member#: 242814
2003 WRX
No it doesn't change airflow into the motor, but it's simple physics, it's easier for the engine to move with less weight than with more weight. This applies to off the dyno as that's where stuff matters and the car actually moves. Your car can dyno 900000 hp but on the road it could only be 4 hp.
That tune right there is an 03 dropped to 2835 lbs with 450 lbs of stuff, me, and my tuner in it. = 298 whp
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
