Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 01-29-2013, 02:02 PM   #1
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
Default EJ20G detonation
Hey guys, so I have a 95 sti ra ej20g closed deck. It's running robs 550 tune with 16 psi boost. At peak boost I am having pretty consistent detonation. I am running yellow injectors and a walbro 255 fuel pump. This motor was built around 8000 km ago, runs well and pulls hard just at this higher boost getting detonation. I don't believe this is a fuel deliver or fuel issue as I only use 94 Octane from chevron in Canada. The catch can is brand new as well....I'm out of ideas here guys not an expert by any means but trying to learn. Should I run a colder plug perhaps? I might just turn my boost down in the meantime as I have a grimmspeed manual boost controller, and see if that helps any. Thanks in advance for any advice.
coupe-a-loop is offline   Reply With Quote
Old 01-29-2013, 02:07 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
stock coil packs i assume?
is your CEL blinking?
Old 01-29-2013, 02:11 PM   #3
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
No actually 2002 coilpacks. CEL blinks yes but only at high boost. I can't even distinguishably hear the knock...although my ear isn't well trained, and the exhaust drowns every other sound out with ease.
Old 01-29-2013, 02:36 PM   #4
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
Hm, after reading the sticky on coil conversion it sounds alot like what rob experienced before he converted. I know for a fact these are converted to 2002, I did not build the motor however I know who did and know the care that was taken on this build. I suppose its possible these new 2002 are now shot?
Old 01-29-2013, 05:03 PM   #5
AgentJ17
Member#: 306411
1995 STi RA
very eg33 such braap
Misfire and knock are two entirely different things. Failed coilpacks will cause a misfire. Rob's tune will trigger the CEL when the car detects knock.
You should be able to run a full 18psi with Rob's tune. Maybe get a wideband kit on your car to verify it's getting enough fuel? I think the wrong heat range and gap in spark plugs can cause knock.
AgentJ17 is offline   Reply With Quote
Old 01-30-2013, 03:08 AM   #6
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
any recommended plugs? I guess it would help to know what I'm currently running. I'll try and pull one in the next couple days I'll be quite busy though. I tried to contact rob, but alas, hes a busy man.
Old 01-30-2013, 07:57 AM   #7
Poppie
Member#: 262422
1998 V4 Type R
Feather White
NGK PRF7B is normally used here in the UK.
Perhaps the knock sensor may need checking/replacing?
Poppie is offline   Reply With Quote
Old 01-30-2013, 04:24 PM   #8
AgentJ17
Member#: 306411
1995 STi RA
I'm pretty sure I'm running NGK BKR6E's (one step hotter than 7's) with about a .027" gap on each. Was running about 15.5psi on Rob's 550 tune until I threw a rod... But up until then, I didn't see the CEL blink once.
Old 01-30-2013, 05:15 PM   #9
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
Well for what it costs I will try replacing plugs. How likely is it that the knock sensor is malfunctioning? I really don't wann assume that until all other possibilities are explored.
Old 01-30-2013, 05:46 PM   #10
Poppie
Member#: 262422
1998 V4 Type R
Feather White
You could always remove the knock sensor and give it a clean as they can suffer corrosion but I can't say how likely it is to be failing sorry.
Old 02-14-2013, 04:12 PM   #11
JFImport
Member#: 284597
Check to make sure nothing is rattling. I had this Same issue until i found out That an exhaust hanger was bust off and was vibrating at higher rpms.
JFImport is offline   Reply With Quote
Old 02-14-2013, 07:03 PM   #12
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
And that was tripping the knock sensor? Worth looking into for sure.
Old 02-15-2013, 01:15 PM   #13
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Also check for a rattling uppipe heatshield. Caused false knock readings on my car.
JDMFLCL is offline   Reply With Quote
Old 02-21-2013, 04:26 PM   #14
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
What could cause the CEL blinking? Is that knock? Mine was doing that the other day. I don't think I heard any detonation because my exhaust is pretty loud and my friend's EWG was going off next to me.
Smoke is offline   Reply With Quote
Old 02-21-2013, 08:25 PM   #15
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
mis-fire can cause blinking cel..
please check your plugs..color and gap
Old 02-21-2013, 11:13 PM   #16
coupe-a-loop
Member#: 336028
1995 v2 sti type ra
Glacier White
Ya I think plugs is where I will start. Is it more common to have misfires under high boost? Because thats really the only time I get it. I did howver notice the other day I had no time to warm the car up properly like I always do and I did get a couple quick bleeps within the first 15 seconds of driving. Saw none after it warmed up.
