Old 02-18-2013, 07:53 AM   #1
Itsawagon37
Member#: 303384
04 Impreza WRX
Default Wagon vs Sedan strut bars
So I have been looking for strut bars, I have found many styles and manufactures, however they all have a similar stock photo yet some say will not fit wagon and others say it will. Is there really that much of a difference between them on both front and rear strut towers? Last I checked they are built on the same platform with just a wagon rear 1/4 and some minor mounting changes of body pannels(fenders/bumpers)
Thanks guys
Matt
Itsawagon37 is offline   Reply With Quote
Old 02-18-2013, 08:06 AM   #2
tuzzio
Member#: 292532
05 STI
I'd assume the fronts are exactly the same but the rears may be designed differently. Those quick release rear wagon bars are dope
tuzzio is offline   Reply With Quote
Old 02-18-2013, 10:23 AM   #3
adam_elkcip
Member#: 151329
2002 Wrx Wagon
AW
I have an ebay rear bar in my wagon, fits fine.
adam_elkcip is offline   Reply With Quote
Old 02-18-2013, 12:07 PM   #4
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
I bought a bar that claimed to only fit sedans and voila! it fit my wagon perfectly... My only suggestion is try to find a bar that doesn't dip down (see below. not my car btw)
I know somebody makes one that goes straight across, it makes it a lot easier to load stuff in your cargo area without always having to remove the bar. Quick realease or not, I hate having to pull out my bar every time I go BMXing. Though a bike rack could help my specific problem.lol.
Preludicrous is offline   Reply With Quote
Old 02-18-2013, 12:38 PM   #5
sc00by4life
Member#: 97135
yeah....those are the wagon bars.
Old 02-19-2013, 08:24 AM   #6
Itsawagon37
Member#: 303384
04 Impreza WRX
I sorta figured the wagons and sedans had the same mounts. Im cheap and the bars I want that say sedan only are 30 less then the ones that say will fit wagons.
Thanks for the help guys!
Old 02-19-2013, 08:31 AM   #7
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Doesn't matter if they're more expensive, very much worth it, a must have.
colin1234567 is offline   Reply With Quote
Old 02-19-2013, 11:49 AM   #8
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
Ha. I'm retarded...
Old 02-19-2013, 12:00 PM   #9
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
I have a Whiteline rear quick release bar. very easy to get in and out when need be.
Old 02-19-2013, 12:02 PM   #10
Honest Bob
Member#: 94698
2005 30R Wagon
You can buy the quick releases separately from a bike shop.
Honest Bob is offline   Reply With Quote
Old 02-19-2013, 12:14 PM   #11
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
The Whiteline's are beefier, the thickest bicycle quick releases I could find are 8mm and I believe the Whiteline's are 10 or 12mm. I still went with the bike ones since I needed them asap.
Old 02-19-2013, 01:12 PM   #12
sc00by4life
Member#: 97135
Ha. I'm retarded...
Sedan bars have the dip to fit into the trunk space since they can't just go straight across.
Old 02-19-2013, 01:54 PM   #13
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
Really? I honestly thought it was more complicated than that. Shows what I know...not much.
Old 02-19-2013, 11:45 PM   #14
Itsawagon37
Member#: 303384
04 Impreza WRX
I have yet to find a non sedan bar that is straight across. Im not too worried about the dip however, and I like the idea of a quick release option, did you just replace the bolts with pins I assume? (like hood pins)
Old 02-20-2013, 12:26 AM   #15
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
My $5 Ace quick release Its called a cleaver pin that goes through the bar. I had to drill out the part that mounts to the strut a little to get it to fit in the hole as the pin is thicker than the bolt it came with. I later made it into what you see by adding some lanyards i had laying around and again ace came in handy with the plastic spacers that made it not rattle. All and all....i love it and the fact its under $6 is awesome!
04jaxwrex is offline   Reply With Quote
Old 02-20-2013, 04:43 AM   #16
oguitar
Member#: 206720
2002 WRX Wagon
^^^^^ Very smart.
Going to have to do this. I wish I had thought of that.
oguitar is offline   Reply With Quote
Old 02-20-2013, 12:07 PM   #17
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
The whiteline wagon bar is straight. http://www.importimageracing.com/whi...wrx-wagon.html
Old 02-21-2013, 11:52 PM   #18
Itsawagon37
Member#: 303384
04 Impreza WRX
I like that bar...but not that price... adjustable or not its a metal bar, designed to create a stiffer chasis.. Im not going to like the dip down bar I got but then again...I got a welder, I can flip them and reweld :-)
