Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 02-21-2013, 06:04 PM   #1
GGABooSt187
Member#: 251913
2002 WRX Wagon
Default NH Smog
So, I have an 02 wagon with a 2.5L swap, catless 3" exhaust, tranny swap, suspension swap blah blah blah. I'm thinking i'm going to have trouble passing smog. if anyone else in this area has had this problem and found a solution, please PM me. Currently in the military, but not much longer so i'll have to register it here in NH. Thanks.
GGABooSt187 is offline   Reply With Quote
Old 02-21-2013, 11:36 PM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
Never had a smog test done. I don't believe NH does such, but don't quote me on that. It has to pass emissions, electronically and "visually". Aka no CEL if you're swapped I'm guessing you're tuned so as long as it has been disabled your fine or run a couple of spark plug non foulers that have been drilled out to 1/2" ID between the last 02 and the DP. Of course that will make the computer happy, but you need "pass" the visual part as well, this require knowing someone with a inspection license.
JonnyV2889 is offline   Reply With Quote
Old 02-22-2013, 12:02 AM   #3
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
No way NH does smog, every jeep in the state has a snorkel and stacks
BradX978 is offline   Reply With Quote
Old 02-22-2013, 12:04 AM   #4
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I have never seen stacks on a jeep ever.
Old 02-22-2013, 12:14 AM   #5
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
There's one in leominster with NH plates all the time over by the new Walmart . I think he/she works at tractor supply or aldee
Old 02-22-2013, 06:27 AM   #6
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
Not 100% sure what a "smog test" is but I live in NH and most inspections consist of safety items (tires / lights / horn / pull wheels to inspect brakes / ball joints / etc) and an OBD readiness check (no CELs). Every place I've been to does varying degrees of these. Some more, some less. I've found the key to passing inspection is to have a safe / legal car...
iamrazor is offline   Reply With Quote
Old 02-22-2013, 08:17 AM   #7
ginlaan
Member#: 332863
2006 STI Stage 2
Black/Wingless
Your car wont pass inspection with those mods unless you know someone that will overlook the mods.
ginlaan is offline   Reply With Quote
Old 02-22-2013, 08:45 AM   #8
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
http://lmgtfy.com/?q=nh+smog+tests
Looks to me like they just do an OBD check for emissions. You'll probably be fine.
Loyale93 is offline   Reply With Quote
Old 02-22-2013, 11:02 AM   #9
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
You will want to speak to locals before bringing your car to an inspection station. Back when I worked in NH, many of the locals complained that stations hung the inspection blackmail over your head. One guy had just completed a full brake job. The inspection place said he needed new front brakes. They had 10 miles on them.
Old 02-22-2013, 11:16 AM   #10
s2k11
Member#: 109776
2011 Sti Hatch
Emissions are done on all 96+ cars in NH. Any modifiacation in NH is illegal though I believe. Its going to depend where you bring it.
s2k11 is offline   Reply With Quote
Old 02-22-2013, 11:29 AM   #11
silverwrx666
Member#: 86514
01 rsti,86 k10,lex
LS400,is350
no front window tint and put a quiet exhaust on it. Then make sure you have no check engine lights and you should be fine at most places.
silverwrx666 is offline   Reply With Quote
Old 02-26-2013, 03:39 PM   #12
jeepnut_nh
Member#: 261162
2000 Outback Sport
blue
what the hell does snorkel and stacks have to do with passing emmissions? all the electronics would still be in place on the newer jeeps.
old jeeps like mine they dont even look at
edit:
i LOL every time i see a newer jeep set up like that, i cant imagine the ECM enjoys deep water all that much.
jeepnut_nh is offline   Reply With Quote
