Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 02-22-2013, 04:28 AM   #1
nfm
Member#: 171697
05 WRX
0whp
Default APS 65mm nonuniform flow
Just ranting here, scaling OL is getting on my nerves, take a look at this graph, x-axis: MAFv, y-axis: g/s:
check out those wavy oscillations...
It took about 7 reflashes and 30 good logs to dial in flat 11afrs, not to mention stupid tactrix disconnecting for no reason (and ferrite chokes do not help on the usb cable, nor SSD disk where I heard it should help because it's not immune to g force as much as rotating disk)
At around 3.5MAFv APS 65mm flows less than stock by 4.1% , which is where I had most problems, getting 9.9-10.3afr instead of 11.
APS vs stock flow (Ctrl +, enlarge that thing):
I have very slight exhaust leak in exh manifold, could that skew the readings wideband gets? Or does an exh leak before turbo work like $0.00 ewg?
nfm is offline   Reply With Quote
Old 02-22-2013, 08:33 AM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
You're trying to hard to get 0 trimming. Smooth out the curve and let your O2 sensors do their job.
Old 02-22-2013, 09:09 PM   #3
nfm
Member#: 171697
05 WRX
0whp
That is true for closed loop, at 3.5MAFv we're well into OL and boost where stock o2 is useless. Hmm and I say no to smoothing! The whole point was to show how wavy the flow is with this CAI, if I would to smooth that out I would be hitting 10afr instead of 11s.
Old 02-22-2013, 11:08 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
if you are hitting an AFR of 10, you dont know what you are doing.
Old 02-23-2013, 12:39 AM   #5
Airboy
Member#: 72829
2006 WRX
EFR6758
Are you scaling the MAF above 3V from full throttle runs only?
Airboy is online now   Reply With Quote
Old 02-23-2013, 02:48 PM   #6
nfm
Member#: 171697
05 WRX
0whp
Yes I use your spreadsheet to filter and get 'WOT only' samples.
Old 02-23-2013, 07:19 PM   #7
Airboy
Member#: 72829
2006 WRX
EFR6758
3.5v is around where turbo is spooling and boost/load is changing rapidly. Should collect data at part throttle so that boost/load is stable as MAF voltage sweep through the 3.5v area.
