Old 02-22-2013, 03:26 PM   #1
2011boostdwrx
Member#: 263470
Default 2011 Stage-2 Akuma SB and 6-spd swap
Guys, I am at about 500-600 break in miles on the new motor. And I am hearing like a rotational noise when inside the car @ idle but not outside. When i depress clutch it seems like it goes away for a second and then comes back after release.
I dont just know if it is because of a load on the engine. The engine consists of Weisco pistons, Eagle H-beams, ACL race bearings, nitride crank and 702 series block halves, stock heads.
I also just installed a fuel lab FPR and AP Fuel Rails, I dont remember really hearing that noise inside prior, but not 100% sure to tell the truth.
Old 02-22-2013, 06:17 PM   #2
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
did you replace the clutch? Sounds like a throw out/pilot bearing issue. Cheap parts but not a quick fix.
Old 02-22-2013, 07:08 PM   #3
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Id say Pilot bearing. If it was the through out bearing you would have the noise when the clutch isnt pushed in...
rexworx is offline   Reply With Quote
Old 02-22-2013, 07:44 PM   #4
2011boostdwrx
Member#: 263470
Evrything is brand new, 6 spd trns hdss act clutch and bearings.
Old 02-22-2013, 08:13 PM   #5
Aspensti08
Member#: 342088
sounds like a pilot bearing
Aspensti08 is offline   Reply With Quote
Old 02-22-2013, 08:17 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
Take it back to the shop that did the work
