Old 04-29-2011, 04:40 PM   #76
dynomight
Member#: 281277
2006 WRX
Silver Metallic
I will definitely apply of what I've just read whenever I have to leave my vehicle for overseas deployment from time to time.
dynomight is offline   Reply With Quote
Old 05-14-2011, 10:10 PM   #77
zeen
Member#: 215487
2002 vf39 etc etc
RA gears 340whp
I'll be unwrapping my car from a 6 month hibernation next month. It hasn't been driven since, I plan to do oil, coolant, battery change.. etc etc.. My only question is, do I change oil FIRST before i even attempt to start the car, or do I just throw in a new battery, start it let it run and then change the oil? I do plan on turning over the motor without actually starting it first.
zeen is offline   Reply With Quote
Old 05-15-2011, 12:24 AM   #78
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
If the oil was fresh prior to storage, there is NO reason to swap it out after. If not, swap it out when you like as it really doesn't matter.
Old 05-15-2011, 12:37 AM   #79
zeen
Member#: 215487
2002 vf39 etc etc
RA gears 340whp
Thanks. The oil was changed prior to storage. I'm more worried about blowing my engine for some reason, because my car has been stagnant for half a year. I'll be going from Florida to New Mexico when i get back home.
Old 05-15-2011, 12:37 AM   #80
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
To unabomber: why is that? IIRC, manufacturers usually recommend 6 months or XXXX miles between oil changes. It just seems as though you should, doesn't moisture typically get into the oil system after time too? I always thought that was the reason to change it after storage. Oh master unabomber, show us the light and explain to us why :bowdowntotheunabomber:
Old 05-15-2011, 02:05 PM   #81
hdempsey
Member#: 126374
2001 Impreza 2.5RS
Pure Aspen White
Originally Posted by Unabomber View Post
Car cover: That's a toughy. If your vehicle is stored indoors, most would say a QUALITY cover is a good idea. By quality, we are talking about a car cover that is designed to protect the finish of your car where it meets the cover as well as protection against UV rays and bird bombs. www.calcarcover.com is arguable THE source for quality covers and their catalog also contains other products for long term storage as well. If anything, you should sign up for their catalog anyway as it's really killer. if your vehicle is stored outdoors, most would say a cover is not a good idea. Think about it.....6 months or a year of the cover flapping against your paint....think it through....it that better than having your car covered in pollen/dirt/bird bombs?
If your car is inside protected against the outside, then how can pollen, bird bombs, or ultraviolet rays get in? I can understand the dust and dirt.
hdempsey is offline   Reply With Quote
Old 05-15-2011, 02:52 PM   #82
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Motor oil that is not used will stay fresh for YEARS. As long as the oil is fresh prior to storage, it will be the same as if in the bottle. And by fresh I would personally use the "week or so prior to/500 mile" rule.
Old 07-01-2011, 05:57 PM   #83
tennis
Member#: 226448
2002 Impreza WRX
Midnight Black
http://www.calcarcover.com/cover_find2.aspx
Which material is best for my bugeye's car cover? Going to college so cost is an issue. Will probably keep in outside in driveway. Possibility of getting a garage space so I don't want outdoors only if possible. Thanks
tennis is offline   Reply With Quote
Old 07-02-2011, 09:10 AM   #84
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
No one knows what the best car cover is or material or type.
Old 07-03-2011, 02:15 AM   #85
tennis
Member#: 226448
2002 Impreza WRX
Midnight Black
Ok I'll just get the cheapest.
Old 07-03-2011, 09:15 AM   #86
buki_JB
Member#: 274345
2011 STI 5dr
Terrible idea. You get what you pay for. Look for something with microfiber on the inside so you don't scratch your paint to no end.
buki_JB is offline   Reply With Quote
Old 07-03-2011, 01:45 PM   #87
tennis
Member#: 226448
2002 Impreza WRX
Midnight Black
Alright thanks a lot. Im tired of buying cheap stuff that sucks.
Old 02-22-2012, 11:54 PM   #88
Help I'm Stuck!
Member#: 248293
2010 2.5i hatch
SSM
My car is going to be stored in my garage for 6 months. My dad said he'll start the car up sometimes and let the engine run for a little. But I won't be driven. Aside from a full tank of gas oil change an interior charcoal. And I don't think mice will be a problem. What else would you recommend? It will be stored from May-November.
Help I'm Stuck! is offline   Reply With Quote
Old 02-23-2012, 06:28 AM   #89
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I'd recommend you READ post #1 as your answers are in there.
Old 10-30-2012, 01:33 PM   #90
SleeperWgn
Member#: 176293
2007 Impreza 2.5 Wgn
Newport Blue Pearl
So I have been storing my car in my (unheated) garage, only driving it around on the occasional weekend for errands/shopping, because I have a company car. Unfortunately it threw a CEL earlier this summer after being mostly unused for several months. I took it in to a local subaru specialist shop, and they told me that because I had gone past the due date of the oil change (but only 1500 miles), some of the oil had gone bad and caused a blockage inside the motor. We ran seafoam and new oil through it for a little over 600 miles, then I brought it back in for another oil change with more seafoam in it. It seemed to be fine for a while (no CEL) but one day it happened again. I cleared the CEL (battery disconnect method) and re started it, and it has been fine since. However, it'll be due for another oil change this December and I'll only have driven it about 500-600 miles probably.
My question is, is there anything I can do to safely increase time intervals between oil changes if I'm only driving less than 1k miles?
SleeperWgn is offline   Reply With Quote
Old 12-05-2012, 08:38 AM   #91
hoffmanEstates
Member#: 122043
04 wagonier
psm
Any benefits to disabling the.fuel/ignition and just cranking it? Or poping a oil galley plug and using shop air not 90psi but light puffs to get.oil to pass through bearings and heads?
hoffmanEstates is offline   Reply With Quote
Old 02-23-2013, 04:34 AM   #92
czaviar
Member#: 260862
1999 JDM typeR ver.6
white
Do you know if Covercraft or Coverking do indoor car covers for JDM type R ? I can see only RS on their webiste, but it has a lower rear wing ...
czaviar is offline   Reply With Quote
Old 05-15-2013, 02:42 AM   #93
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
Does this apply to say.... A few years? Maybe an indefinite amount of time?
Say you had it in a garage with car cover the whole time and had no one one to look after it... Will all the oils lubes and gas be ok?
pkluong is offline   Reply With Quote
Old 05-15-2013, 06:33 AM   #94
hoffmanEstates
Member#: 122043
04 wagonier
psm
Over prolonged period of time it all breaks Down,
Old 08-01-2013, 08:26 AM   #95
jopacze2
Member#: 352797
I am going to be storing my car for 6 months, what if I am not able to start it once a month at all during those 6 months?
jopacze2 is offline   Reply With Quote
Old 08-01-2013, 02:53 PM   #96
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Are you a troll or spammer or did you NOT read the first post?
Old 08-06-2013, 08:44 PM   #97
Scubaru2.5RS
Member#: 361269
2002 Impreza 2.5RS
Very nice write up. This is what a do with my civic hatchback, when winter comes.
Scubaru2.5RS is offline   Reply With Quote
Old 09-23-2013, 02:41 PM   #98
masterforce
Member#: 221580
2011 WRX STI
Nice. Write up. Basically the same steps I took with my motorcycle last winter but now im going to have to do it with my car as well for 6 months. Thank you USAF.
masterforce is offline   Reply With Quote
Old 09-24-2013, 10:51 AM   #99
MPSubie06
Member#: 321626
06 WRX
My car is taking a 6 month nap as we speak. Also USAF deployment, but definatly not complaining about it (make some money for car parts ). I took the battery out, put air in the tires, blocked it to leave the e brake down, gave her a good bath, added fuel stabilizer and a full tank of gas.
She's sitting in my garage right now so dont have to worry about the weather.
MPSubie06 is offline   Reply With Quote
Old 09-24-2013, 12:49 PM   #100
McBakes83
Member#: 196200
2013 Impreza STi
SWP Sedan
My 2013 STi has been sitting in a storage unit since the end of May. I'm deployed right now (bought it from a dealership and had it sent to my parents) and I won't come back until December sometime. Battery is disconnected and still has the plastic on everything.
I think it's sitting with <30 miles right now. Can't wait to get back and start driving it!
McBakes83 is offline   Reply With Quote
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 382 Today 02:10 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 116 08-01-2016 10:03 PM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 322 05-18-2016 02:47 PM
Car Buying FAQ: read if you are buying/selling/leasing a Subaru or other car Unabomber Newbies & FAQs 82 10-19-2015 06:42 AM
