#1 |
Member#: 271207
BAIC
Vehicle:2011 WRX SWP |
So I'm going to be installing a Grimmspeed 38mm V-band up pipe and Tial 38mm EWG soon and I did a search for a DIY and didn't see much for the 2008+. I'm sure lots of people have done it themselves so did you follow in DIYs or anything?
From some quick research it looks like its a pain in the ass to do...especially one person with jack stands and a few ratchets lol agree or disagree? I usually do all my own work but it seems like such a dozy I might just pay a someone with a lift or a shop to do it under the table....
#2 |
Lil' Ron
Moderator Member#: 140114
Vehicle:06 18G Semi Built SGM WRX |
The install is the same, the motor configuration is the same from 02-2013.
Car still smoking? |
#3 |
Member#: 332887
Vehicle:2012 WRX stage 2+ DGM (sedan) |
You may want to use ramps instead so you can safely jack up the motor to remove the stock UP. It's a pain to yank out with that fat heatsheild....
#4 |
Member#: 315546
Vehicle:03 wrx silver |
Listen to this guy, save you money dude all the uppipe bolts are visible and easy to get to. The hard part is gettign it out with the fat heatshield on it, but it does come out.
#5 |
Member#: 271207
BAIC
Do you have any DIYs I can check out? I think im gonna have access to a lift so it shouldnt be too hard, just a little unsure of how exactly to install the ewg and upipe...lol
#6 |
Member#: 332887
Grimmspeed has a video for it. If you're removing the OEM UP, you'll have trouble unless you loosen the motor mounts and jack the motor up a bit. Getting it all back in is the easy part
#7 | |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
I guess I will repost my info (again) from the last EWG thread in the 2.5L section. Hopefully you find it to be useful.
A couple notes:
#8 |
Member#: 288037
Vehicle:2013 Orange XV 11' WRX *sold* |
It's easy.
Remove Intercooler Remove turbo heat shield Remove down pipe Remove manifold Unbolt uppipe Jack up motor slightly Remove uppipe Then install new one. It's a bitch with the EWG but I found it easiest to assemble the uppipe/EWG/dump tube then wiggle it in there. Jack up motor more if you need too. Make sure you get the angles on the EWG right by putting the DP back in place to make sure it all fits. It's a tight fit so mock it up before making the EWG is snugged down. Good luck! |
#9 |
Member#: 139955
Vehicle:# OneBoston |
I prefer to install the uppipe in the car, then the wastegate onto the uppipe and then the screamer onto the wastegate.
I actually find the 2-bolt flanges to be a lot easier to deal with for this, but alas, theres that advantage that the v-band has with the lack of gaskets. |
#10 |
Member#: 343582
Vehicle:2012 wrx black |
do u have to put the ones that say h20 on the wastegate in
