Old 02-20-2013, 06:00 PM   #1
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
Default timing belt tensioner question
Just replaced my timing belt, with a gates kit.
Got everything in and last step is to pull the pin on the tensioner. This is a brand new one. I pulled the pin, and it didnt really move. the belt doesnt feel tighter, and i can still put the pin back in it no problem, is this something to be worried about? will it tighten up once i turn the motor over a few times?
thanks guys.
SaabaruAero05 is offline   Reply With Quote
Old 02-20-2013, 06:52 PM   #2
mayer2103
Member#: 301789
03 mustang cobra
white
give it 30 minutes and it should get tight
it just takes time
mayer2103 is offline   Reply With Quote
Old 02-20-2013, 08:49 PM   #3
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
Ok, thanks!!
Old 02-20-2013, 09:21 PM   #4
yeah....give it 30 minutes to push up and that should do it...dont rev the hell outta the motor for the first couple hundred miles
Old 02-21-2013, 04:33 PM   #5
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
Still hasn't moved, it's been 24 hours since I installed....
Old 02-21-2013, 04:37 PM   #6
cmiovino
Member#: 134005
2004 WRX Premium
At this point, it may be defective. It's always a possibility.
I know I took it easy on mine like Uncle Scotty said. Although, I've never heard of such a thing actually. I still felt it was better to 'break it in'.
I'd highly suggest getting another one.
Old 02-21-2013, 04:52 PM   #7
SaabaruAero05
Member#: 335112
'05 Saabaru
Red
i'm thinking its defective, i'm contacting gates right now, i'll see what they say, hopefully they will send me another one. i do have the old one still, but i would feel better with a new one obviously..
Old 02-21-2013, 07:44 PM   #8
i saw somebody post that there had been a bad batch of tensioners, lately....dont remember the details, now...but these kinds of things happen
you could use the old one for a bit while ya wait for the new one.....if you re-compress it S L O W L Y in a vise....think half a turn of the handle every 30 seconds.....find a small allen wrench to use as a pin...re-pin it and install it and done
Old 02-22-2013, 12:19 PM   #9
rick-l
Member#: 33868
2003 wrx
srp
Aren't you supposed to compress them with the cylinder vertical?
rick-l is offline   Reply With Quote
Old 02-23-2013, 12:53 AM   #10
bsuby
Member#: 347520
02 wrx
midnight black
no being vertical shouldnt matter I had to compress mine an did it on a vise horizontal an had no problems
bsuby is offline   Reply With Quote
Old 02-23-2013, 02:26 AM   #11
so rotate the vise to keep it vertical....and for temp use it wouldnt matter
Old 02-23-2013, 11:08 AM   #12
rick-l
Member#: 33868
2003 wrx
srp
I was just pointing out that the service manual says to do it vertically, I don't know why.
CAUTION:
Always use a vertical type pressing tool to move the adjuster rod down.
Do not use a lateral type vise.
