Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-16-2013, 08:47 PM   #1
twinturbomeow
Member#: 315546
03 wrx
Default Wont start after Unmarrying AP
03 wrx, flashed "revert to stock", after that completed I replugged it in just to make sure it unmarried successfully which it did because it prompted me to pick a new map to flash car with.
This is a accessport v1 btw
So then I unplugged the green connects & removed the white transparent plug. Turned the key to "ON", and the fuel pump didn't even turn on. Car turns over but keeps cranking. Can someone please help me I have work tomorrow.
Thanks in advance!
twinturbomeow is offline   Reply With Quote
Old 02-16-2013, 09:27 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
How long did you crank it? Not uncommon to take a bit longer then normal to crank after flashing a new/different map. (yes this applies to unmarrying)
Old 02-16-2013, 09:39 PM   #3
twinturbomeow
Member#: 315546
03 wrx
3-4 seconds but tried twice, but the issue is the fuel pump wont prime when key turns to on...
Old 02-16-2013, 09:41 PM   #4
Nutrients
Member#: 346825
2009 WRX
When this happens to me I just give it about 10-15 seconds and turn it over again...are you concerned about it because it happens frequently or you literally can't start it after letting some time pass
Nutrients is offline   Reply With Quote
Old 02-16-2013, 09:54 PM   #5
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Try it again....Subarus are notorious for not liking hard ECU resets...happened to me several times. Put key in to ON position, let it sit for a few seconds turn the radio on to see if it comes on, wipers, etc., then crank her....you may have to give it a touch of gas as well, not like a 72 Nova, just a 1/2 pump or two.
Old 02-16-2013, 09:57 PM   #6
meebs
Member#: 3251
2009 WRX Hatch
meebs is offline   Reply With Quote
Old 02-16-2013, 10:04 PM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You must have had one of those cars in a cold climate too. Get in, floor it for 2 seconds, ignition on, hold gas pedal half way down start car for 5 seconds, hold gas all the way down for 3 seconds, start it again and when it fires up, judiciously give it gas so it doesn't die but won't wake up the neighbors for 2 minutes until it will idle like hell but not die. Scrap entire car if on time, if late, scrap one horizontal line across the windscreen la Nazi headlight covers, and cautiously drive to work/school.
Did I just type all that mess?
Old 02-16-2013, 10:10 PM   #8
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
You really are old school, Ron.
I did all that except when my van started to sputter going up the street (costs money to idle and a 340 with a sticking valve doesn't do well with gas as it is and gas was almost 50 cents a gallon!), I'd pull the engine cover off while moving, spin off the air cleaner and put my finger in to move the choke. Automatic choke, my butt.
Old 02-16-2013, 10:53 PM   #9
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
And a can of HEET and starter fluid when all else fails...amiright?
Old 02-17-2013, 11:32 AM   #10
twinturbomeow
Member#: 315546
03 wrx
i cant tell whos being serious and whos not...
Old 02-17-2013, 12:44 PM   #11
Heedlessone
Member#: 254130
1993 LS1 RX7
Everybody is always serious on NASIOC.
Heedlessone is offline   Reply With Quote
Old 02-18-2013, 12:04 PM   #12
twinturbomeow
Member#: 315546
03 wrx
bump re-did fuel pump incase but that didnt help
Old 02-18-2013, 12:34 PM   #13
Scanyland
Member#: 282593
1996 Subaru Legacy
did you try reflashing to a cobb map. I would try that to see if it starts with a cobb map.
Scanyland is offline   Reply With Quote
Old 02-18-2013, 02:20 PM   #14
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Genius! That was my question. Have you flashed to any other maps and had success?
prescottn6ft7 is offline   Reply With Quote
Old 02-18-2013, 02:29 PM   #15
Scanyland
Member#: 282593
1996 Subaru Legacy
yup, a little commen sence can go a long way
Old 02-23-2013, 07:39 PM   #16
twinturbomeow
Member#: 315546
03 wrx
I keep getting an error when I try I flash any type of map it wont
Old 02-23-2013, 08:41 PM   #17
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Sounds like your map got corrupted somehow. What did Cobb Support folks say?
Old 02-24-2013, 01:42 PM   #18
twinturbomeow
Member#: 315546
03 wrx
will be calling them today if open
