Old 02-23-2013, 03:38 PM   #1
Dupree70
Member#: 347126
2002 Impreza 2.5 ts
Default 2002 impreza 2.5 motor issues..
I recently put in a somewhat rebuilt motor..used block and heads. .The rest rebuilt..
I keep getting misfire codes different cylinders.
Also randomly overheating when overheating..I turn on heat to try and let sone off the motor it blows cold air..
Bad head?
Any ideas?
Thx
Dylan
Dupree70 is offline   Reply With Quote
Old 02-23-2013, 10:12 PM   #2
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
I think you need to not have a "somewhat" rebuilt engine
Navendra94 is offline   Reply With Quote
Old 02-23-2013, 10:29 PM   #3
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
If you have a specific problem, my suggestion is to take time with your post so people understand wtf you're talking about.
As it is I can only offer my face rolled across the keyboard.
Hope this helps:
alksdjfla;ksjdfoiashdfoahysdolifhalskdfj;aksldjf;a skdjf;aklsdjfalskdf
And be sure to check the:
alskdjf;alskjdfo8iawujeoirjalksdfjasiodfjuaowe98t9 w0fuijailksdjflkasjdfasdf
Best of luck.
Napalm3nema is offline   Reply With Quote
Old 02-23-2013, 10:46 PM   #4
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
This.
Have you checked the headlight fluid? Make sure that's topped off. Afterwards, see if you can't explain in detail what's going on. Whats in the car, etc.
Old 02-24-2013, 06:37 AM   #5
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
You have air in your cooling system.
Old 02-24-2013, 09:45 AM   #6
Dupree70
Member#: 347126
2002 Impreza 2.5 ts
I appreciate the help..idiots..
Old 02-24-2013, 09:56 AM   #7
Scanyland
Member#: 282593
1996 Subaru Legacy
You used no real detail in your post about the problems you are having and are being asked to do so that makes us idiots.
But yes it does sound like air in the cooling system, at least for the overheating
Scanyland is offline   Reply With Quote
Old 02-24-2013, 10:12 AM   #8
jhsellers
Member#: 333484
2002 Impreza Outback
Any ideas?
Education?
jhsellers is offline   Reply With Quote
Old 02-24-2013, 10:48 AM   #9
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Listen, you need to provide SPECIFIC INFORMATION as to your issues instead of providing this junk of "somewhat rebuilt engine." What you apparently did was take a junk bottom end, and put your junk top end on it.
Instead of calling people IDIOTS and getting points for it, maybe you should reevaluate the situation and come back with information that helps us try and solve your half ass problem.
Old 02-24-2013, 03:03 PM   #10
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
$1 that heads weren't correctly torqued.
i_c_the_light is offline   Reply With Quote
