Old 01-28-2010, 12:59 AM   #26
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I just ordered that kit from harborfreight...
motohippy, how does it work? any details?
Old 01-28-2010, 01:03 AM   #27
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
It really works on the rear (for '98-'01 at least, I'm not going to speak to what I haven't done). Comes with a bunch of different adapter plates, just a matter of choosing the right one at each step. It should work with the knuckle fully removed, so long as you have it clamped down really damn well. IMHO, it would be a hell of a lot easier with the knuckle on the car, just to keep things steady, as well as to give you somewhere to brace a wrench. I followed MSA5TT0201 basically to the letter, and really only had trouble with was pulling the lateral link bolt. Bastard was fused into the bushings. I'll post a full description of it once I get the pics off my camera.
motohippy is offline   Reply With Quote
Old 01-28-2010, 01:08 AM   #28
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Please post write up on how you pressed out/in the bearing. Did it require a lot of force to remove the old bearing?
Just spent $90 ordering the kit, which is roughly how much dealer would charge for labor.
Old 03-13-2010, 09:55 AM   #29
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
$90 Harbor Freight tool I purchased seems to be exact copy of tool Subaru dealer uses.
$90 HF bearing puller
$30 Seal driver
$80 Slide hammer & hub puller
For $200 you will have nearly all tools necessary to remove / replace wheel bearing without having to use press.
Old 10-24-2011, 10:25 AM   #30
nftyper
Member#: 77269
2002 WRX Wagon
09 FXT 00 Foz L
Im so happy i found this write up with pics. Thanks for putting this up.
Update: Just bought a low milage spindle and installed it. Went very smooth with this write up.
nftyper is offline   Reply With Quote
Old 11-14-2011, 12:48 AM   #31
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Glad it worked out for you. I find it so much easier to just replace the knuckle with low miles driven in west coast.
Old 04-24-2012, 05:52 PM   #32
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
$30 Seal driver
which HF bearing puller did you end up getting?
Old 05-16-2012, 08:59 PM   #33
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Old 05-16-2012, 10:18 PM   #34
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
How exactly do you do the work with that kit?
Old 05-16-2012, 10:50 PM   #35
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Old 05-17-2012, 06:03 AM   #36
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
thanks txl
Old 06-06-2012, 08:17 PM   #37
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
Wow. 35 min and one hub is out of the parts car. Now off to buy some cotter pins and start on my car!
Uncle Tattoo is offline   Reply With Quote
Old 06-06-2012, 09:04 PM   #38
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Update: can't get the axle nut loose on mine. Guess I'll try again tomorrow!
Old 06-07-2012, 06:08 AM   #39
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the nut is best broken loose with a big impact gun.
you may have issues with the axle splines being frozen in the hub. on one i had to remove everything INCLUDING the axle, put the knuckle in a vise, and then bang the **** out of the axle with a sledgehammer to get it to break loose.
the axle metal is softer to prevent shattering and it will deform easily. you can keep the nut partially threaded on, put the socket back on, and then hit that. as it was i ended up replacing the axle with a spare i had laying around.
a bit of anti-sieze on the splines isn't a bad idea on reassembly.
Old 06-07-2012, 06:09 AM   #40
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
or, if you have a bearing puller, that would work too. the axle has a center detent for the puller pin.
Old 06-08-2012, 12:53 AM   #41
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Uncle Tattoo, did you try to remove the axle nut with the wheel on the ground?
Get a 32nm socket and big breaker bar to break it loose!
Old 06-08-2012, 10:33 AM   #42
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
On the ground and in the air. It took a breaker bar with an STi mid pipe cheater bat and 260 ft/lbs of uncle tattoo to busy it loose. Everything else was a snap!
I highly agree with renting the tie rod kit, buying a 6pt 32mm socket, and a long heavy cheater bar. Oh and a new axle nut. And cotter pins lol. Good thing there's an advance auto within 2 blocks of me.
Old 06-08-2012, 11:04 AM   #43
Samurai Jack
Member#: 21145
2002 Enemy of Aku
subscribe
btw - the write-ups on these procedures are excellent!
Thanks to those who took the time to document them so well
Old 01-11-2013, 09:31 PM   #44
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I had to replace wheel bearing/knuckles on all but front driver side knuckle within 500 miles of each other. Surprisingly front driver side wheel bearing is still holding up after 105k miles.
Old 01-12-2013, 08:25 AM   #45
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
ball joint replacement can be easy or impossible. The easy way is buy the turn in concepts ball joint removal tool. which threads onto the bottom of your ball joint, and then a counter nut pulls out from he knuckle. Took 5 mins. I have one to loan for ship charge.
The hard way is to pb blast, hammer, heat, bend, break stuff and nothing moves and then swear for hours. and keep car on jackstands while you wait for the right tool.
also bought the harbor freight wheel bearing set for $90, set of dies and threaded rod with counter nuts to press bearings out and then pull back in. worked very nicely. and will invest $60 in a slide hammer to remove hub so bearings can be replaced with knuckle on the car.
fyi here's another two threads on rear wheel bearing replacement:
http://forums.nasioc.com/forums/show....php?t=1925081
Old 01-20-2013, 01:56 PM   #46
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
I just replaced both front axles on a recently purchased 200k miles MY02 wagon that spent all of its life in New England. I am very fortunate that both came out of the hubs with no effort at all. I think the anti-seize is a great idea.
Old 02-21-2013, 08:18 PM   #47
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I am going to be installing front EMP axles and driver side knuckle this weekend. Will make sure to post some more pictures.
Old 02-22-2013, 11:48 PM   #48
dollar5th
Member#: 324540
Pickle forks are a bad idea, can easily damage the ball joint boot. A large pry bar on the lower control arm and hammer on the control arm is better.
dollar5th is offline   Reply With Quote
Old 02-24-2013, 02:59 AM   #49
ejsmallz
Member#: 329402
03 WRX Wagon
Where did you get your new 05 hub assembly from?
ejsmallz is offline   Reply With Quote
Old 02-24-2013, 04:50 PM   #50
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I found used hub assembly / knuckle from eBay. Much more cost effective than replacing wheel bearing, although there are risks involved.
DIY: 06 Rear diffuser on 02 WRX sedan txl146 Interior & Exterior Modification 39 03-16-2013 07:38 PM
DIY: Front Group N strut top mount install on 02 WRX txl146 Brakes, Steering & Suspension 7 09-18-2010 01:37 AM
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
DIY: STi short shifter kit on 02 WRX txl146 Transmission (AT/MT) & Driveline 4 06-11-2006 09:54 PM
GD Knuckle/bearing/hub assembly fit on GC's? MyFirstDeuce Brakes, Steering & Suspension 2 01-08-2006 03:13 PM
