Old 08-29-2008, 10:34 AM   #1
gigabytexbc
Member#: 123767
2009 WRX Stage 2+
Gray
Default Rear Strut Rattle
ok, so my right rear strut has started to rattle, even while going slower speeds. there is no clunking because trust me i blew the same strut and i know what the clunking sound etc... is and this isn't the case(in terms of superbly loud clunking something is going to rip through the bottom). this sound is just rattling, almost like something is loose and moving around. once again it's coming from the right rear and you hear it on well paved streets while driving, while making right turns, and over slight bumps. the sound is a rattle like something is moving around around the strut area. they are kyb gr2 struts for an 05 wrx for those that want to know. replaced the right rear 2 months ago after a goodluck streak of a year so hopefully not blown but doesn't sound like it did before in terms of loud clunking but it did rattle like this but louder before. just the whole "what the hell is moving around and rattling back there" type of sound what are my options of what it could be?
gigabytexbc is offline   Reply With Quote
Old 09-05-2008, 05:35 PM   #2
FUBAR
Member#: 2132
11 STi Sdn
Sparkling Slvr Met
im having the exact same issue, however im on stock 02 struts w/prodrive springs. my local shop says that its the endlink that is broken, specifically the plastic grommet w/in the endlink that you put the bolt through that connects it to the swaybar. Im currently in the market to get the kyb-gr2's and new rear endlinks. by the way the endlinks are perrins. Second pair of rear enlinks the first were whitelines and i snapped those now this.
hope this helps
FUBAR is offline   Reply With Quote
Old 09-06-2008, 12:16 AM   #3
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
hope this helps
plus 1
RaceComp Engineering is offline   Reply With Quote
Old 02-24-2013, 06:08 PM   #4
mrchyes
Member#: 294069
04 Impreza RS
the tophat on my rattling strut was defective, causing the strut top nut to not be physically able to tighten it down, the nut was at the end of the threads, couldnt tighten any more, yet there was wobble room for the tophat between there, that was the rattle. Used my old tophat, problem fixed. yay
mrchyes is offline   Reply With Quote
how to fix rear strut rattle? jetski247 Brakes, Steering & Suspension 2 02-25-2013 06:20 PM
WTB: 05 STI Rear Strut Dust Boot j_contar NESIC Private Classifieds 5 06-05-2010 10:32 PM
Prodrive Spring Install. Rear Strut Rattling? iRace559 Brakes, Steering & Suspension 5 11-19-2007 07:40 AM
rattling rear strut tower brace caryfd227 Brakes, Steering & Suspension 5 12-21-2004 10:27 PM
HELP: Rear Passenger Strut Rattles sanders Brakes, Steering & Suspension 1 10-26-2000 08:28 AM
Message Board Statistics All times are GMT -4. The time now is 07:31 AM.
