Old 05-29-2007, 06:04 PM   #1
MorallyBass
Member#: 58094
2004 WRX STi
Default Rattling after Strut install?
Two questions:
1) What's the proper torque spec for the bolts securing the rear strut tophats to the chassis? (2004 STi)
2) Other than loose bolts securing tophats/strut assembly to the chassis - what could cause a rattling/clunking from right rear tire area? These are new struts - not clunking struts! All interior pieces in this area have been tightened and re-secured. Leading me to believe it's something loose in the suspension component.
Help?
MorallyBass is offline   Reply With Quote
Old 05-29-2007, 06:05 PM   #2
MorallyBass
Member#: 58094
2004 WRX STi
Follow-up - I'd like to double check everything is tightened to spec (had a problem with loose endlinks after swaybar install - tightening bolts there fixed another clunk from front-end). If that fails, will investigate other potential issues.
Old 05-29-2007, 06:34 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
AFAIK the tophat to chassis bolts are and always have been 14.5 ft-lb (20 Nm)
A more common cause of rattling is the actual strut topnut (41 ft-lb or 55 Nm) which is harder to torque adequately
As you say, endlinks are another common source
UkNuck is offline   Reply With Quote
Old 06-04-2007, 12:32 PM   #4
MorallyBass
Member#: 58094
2004 WRX STi
Thanks for the help here. I'm hoping to torque these down after work tonight.
It shouldn't be a problem to check the chassis bolts with a torque wrench. Will the top-nut be trickier?
Old 06-04-2007, 12:44 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Yes it will be trickier.
If you have stock struts, there is a hex head in the top of the shaft which you can use to hold it from turning. You will need a pass-through type socket. In the past I have managed to do a final torque by using an offset box wrench to hold the nut and then torquing the hex.
Or you can sometimes get enough grip with a rubber strap wrench on the strut. It allows you to use a regular socket/torque wrench on the nut. With most aftermarket struts that's your only option.
Old 06-04-2007, 12:48 PM   #6
MorallyBass
Member#: 58094
2004 WRX STi
I've got brand new Ohlins fixed perch struts, which were professionally installed.
I've been hearing this sound after installation.
I had problems with loose endlinks in the front soon after install, so I'm skeptical of proper torquing. I want to try to re-torque the rear strut to rule out the rattle coming from that area of the vehicle. Thanks, I'll see what I can do. If it's this tricky, I can see why they may not have torqued it properly.
Old 06-04-2007, 12:52 PM   #7
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
In that case you should talk to your installer - the torque specs I gave you are for stock pieces
Old 02-24-2013, 06:09 PM   #8
mrchyes
Member#: 294069
04 Impreza RS
the tophat on my rattling strut was defective, causing the strut top nut to not be physically able to tighten it down, the nut was at the end of the threads, couldnt tighten any more, yet there was wobble room for the tophat between there, that was the rattle. Used my old tophat, problem fixed. yay
mrchyes is offline   Reply With Quote
Rattle after DP install (Video) djburn1200 Texas Impreza Club Forum -- TXIC 8 05-10-2008 06:59 PM
Buzz/Slight Rattle after TBE installed ajshades Factory 2.0L Turbo Powertrain 2 04-02-2008 12:20 PM
Rear End Rattling After Strut/Spring Install. Any Ideas? williaty Brakes, Steering & Suspension 43 11-11-2007 04:23 PM
clunking after strut install Rickyh Brakes, Steering & Suspension 1 01-18-2006 05:45 PM
Message Board Statistics All times are GMT -4. The time now is 01:14 AM.
